Are the tailgates / cables really strong?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cycledrum, Feb 12, 2008.
  1. Feb 12, 2008 at 9:22 AM
    cycledrum
    cycledrum [OP] Well-Known Member
    Union City, CA
    88 4X4 Pickup xtra cab, SR5
    I see they switched to cables instead of the flat folding bars I have on my '88 pickup for securing the tailgate.
    I hope those cables are plenty strong. Sometimes I haul a 500 lb motorcycle in my truck ... hate to have a cable give out going up the ramp.
  2. Feb 12, 2008 at 9:45 AM
    Cburt
    Cburt Well-Known Member
    Kansas City
    SR5 4x4, White
    None currently,
    I would say your tail gate won't support a 500 pound motorcycle and a 200 pound rider.
    I have thought about how I might load my Triumph in the truck and concluded that removing the tail gate and putting the ramps directly on the truck bed would be the safest option. Then put the gate back on.
    Check your owners manual, because believe I have seen somewhere that the gate will only support 200 pounds or so. Yea, can you believe it?
    Mine will flex ever so slightly when I step up on the middle and I weigh 200.
  3. Feb 12, 2008 at 10:26 AM
    cycledrum
    Union City, CA
    I don't own a Tacoma, just looking. If the tailgate won't support a bike going up a ramp, that would be bad. I'd hate to go through the hassle to unbolt/remove the tailgate for every load/unload.
  4. Feb 12, 2008 at 10:41 AM
    Cburt
    Kansas City
    SR5 4x4, White
    None currently,
    I have used mine w/ the tailgate down loading a 300 pound lawn tractor w/ my 200 pound carcuss on the seat without issues. If you don't put all the weight in the middle of the gate I don't think it is a problem.
    I believe the gate will buckle in the middle with the weight smack in the middle and 700 pounds of motorcycle and rider.
    There is a fix that i have seen on another site, but if your aware of it and carefull you should be fine.
    The Toyota isn't heavy duty as a full size pickup would be, but then your not getting 10 miles per gallon either and you can get it into your garage.
    Depends on what you want or what you can get buy with.
  5. Feb 12, 2008 at 10:51 AM
    cycledrum
    Union City, CA
    My ramp is over a foot wide, so the load is spread. Also, I walk / push the bike onto the truck, never ride it on. I've got a question into a local dude with a 4x4 Access prerunner. He hauls motorcycles all the time.
  6. Feb 12, 2008 at 10:54 AM
    Cburt
    Kansas City
    SR5 4x4, White
    None currently,
    cycldrum I'm interested to hear what he has to say.
    Does he haul dirt bikes, you know they don't weigh nearly as much to a full size street bike.
  7. Feb 12, 2008 at 11:06 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    You'll find the cables to be stronger than the tailgate. Some have pulled apart their gates and reinforced them with additional steel. Might be worth investigating if you'll often be loading/unload from the gate.
    As for removing the tailgate, it'll take under a minute once you see how it comes apart. It makes the cost of a locking latch seem pretty cheap considering the possible alternative. ;)
  8. Feb 12, 2008 at 11:21 AM
    cvillechopper
    cvillechopper Jackass to the masses
    Charlottesville, VA
    '24 DCSB TRD Off-Rd, Premium Package
    Console lock-box, Studly Driver
    I just picked up an old project bike (~600 lbs) last week and loaded in into and off of the truck without removing the bed. No problem. I didn't transport it with the weight on the tailgate though. I angled the bike diagonally in the bed so the rear was mostly on the bed.
  9. Feb 12, 2008 at 3:46 PM
    concrete jedi
    concrete jedi Well-Known Member
    Rochester N.Y
    06 Tacoma 4 door indigo blue
    Broken and scratched tailgate, cracked rear tail light lens, coffee stain in driver seat.
    A piece of thick plywood would help displace the weight of the bike, I just wouldn't hang out on the tailgate, load the bike and go on.
