are these mods cool?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jonny U, Apr 4, 2009.
  1. Apr 4, 2009 at 10:05 AM
    Jonny U
    Jonny U [OP] Member
    Phoenix
    07 Tacoma Sport
    Ok, I think I am ready to get my lift. Here are the mods that I am thinking of. What do you think? Are there any suggestions from anyone about something else I should add or do before I go with it?
    - Revtek "3 inch lift
    - coilovers
    - UCAs
    - Bilstein 5100s
    - AALs in rear
  2. Apr 4, 2009 at 10:12 AM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    Sounds like a perfect set up. Make sure to pick a quality 3" lift kit
  3. Apr 4, 2009 at 10:15 AM
    THXEY
    THXEY Panda Jerk
    Jacob
    San Diego
    2013 Subaru WRX
    STi Short Shifter.OEM floor illumination kit. Rally Armor Mud Flaps. BC BR Coilovers. Invidia N1 Exhaust
    theyre very cool but if your going for looks idk i wouldnt spend all that money for all loks and not for off roading
  4. Apr 4, 2009 at 10:17 AM
    rick
    rick `
    revtec spacer? if you are getting coilovers you don't need the revtek. and i assume you mean the rear 5100s.
  5. Apr 4, 2009 at 10:18 AM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    doesnt the revtec 3" come with spacers and aal or blocks?the c/o r not included in that lift?dont understand what u r getting.
  6. Apr 4, 2009 at 10:23 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    What is your goal in lifting?? Looks or Offroad performance?? Budget?
    The Revtek spacer kit isn't needed if you are getting coilovers(for offroading)...or coilovers aren't needed if you are going to use a spacer kit like the revtek kit (for looks and not offroading).
    You'll get 3 inches from the spacer or from the coilovers (provided you get the right ones) in the front..and the 5100 shocks will go nicely with that.
    UCAs are also a good idea if you are going to 3 inches of lift. (Total Chaos and Camburg are the two most highly recco'd ones around here I think..Light racing is also recco'd often.)
    The rear AAL with extended shocks in the back is a good call too. May want to think about extended brake lines in the back at least. There may be some shim kits and drop mounts you could need if you have vibrations or angle issues...but you need to install the light first and then decide if you need the extras.
  7. Apr 4, 2009 at 10:23 AM
    T-rev
    T-rev Resident Mall Crawler
    Tempe, AZ
    2017 TRD Offroad
    I'm kinda confused to, my Revtek came with the 3" spacers and I had a choice for AAL's or Blocks in the rear
  8. Apr 4, 2009 at 11:11 AM
    Jonny U
    Jonny U [OP] Member
    Phoenix
    07 Tacoma Sport
    All great suggestions. It answered alot of my questions, because I don't know much about lifts at all. Still trying to learn. Will the Revtek lift still be good for occasional offroading? I am going more for the looks, but want the option to go offroading once in awhile.
  9. Apr 4, 2009 at 11:14 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    The spacer lift will work off road...Go with an AAL in the back. You will have a rougher ride than stock or with coilovers...but it's doable.
    If you go offroad with any regularity it's worth it to go with OME shocks and springs, or adjustable coilovers.
  10. Apr 4, 2009 at 1:34 PM
    yosh2000
    yosh2000 Well-Known Member
    Denver, CO
    '17 Tundra CM 5.7
    if your simply going for looks, i suggest you go w/ the front and rear bilstein 5100s from downsouthmotorports.com. it will give you up to 2.5" up front and give you tuned shocks for less than $300. and they will be good for occasional offroading....
