Are you using 5 and half quarts when doing oil change 4.0 V6?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by blazze2005, Jul 25, 2016.
  1. Jul 26, 2016 at 4:32 AM
    Shibbyjeep
    Shibbyjeep Well-Known Member
    Trent
    Greenville SC
    2014 Tacoma DCSB TRD OR
    Here's the official info provided via toyota to our fluid capacity info for an 05 4.0
    And why is it so many of you 2015 guys have been changing your own oil? Did you not get 2 years or 25k free maintenance? Or did you guys just already out drive the freebies?
    I'm rolling over 35k this week and finagled the dealer into giving me 2 more oil changes.
    yotaTom likes this.
  2. Jul 26, 2016 at 4:40 AM
    dtopgun515
    dtopgun515 Well-Known Member
    Darrell
    Hey Yall Georgia
    13 TRD Sport
    5100's up front set to 1.75, SCS Stealth 6 wheels, Nitto Terra Grappler AT's
    I out drove the freebies in one year! I can never tell where the oil is on my dipstick no many how many times I pull it out and wipe the oil off and then try again. I always just put a little more than 5 quarts not sure of exact amount since the manual says 5.5 I just do my best guesstimate.
    Shibbyjeep[QUOTED] likes this.
  3. Jul 26, 2016 at 5:22 AM
    ColoradoTom
    ColoradoTom Team Velveeta™
    Colorado
    2014 Tacoma 4x4 Access Cab
    Yep. I just changed, rolled the truck into the garage fully hot, dropped the oil and pulled old filter and then went to have a sandwich so it drained as much as it could. Added the 5 qt Mobil1 jug. Not even half way down to the low dot. Unless your truck is using oil, there's no reason to make sure it's full right to the top dot. I absolutely hate to have my oil overfilled. I've brought it home and drained a little after having someone else change it and overfill because they just blindly put in 5.5. Would way rather have it a smidge below the full dot than a smidge above it. And would rather not have to buy a 5 and a quart then keep track of the half quart for 6 months until the next change.
  4. Jul 26, 2016 at 5:42 AM
    timothom
    timothom Well-Known Member
    2014 Tacoma Access cab sr5
    Kenwood DMX7705S PrecisionPower Phantom 900.4 Alpine type-r 8" Image Dyanmics CXS64.2
    I thought the tow package oil cooler was for the trans only. There's an engine oil cooler with it too?
    svocobra likes this.
  5. Jul 26, 2016 at 6:04 AM
    edm3rd
    edm3rd Well-Known Member
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    hard tonneau,scangauge
    Yes all v6's with tow pkg have an engine oil cooler. Two lines connect at oil filter base.
    The v6 listed above stating 4.8 is the X-Runner. Chart is incorrect in what is labeled "4.0L engine, 4wd" should be 4wd and PreRunner. the X-runner has a different oil pan while 4wd and Pre-Runner have the same (deeper) pan.
    yotaTom likes this.
  6. Jul 26, 2016 at 6:14 AM
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    Damn I added 6 qrts. Time to drain some oil out.
  7. Jul 26, 2016 at 6:54 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I would rather change my own oil, its more of a pain to let the dealer do it even though it would be free.
  8. Jul 26, 2016 at 6:58 AM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
    5qts puts just under top mark with YZZD3 filter. So to make life easy I use 5qts. That's with factory tow package as well.
  9. Jul 26, 2016 at 7:10 AM
    jtweezy
    jtweezy Well-Known Member
    Austin
    2014 4X4 DCSB OR V6
    I could be wrong, but I believe it's both the tranny and engine oil that get coolers. Tow package from what I remember is engine oil cooler, trans fluid cooler, high output alternator, hitch, and 7-pin connector.
  10. Jul 26, 2016 at 7:13 AM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    5.5 quarts here each & every time.
    shakerhood and svocobra like this.
  11. Jul 26, 2016 at 9:00 AM
    blazze2005
    blazze2005 [OP] Well-Known Member
    South Jersey
    05 Tacoma Pre-Runner Sport
    Fuel Off-Road Octane Wheels,Yokohama Geolander ATS 265/65/17.Grillcraft,Borla Exhaust,Truxedo Lo Pro Tonneau Cover,Pop n Lock Tailgate Security,Custom Wet Okle TRD Seat Covers,Catch-All Matts,Gatorback Belt,Shorty Antenna,Toyota Bed Matt,Sirius Radio,Vent Sades,20% Lumar Window Tint
    I will stick with my 5 quarts 10 ounces
  12. Jul 26, 2016 at 9:04 AM
    ColoradoTom
    Colorado
    Do you pull the stick and check when you're done?
    After ARB1977 posted about his 6 quarts it got me thinking; how many people just pour in the amount that the manual (or TacoWerld or whatever) says is the capacity and then call it done and shut the hood? I was taught how to do oil changes by my dad, and the last thing to do was always to pull the stick and see what the engine actually got.
    Who checks after and who doesn't? And why?
    bobsuruncle likes this.
  13. Jul 26, 2016 at 9:11 AM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Try this... scuff the dip stick area between the 2 marks with some sandpaper to etch it. When checking the level remove the stick and wait around 10 minutes before reinserting... lets the oil you dragged up the tube with the stick time to drain back down.
    dtopgun515[QUOTED] likes this.
  14. Jul 26, 2016 at 9:11 AM
    TACO TX
    Kelly
    Denison ,Texas
    The first change in my 15' I did not check and put 5.5qt in. After starting and checking it was a 1/4" above the top mark. 5.5 is what I always put in my 03' 3.4l. I should have started with 5qt and adjust if needed on the 4.0l.
  15. Jul 26, 2016 at 9:16 AM
    #35
    3coma
    3coma my kid says my truck is "Boss"
    rob
    19 dcsb sport cement 4x4
    I need to scuff my dipstick more than I already have. I still can't read the damn thing hot or cold.
  16. Jul 26, 2016 at 9:27 AM
    #36
    OdinBow
    OdinBow Just an idiot out wandering around CO.
    Mitch Cumstein
    Erie, CO
    2011 Timberland Mica T|X Pro
    None, but willing to learn.
    I always check because I'm human and I like beer.
    12TRDTacoma, dtopgun515 and xJuice like this.
  17. Jul 26, 2016 at 9:44 AM
    #37
    Spintly
    Spintly Well-Known Member
    Greg
    Home of the Groundhog
    85 Single Cab Pickup & 2000 911
    When I bought my 06, I checked the dipstick after adding 5 qts and it was between the marks and closer to full. Waited until the day after to check it. Closed the hood and been using 5 qts for 9 years...
  18. Jul 26, 2016 at 9:46 AM
    #38
    Mad Man Marty
    Mad Man Marty Well-Known Member
    Marty
    PA
    2007 Tacoma SR5 TRD Sport
    6speed, TRD intake, bed tie downs, weathertech rear,Tint
    I fill mine until the oil hits the top full mark.
  19. Jul 26, 2016 at 9:47 AM
    #39
    TACO TX
    Kelly
    Denison ,Texas
    Just pull out, wipe off and wait a few minutes. Insert and will be easily readable.
  20. Jul 26, 2016 at 9:53 AM
    #40
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    5.25 here.
    Oil/filter change, start and check to ensure there's no random leaks, let settle and check the dipstick.
