are satoshi grills really that hard
Discussion in '2nd Gen. Tacomas (2005-2015)' started by meckleystephen, Feb 2, 2010.
  1. Feb 2, 2010 at 5:36 PM
    meckleystephen
    meckleystephen [OP] My Taco is Bi-Winning!!!!!!!!
    Stephen
    York, PA
    2013 Toyota Tacoma Off Road
    3 Inch Toytec lift,Blacked out badges
    i was thinking about doing this mod and have done some pretty extensive research i have some expierience with bondo and fiberglass i was just wondering since i have a grillcraft on the way
  2. Feb 2, 2010 at 5:40 PM
    Ptowntaco
    Ptowntaco Camburg :)
    Bryce
    Petaluma Ca.
    2000 Prerunner TRD
    Tint, Socked, Deck Plate mod, Camburg 2.5 coils, Camburg UCA, 5100's in the rear, Custom Deaver leaf pack, Micky Thomson Classic Locks, BFG KM2, CB
  3. Feb 2, 2010 at 5:42 PM
    1337Taco
    1337Taco Well-Known Member
    Kevin
    NorCal
    2015 4X4 Manual
    If you are challeneged like me than yes. But if you follow the directions and use the correct tools than it should be fairly easy.
  4. Feb 2, 2010 at 5:43 PM
    surfsupl
    surfsupl Well-Known Member
    Gregg
    WestCoast
    I DONT CARE IF IT'S A RE-POST
    Rear Diff Breather~ 5100's ~Fog Light Anytime~Tint~TRD Seat Covers~Weather Tech's~Pioneer H.U.~Lift~Eibach Springs~LED's......blah...blah...blah
    Just take your time in doing so...............no need to rush...............you will be amazed how you feel when finishing this mod.................good luck...........:thumbsup:
  5. Feb 2, 2010 at 5:45 PM
    Duff Man
    Duff Man Well-Known Member
    Sean
    North Carolina
    09 TRD Off Road
    AEM CAI, Magnaflow exhaust, DT headers, all speakers replaced with (2) 10's and amp behind rear seats, color matched grill, grillcraft, projector headlights, 8000k HID's, DC Torque wheels, 3" Toytec lift, Bilstein 5100 shocks.
    I'm going to attempt it this weekend, hopefully it's more towards the easy side:goingcrazy:
  6. Feb 2, 2010 at 5:47 PM
    cntstan
    cntstan Well-Known Member
    Chuck
    Wisconsin now, North Carolina will always be HOME
    08 DC SR5 4X4 ; 94 Ford Bronco
    3" Toytec coilovers, rear AAL,satoshi'd grill,ARE topper,TRD exhaust, All Pro winch bumper, Warn winch, All Pro skid, Pro comp 7089's, Supersprings, Wet Okole seat covers
    They are not as difficult as you might think. The hardest part for me was getting the guts up to start cutting up my grill. Once you have the middle bars cut out and the small "leftover" tabs sanded down, it's just a matter of reinforcing the holes left behind with fiberglass and filling it smooth with the bondo. Attaching the grillcraft on the backside can be tricky but I just sandwiched some brackets on the backside between the fiberglass and the plastic, then used small bolts to attach the grillcraft to the brackets. Then paint over the bondo and you're done.
  7. Feb 2, 2010 at 6:00 PM
    cntstan
    Chuck
    I have one of these and they are awesome for cutting things flush and sanding in tight areas. I think dremel makes a similar one that is probably less expensive.
  8. Feb 2, 2010 at 6:03 PM
    meckleystephen
    Stephen
    York, PA
    well i just found out that i since i ordered on a group buy im gonna have to wait like three weeks for the grill :( so i might just try and do the satoshi mod and then throw some chicken wire on it and then when i get the grill put it on thanks for all the info tho
  9. Feb 2, 2010 at 6:05 PM
    meckleystephen
    Stephen
    York, PA
    did u just paint the inside of ur grill with a high gloss spray paint i have a blue truck how would that look???
  10. Feb 2, 2010 at 6:06 PM
    cntstan
    Chuck
    No, I used a flat black. I like the way it matches just fine.
  11. Feb 2, 2010 at 7:44 PM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    Don't do it ... its REALLY hard.... wuss out, be lazy you don't really want to do all that work....
  12. Feb 3, 2010 at 8:21 AM
    joshua32
    joshua32 Well-Known Member
    Joshua
    Tyler, TX
    06 Prerunner SR5
    You can always order a spare from certifit and get started on that. I found one off of ebay for 12 bucks and did my mods to that then ordered color matched paint from ebay for my color code and painted it with that. The color was a perfect match. I am by no means experienced at body work but pretty good at doing things if I read up on it enough. I had the ugly SR5 chrome grill and chrome insert and now the front looks completely different. Good luck!
  13. Feb 3, 2010 at 8:25 AM
    MikeyD
    MikeyD Well-Known Member
    Sayreville NJ
    2007 Toyota tacoma 4x4
    BHLM, HID kit, yellow fogs, Grill craft, Hellas behind grillcraft, LED cup holder mod, after market horn, extra reverse lights, under body glow for off roading at night, pro comp 7089's wrapped in 255/75/17 bfg mud terrains, Toytec coiovers sat at 3.25, 2" add a leaf with 5100's, Satoshi grill mod
    Go for it. I wouldnt say it is hard. Its just time consuming. Just alot of sanding and sanding. Just take your time and you will be fine.
  14. Feb 3, 2010 at 8:37 AM
    ja66ba
    ja66ba Member
    I thought fiberglass and bondo don’t stick to plastic. And even if you get it to stick, in time it will crack and pop out. Has this happen to anyone yet? :confused:
  15. Feb 3, 2010 at 9:47 AM
    HondaGM
    HondaGM CallSign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    if it does pop off,you can go to lowes and get some chicken fence wire and replace it.:rofl:
  16. Feb 3, 2010 at 10:37 AM
    1BlkT
    1BlkT Mod'n on a Budget
    Ty
    90603
    2006 Black Sport Double Cab
    Allied 4'' Spindles, Sway A Way 2.5 Coilovers, Donahoe Remote Reservoir Shocks w/ Deaver 11Pack Leafs, Goodyear Duratrac 285's, Pro Comp Series 8128, Recessed Grill w/Hella 500's behind, Tint, Black TRD Skid Plate, Debadged, Tailgate Hose Clamp, Weathertech Mats, Aero Turbine 2525XL Exhaust, Volant Intake, RETRO'D Headlights by Yosh2000
    Make sure you rough up the plastic where you are laying the fiberglass and extend it past the areas you are covering and you should be fine. I haven't had any problems with mine and I've had it for a little over 2 years.
  17. Feb 3, 2010 at 1:51 PM
    Viet2100
    Viet2100 Well-Known Member
    Viet
    South Florida
    2016 Prius 4T
    Not hard, just time consuming.
  18. Feb 3, 2010 at 2:47 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    I'm in the same boat as you with the grillcraft, and I clicked on this thread thinking...."hmm, now that I have the time....".
    I also have an extra grille so I'm very tempted.
  19. Feb 3, 2010 at 2:52 PM
    topgun155
    topgun155 Well-Known Member
    Zack
    Richmond, TX
    2018 F-150 5.0
    RIP to my 08 Prerunner DC
    It really isn't too hard. Just take your time and follow the directions.
    It is more of a tedious and time consuming job.
  20. Feb 3, 2010 at 7:03 PM
    meckleystephen
    Stephen
    York, PA
    yea i might just do the satoshi mod and then throw some chicken wire in it that way when i get it i can just put the grill on its supposed to snow anyway all weekend so the garage is free and warm
