are trd sport and off road lugs and tpms interchangeable?
Discussion in 'Wheels & Tires' started by GeauxTigers, Aug 9, 2012.
  1. Aug 9, 2012 at 4:12 PM
    GeauxTigers
    GeauxTigers [OP] //TRD
    Caleb
    Sterlington, Louisiana
    '14 TRD DCSB Off-Road 4x4
    265/70/17 BFG KO2/17"x7" Pro Sema Wheels/OME 884/Bilstein 5100 front & rear/HeadStrong 1/4" TP spacer/Deaver 1.5"-2" AAL/Mud-Flap delete/Westin Bed mat/UltraGauge/ WeatherTechs/AFE Pro Dry Drop in Filter/debadged/AVS in-channel window visors/color-matched OEM grille/Kicker 6.75" Components in front door/Alpine KTP-445U power pack behind factory head unit/
    as the title states..im probably about to pick up some sport wheels for my off road and was curious if they used the same lugs and tpms thanks!
  2. Aug 9, 2012 at 7:12 PM
    Large
    Large Red
    Tpms - yes. Lugs, not sure.
  3. Aug 9, 2012 at 7:18 PM
    jandrews
    '09 FourDubDee TRD OR
    Lugs are all the same, 12mmx1.5 thread size.
    They are a bit of a pest in that they are technically mag seat with washers so finding aftermarket lugs can be difficult. If you're staying with the OEM stuff though, should work fine.
  4. Aug 9, 2012 at 7:27 PM
    tomwilson74
    tomwilson74 Well-Known Member
    Tom
    West Virginia
    2020 TRD double cab OR
    OME 3” lift Mickey Thompson Classic III Wheels
    I just had 4 Toyota spare tire type steel wheels put on my Tacoma today. The lugs on the original wheels would not fit on the steelies. Had to get 24 new ones. What's up?? What if I had a flat out on the road, the lugs won't work on the spare tire?
  5. Aug 9, 2012 at 7:33 PM
    jandrews
    I imagine they would, they'd just look odd.
    You might notice at the end of the shank of the OEM lugs, there is an angled seat. This allows the lugs to work with most aftermarket tires that require and angled seat as well as the OEM tires with mag seats.
