Are these the correct parts to regear?
Discussion in 'Performance and Tuning' started by austinramsay, Sep 15, 2012.
  1. Sep 15, 2012 at 8:22 PM
    austinramsay
    austinramsay [OP] Well-Known Member
    Austin
    Yuma, Arizona
    2001 Tacoma TRD Doublecab
    Decided to regear to 4.88s with the help of my auto teacher at school. I just want to make sure this is everything i need and these are the correct parts for my 1996 4wd non locker taco. Does everything look good? I was a little confused about the Non-ELD gears, that means non electronic locking differential right?
    Gears:
    http://eastcoastgearsupply.com/i-126915-nitro-8-4-tacoma-t100-rear-non-eld-ring-and-pinion.html
    Install kit:
    http://eastcoastgearsupply.com/i-126923-toyota-tacoma-t100rear-install-kit-mini.html
    Gasket:
    http://eastcoastgearsupply.com/i-7185269-toyota-8-lubelocker-gasket.html
  2. Sep 15, 2012 at 9:26 PM
    TherealScuba
    TherealScuba Sober Member
    Stephen
    Austin, Texas
    99 Single Cab 4x4
    Yes, Non ELD means non e-locking diff.
    Gears are correct.
    Get the master install kit. Best to replace the bearings while your in there.
    http://eastcoastgearsupply.com/i-126921-toyota-tacoma-t100rear-install-kit-master.html
    That gasket is not for the Tacoma diff. Use ultra-grey permatex RTV.
    Don't forget the front diff gears and master install kit.
    http://eastcoastgearsupply.com/c-61...er-gears-toyota-toyota-7-5-tacoma-ifs-hp.html
  3. Sep 15, 2012 at 11:41 PM
    austinramsay
    Austin
    Yuma, Arizona
    I would get the install kit but dont have the money for it. Is that ultra-grey stuff like a paste kind of gasket? Oh and I'm not doing the front yet either, so no 4wd for a little bit :(
  4. Sep 16, 2012 at 12:40 PM
    austinramsay
    Austin
    Yuma, Arizona
    Bump! So i can use that RTV stuff as a gasket?
  5. Sep 16, 2012 at 12:48 PM
    TherealScuba
    Stephen
    Austin, Texas
    99 Single Cab 4x4
    Yes. Plenty of people, myself included, use RTV on front and rear diffs with no issue.
  6. Sep 16, 2012 at 1:10 PM
    austinramsay
    Austin
    Yuma, Arizona
    Cool thanks! That install kit says it comes with a gasket, but its not in the picture. So im not sure if i need to get some RTV or not, guess ill wait for it to arrive and see. I just ordered everything :)
    Edit: Also for the gear oil, just use the factory recommended 75w-90?
  7. Sep 16, 2012 at 1:52 PM
    TherealScuba
    Stephen
    Austin, Texas
    99 Single Cab 4x4
    Even if it does come with a paper gasket, throw it out.
    They aren't worth a shit and will leak eventually.
    75-90 is fine.
  8. Sep 16, 2012 at 6:55 PM
    austinramsay
    Austin
    Yuma, Arizona
    Thanks for helping me out man :)
