Are cx revo topper
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ScrappyOreo, Feb 2, 2019.
  1. Feb 2, 2019 at 6:56 PM
    ScrappyOreo
    ScrappyOreo [OP] New Member
    2019 Toyota Tacoma TRD Off Road
    Remote Start,
    I ordered the ARE CX Revo topper. For my new Toyota Tacome TRD Off Road. Should have installed in 4 weeks. Question is, has anyone had any water leaks around the bed and if so how was the leak corrected. Topper (Dealer) Said the design of the Tacoma bed was prone to leakages because of the plastic trim on top of the bed. Appreciate any input. Thanks
  2. Feb 2, 2019 at 7:37 PM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    I was looking at the same cap, how much did you pay for it?
  3. Feb 2, 2019 at 7:45 PM
    BortisYeltzen
    BortisYeltzen Well-Known Member
    Barrett
    Salt Lake City, UT
    2017 MGM TRD Off-road DCLB
    OTT Tuned, Bilstein TRD Pro lift, ECGS bushing, Heated Clazzio's, RCI SKID TRILOGY, BAMF sliders, ARE V-Series shell, RokBlokz flaps, more to come
    It’ll leak, they all do. Get a bed mat, seal as best you can and live with it. Water will get in, if you make it too tight, water can’t get out and bad things happen. Figure out how to manage it. I have a ARE V-series, bed cubby covers, sealed the rails, etc... It is pretty tight and minimal leaks, however, I bring water in when I put wet gear, snow-packed skis and snowboards in there. The shell then traps the moisture and it can’t get out and all the sudden my shell is fogged up, wet, and I have to wait for warm weather, open the windoors and back and dry it out. What I’ve found is managing dust is way more critical than water. With a bed mat, any water that leaks in runs down and under the bed mat. As long as I’ve got a place for that moisture to drain, I’m set.
    Also, the tailgate has massive gaps, you’ll need to seal that regardless of how well your shell is sealed.
    https://www.amazon.com/Adhesive-Uni...49165950&sr=8-4&keywords=tacoma+tailgate+seal
    And these:
    https://www.tacomaworld.com/threads/bed-cubby-caps.491909/
