Are wheel clearances the same between a 4wd, a prerunner, a TRD off road if they are all "leveled"
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PapaGrizz, May 15, 2019.
  1. May 15, 2019 at 8:07 PM
    PapaGrizz
    PapaGrizz [OP] Active Member
    2010 DCSB 4X2 On Road
    3" front 1" rear. Method NV 17s
    I have a plain old prerunner with a 2 inch spacer up front and 1 inch block in back. It's level but when I look at other trucks' wheel tire combos I don't know it they compare if they are 4wd or have the off road package. Any way to know without busting out the tape measure on a stranger's ride?
  2. May 16, 2019 at 12:25 AM
    IwasDacapsterAz
    IwasDacapsterAz Well-Known Member
    Cap
    14 4w4 Taco Access
    Bamf and Bilstien
    pre-runners are always taller....
  3. May 16, 2019 at 9:18 AM
    PapaGrizz
    Yeah I get that a prerunner is taller than a regular 2wd but is a stock prerunner comparable in height to a stock 4wd? Is a 3 inch lift prerunner the same height as a 3 inch lift on a 4wd? Assuming same size tires.
  4. May 16, 2019 at 2:16 PM
    Fitz235
    Fitz235 Well-Known Member
    Rob
    New Hampshire
    Black '22 DCSB TRD Offroad 4WD
    - TRD T4R Pro Wheels - TRD Lift Kit - TRD Skid Plate - 265/70/17 Toyo Open Country 3's - OEM Bed Lights - OEM Bed mat - Alpharex Tail Lights - TacomaBeast LED Interior Lights - Green Lane Offroad Aluminum Sliders - Place Holder for More Bad Financial Decisions...
    Most stock 6 lugs of any trim, measure ~20" front, 22" rear when measuring from center of hub to bottom of the fender. Measuring using this method, takes the variable of different height tires/wheels out of the equation.
    Take the guess work out of it, and go measure.
    Sidney Vicious likes this.
