Are there any deals on the Bilstien 5100
Discussion in 'Downsouth Motorsports' started by roxspin72, Aug 22, 2010.
  1. Aug 22, 2010 at 3:05 PM
    roxspin72
    roxspin72 [OP] Enjoying my addiction
    NC
    Speedway Blue, TRD, 4X4,
    Oh Yeah!!!
    Looking for front and back set for my buddy. BE5-C477-TO & 478-TO...
    My discount code only works on fronts.
  2. Aug 23, 2010 at 9:52 AM
    Downsouth Motorsports Downsouth Motorsport Vendor
    Lakeside, Ca. 92040
    2017 4-Runner Dirt King Long Travel King 2.5 Coil-Over / 2.5 Bypass Front and Rear ICON Rear Upper and Lower Arms ICON Rear 2" Springs 34" x 10.50" x 17 Toyo Tires on 17" x 9" RaceLine Wheels
    Good In stock here at DSM and the discount code for all "4" is
    BIL0509
    Thanks,
  3. Aug 23, 2010 at 1:47 PM
    roxspin72
    NC
    Oh Yeah!!!
    Thanks...
  4. Aug 25, 2010 at 10:05 AM
    Veccster
    Veccster bass turds
    Eric
    Pittsburgh - The City of Champions
    2020 Pro
    Awesome...Worked for me.
    To anyone else...make sure you don't put a space after the code.
  5. Sep 16, 2010 at 6:09 PM
    BGrutter
    BGrutter Well-Known Member
    Baron
    Kansas City, MO
    2010 4x4 DCSB TRD OR
    Rear-View Camera Mod, Anti-theft Tailgate, No Mud-Flaps, Diff Breather Mod, Color-matched Mirror/Handle covers, Front Valance mod, Phone/GPS/Camera mount, and Illuminated 4x4 Switch ToyTec Ultimate Lift Light Racing UCAs
    Wow, and I shoulda known that... I'm an idiot. I was about to post for an updated code. Good looking out :cheers:
  6. Oct 12, 2010 at 9:28 PM
    dustinclm
    dustinclm Well-Known Member
    Thibodaux, La
    2012 Super White DC 4x4 V6
    Bilstein 5100 set at .85" WeatherTech Floor Mats
    im looking into getting a set of 4 of the 5100's for my truck,and i have questions..do i need to discard the front spacers i already have for my lift? could anyone give me a part #/price? 2001 2.7L 2wd prerunner, thanks
  7. Oct 12, 2010 at 9:38 PM
    Lakeside, Ca. 92040
    Here is a link to the 5100s page on the site:
    http://downsouthmotorsports.com/b-614-bilstein-performance-shocks.html
    And here is a link to the TW thread with the discount codes & how to use them: http://www.tacomaworld.com/forum/1s...bilstein-5100-1st-gen-95-5-04-dsm-update.html
    And as for the spacers, we would recommend eliminating them and using the shocks for lift. But you can also keep the spacers, but you must install the shocks at the "stock" or zero lift setting if you do so.
    Marco @ DSM
  8. Oct 12, 2010 at 9:41 PM
    Leadgolem
    Leadgolem Well-Known Member
    Greg
    Littleton, CO
    98 Tacoma SR5 2.7L 4x4 stick
    Herculiner bed liner, White LED instrument lights, Custom painted hood, Homemade leather steering wheel wrap, Avic u310bt gps stereo, 1.5" bushwacker fender flares, 1.25" bilstein lift front, 1" shackle lift rear, rear bilstein 5100 shocks, ridiculous helper spring lift rear, wet okole seat covers, mutilated exhaust, boom mat under hood
    I'd remove the front spacers if it was me. The 5100's front lift is a suspension preload. Basically, it does the same thing as a top nut spacer just in a different location. Don't know a part# but they are 350 for the whole set on toytec. You can pm username "ToyTec Lifts" for a discount code. They are a vendor on here as well.
    EDIT: Wow, downsouth does have a better price. Even with the toytec code.
    EDIT2: Just in case it hasn't come up yet, these shocks do not lift the rear of the truck one bit.
  9. Oct 12, 2010 at 9:52 PM
    dustinclm
    Thibodaux, La
    thanks, i will call tomorrow! just another question or two...i know that i wont know how much better the truck will ride untill i put them on, but i am on a college budget so im just making sure it would make the ride more comfortable than the already installed spacers...also, i have 3" blocks in the back, the 5100's will work in the rear with blocks, i dont need the 5125's? lastly, will these do any to level the truck, as it is the back is just a hair higher than the front and i dont want to lose any height in the front by removing the spacers
  10. Oct 12, 2010 at 9:56 PM
    rv210
    rv210 Well-Known Member
    robert
    san antonio
    ***HAD***05 quadcab 4x4 taco
    bed cover, piaa led's, bfg a/t tires,17' pro comp 6089 rims,billies 5100's in front set at 1.75'
    I bought mine from dsm and installed hem at 1.75 and I love it
  11. Oct 12, 2010 at 10:04 PM
    Leadgolem
    Greg
    Littleton, CO
    The 5100's have the additional travel you need when doing a lift. They should be fine on the rear with 3" spacers.
    If your not going to remove the blocks on the front the 5100 would need to be set at the lowest snap ring position. So they wouldn't do anything to lift your truck more. If you want to go over 3" you really need to get new springs, and UCA's.
    How big of spacers do you have on the front?
    With a the snap rings set to either 0 or the 1.25, this being the middle of 3 grooves available, the ride is better then stock with no modifications. At 2.5, the top ring position, the ride is slightly stiffer.
  12. Oct 12, 2010 at 10:37 PM
    dustinclm
    Thibodaux, La
    the spacers are for a 3" kit but i just went measure the spacer ad it is only 2.25" http://www.tuffcountry.com/suspension-kit/toyota-tacoma-1995-04-lift-kits.html that is the kit i have...so i should get just a little more height with the 5100's when i take out the spacers if im not mistaken. eventhough it may be stiffer than stock, i cant see it being like it is now, its pretty darn stiff
  13. Oct 12, 2010 at 10:51 PM
    Leadgolem
    Greg
    Littleton, CO
    Actually, you'll get about 1/2 less with the billies. Your current spacers are probably providing you with an actual 3" of lift. Putting top nut spacers on changes the amount you lift more then the actual spacer size.
    Draw a triange in your head with the upper control arm being one side of a triangle. Another side of it is the lower control arm. The third being the tire. Now, the shock is inboard of the tire. So lengthening the triangle there has a proportionately larger effect on the length of the side of the triangle with the actual tire as it's side. Basically, you are closer to the pivot point of the triangle. Putting in a spacer is like putting a board or something near the hinge on a door so it won't open all the way.
    If you want to you can keep your spacers there and just install the new front shocks at 0, the lowest snap ring position. The billies really are superior shocks and should help with the ride even with the spacers.