  10. Feb 12, 2008 at 10:20 PM
    cycledrum
    Union City, CA
    I'd think this guy hauls his GSXR1000 in his truck, he goes to trackdays. Haven't heard back from him yet.
  11. Feb 12, 2008 at 10:28 PM
    cycledrum
    Union City, CA
    I was thinking of something like that too ... like rolling the bike onto a piece of aluminum channel which would keep the front wheel from turning and hopefully keep the load off the tailgate. Could fashion a crossbar at front of bed to keep the channel in place without having to bolt into the truck bed.
  12. Feb 13, 2008 at 7:30 AM
    willard417
    willard417 Yeah
    Luke
    beaver county, PA
    06' access cab. 2.7L
    alpine head unit, removed secondary air filter, 18" XD Rockstars. 285/60/R18, 3" OME 884/AAL OME shocks all around.
  13. Feb 13, 2008 at 7:37 AM
    Cburt
    Kansas City
    SR5 4x4, White
    None currently,
    He meant removing the tail gate..........I hope.
    Using a plywood sheet sounds to be the best idea. I will keep that in mind if I need to haul my bike someday.
  14. Feb 13, 2008 at 8:11 AM
    cvillechopper
    Charlottesville, VA
  15. Feb 16, 2008 at 11:16 AM
    stucksucksnayota
    stucksucksnayota Well-Known Member
    Barry
    Fort Smith, Arkansas
    14 Taco 4x4 TRD Sport DCSB
    OEM roof rack, Shorty antenna (eBay), soft tonneau cover, K&N drop in air filter, bed mat, interior LED lights, 5100's, MT tires to come soon!!!
    Well I've been reading this thread and thought i would chime in. We do alot of 4wheeler riding which means riding the 4wheeler up into the back of the truck on ramps. I have an 01 double cab 4x4 trd and a 2004 yamaha big bear and i think that the dry weight on this bike is around 450 to 500 pounds may be a little bit lighter but I weigh around 250Lbs and i ride the 4wheeler up the ramps into the truck and have never had a problem at all. I dont think i would worry about the cables breaking or your tailgate bending
    Heck its a Toyota remember LOL
  16. Feb 16, 2008 at 12:27 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    FYI: There is a tailgate TSB for this issue.
  17. Feb 16, 2008 at 3:01 PM
    Flycatcher
    Flycatcher Master of the Universe
    Minnesota
    2009 Acadia (regretfully sold the Taco)
    The tailgates bend easy, there wouldn't be a TSB if they didn't. I think there is already one member here that bent one loading a bike. I bent mine unloading a ball and burlapped tree. Everyone who is loading gunsafes and 4wheelers and other things like that need to consider that the weight displacement is completely different. A motorcycle puts all its weight in 2 spots the size of your hand. A dirtbike or sportbike should probably be fine. Even the liter bikes are only around 400lbs these days. A cruiser or something plump like that might be too much. It couldn't hurt to take off the gate though or use plywood to disperse the weight. It takes seconds. Even if it does bend you can get it replaced for free.
  18. Feb 17, 2008 at 7:36 AM
    Cburt
    Kansas City
    SR5 4x4, White
    None currently,
    Fly, are you saying if I bend my talegate that Toyota will replace it under warrantee?
    Are you serious?
  19. Feb 17, 2008 at 8:27 AM
    WilsonTheDog
    Eric
    Myrtle Beach SC
    ^That is correct.
  20. Feb 17, 2008 at 9:31 AM
    Roland
    Roland My other ride has sails
    Rhode Island
    06 Impulse Red I4 2WD Access Cab
    UnderCover Tonneau, Bed mat, Bug Deflector, aFe Pro Dry S, Secondary Air Filter removed, Synthetic 5W-30 oil, Scanguage II with blendmount, WeatherTech floorliners, Toyota seat covers, Installed OEM intermittent wipers, TacomaWorld sticker, Defrost without AC mod, Hidden Hitch
    Only if it's under the 3 year 36000 limit.
