Are we Hub Centric or Lug Centric???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by erock, Feb 19, 2008.
  1. Feb 19, 2008 at 2:11 PM
    erock
    erock [OP] Well-Known Member
    Boise
    06 TRD OR Tint Window, Magna Flow 2.5 Catback, TRD CAI, 3" Revtek and TSB, 33" Toyo MTs
    Cig Lighter Will tackle the Rear Locker Always On soon
    Trying to get some new ProComp wheels and need to know cause' there's two different part numbers with the same specs except for the Bolt Circle.
    I thought only Chevy's were Hub Centric...
  2. Feb 19, 2008 at 2:43 PM
    nd
    nd Radical Town. It's a hell of a place!
    Nate
    Greenville, SC
    07 TRD Off-Road 4x4 debadged
    De badged, 5100's, Black Toyota Baja wheels
    i do believe we are hub centric
  3. Feb 19, 2008 at 2:52 PM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    I'm running ProComp lug centric wheels on my '06.
  4. Feb 19, 2008 at 2:53 PM
    mjp2
    NJ
    Don't mean to steal your thunder ndcouch, but at least you got to add to your post count. ;)
  5. Feb 19, 2008 at 6:18 PM
    hokihigh
    hokihigh Active Member
    Tacoma's are lug centric. At least thats what I read.
    hoki
  6. Feb 20, 2008 at 6:39 AM
    nd
    Nate
    Greenville, SC
    From what i understand our factory wheels are hub centric with a bore size of 106mm. most manufactures have a bore of 108mm, so most rims are made to fit that size. So you will need a spacer if your aftermarket rim is 108mm and i have heard alot of people complain about keeping these wheels balanced and aligned due to the size difference. most of your aftermaket choices will be lug centric
  7. Feb 20, 2008 at 6:54 AM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    don't worry about couch, he's egocentric
  8. Feb 20, 2008 at 7:00 AM
    mjp2
    NJ
    I almost spit out my coffee when I read this. Well played! :laugh:
  9. Feb 20, 2008 at 8:15 AM
    nd
    Nate
    Greenville, SC
    i'm also narcisistic, vain, concieted and full of myself.
  10. Feb 20, 2008 at 8:19 AM
    mjp2
    NJ
    So you've got that going for you, which is nice. :D
  11. Feb 20, 2008 at 8:46 AM
    nd
    Nate
    Greenville, SC
    yeah, i've got all that, plus i drive a Taco, so i'd say i'm pretty much set :)
