Are you using 5 and half quarts when doing oil change 4.0 V6?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by blazze2005, Jul 25, 2016.
  1. Jul 26, 2016 at 10:02 AM
    #41
    MarineBob
    MarineBob Well-Known Member
    Bob
    Massachusetts
    2024 TRD Sport Long Bed
    Step bars coming
    My wife's 2008 Lexus takes 6.7 qts. I pretty much change both oils at the same time so its convenient to split 2 six packs of oil, kind of rounding each to like 6.6 and 5.4. That gets each one to just about at the full line so it works out well. I can't read the dip stick with clean oil in either vehicle. Maybe Toyota could put a different finish on the stick where the oil level resides? Might cost them 25 cents but it would be worth it
  2. Jul 26, 2016 at 10:04 AM
    #42
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    I add 5.3 quarts. I know that oil always remains even when I let it drain for 30 minutes. Some Synthetic oil "sticks" to the engine so I figure I offset it that way. Haven't had a problem, and it always falls dead center on the dipstick ( granted the dipstick is very inaccurate anyhow)
  3. Jul 26, 2016 at 10:08 AM
    #43
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    5 quarts and then eyeball about 1/2 another quart. You don't have to be that accurate. A few ounces either side of that won't matter.
  4. Jul 26, 2016 at 10:11 AM
    #44
    knayrb
    Bryan
    Pure stock
    You're just fine. I've done that a few times and it won't hurt a thing. 7 quarts maybe but 6 is fine.
  5. Jul 26, 2016 at 11:34 AM
    #45
    Sidponcho
    Sidponcho Well-Known Member
    Dan
    I'll be going to my dealer next week for my last "included" oil change.
    It's on the way to work.
    Free WiFi
    Free cooked-to-order breakfast
    After this, I'll start doing my own oil changes and fill it up based on the dip stick
  6. Jul 26, 2016 at 2:12 PM
    #46
    edm3rd
    edm3rd Well-Known Member
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    hard tonneau,scangauge
    Your dealership is inside of a restaurant ????
  7. Jul 26, 2016 at 2:19 PM
    #47
    kirkofwimbo
    kirkofwimbo Well-Known Member
    Clayton
    Wimberley, TX
    ‘21 Tundra SR 4x4
    Agree with this. I don't even check the dipstick.
  8. Jul 26, 2016 at 2:20 PM
    #48
    1Shifter
    1Shifter Well-Known Member
    Jeff
    Outta the black and into the blue
    09 PreRunner
    Same as everybody else...
    I use a single 5 qt jug when I change the oil and filter. Puts the oil level on the dipstick between the two dots. I check my oil once a week at every fill up, no problems.
  9. Jul 26, 2016 at 2:26 PM
    #49
    DaveInDenver
    DaveInDenver Not Actually in Denver
    David
    Grand Junction
    2008 Super White TRDOR AC 6MT
    Unexceptional
    Same here and check the dipstick the next morning to verify it's around the top dipstick mark. In the end it balances because the remaining half is dumped in on the next change so if I was a little under the next time it's a little over.
  10. Jul 26, 2016 at 3:17 PM
    #50
    4x4Taco09
    4x4Taco09 Well-Known Member
    Dane
    Louisiana
    09 TRD Sport 4x4 BSP DC LB
    Kings, Deavers, Brute Force, Prinsu, Lights, all the stuff
    5.5 for me. After it stops draining for the first time, Ill start the truck and let it run for about 2 seconds then kill it, you'd be surprised how much oil is left in the engine after doing this. After that, put the plug in and 5.5 on the dot for me
    I also put the .5 quart bottle in a gallon zip lock and put it in one of my bed cubbies for the next oil change ;)
  11. Jul 26, 2016 at 4:12 PM
    #51
    MarineBob
    Bob
    Massachusetts
    Step bars coming
    I guess the Toyota dealers offer a few perks. At the Lexus dealership, they have TV's at the urinals. Amazing country. What'll they think of next?
    TexasWhiteIce likes this.
  12. Jul 26, 2016 at 4:17 PM
    #52
    SilverBullet19
    SilverBullet19 Well-Known Member
    Scott
    Sacramento County
    2015 DCLB Prerunner TRD Sport
    It varies by engine and every oil change.
    If you throw the plug back on after just a few minutes, it'll probably only take 5 quarts because it didn't drain completely. So if you take it to an oil change shop, bet on them using 5 quarts and seeing it full on the dipstick.
    If you do it at home, you'll probably take 5.5 quarts. That's because you remove the drain plug and leave for 15-20 minutes to have a beer, thus allowing all the oil to drain.
    In summary, beer helps you complete a more thorough oil change.
    ColoradoTom and shakerhood like this.
  13. Jul 26, 2016 at 5:36 PM
    #53
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    straight from Toyota... the 5.5 amount called out is reference quanity
    *: The engine oil capacity is a reference quantity to be used when changing the engine oil. Warm up and turn off the engine, wait more than 5 minutes, and check the oil level on the dipstick.
    yotaTom likes this.
  14. Jul 26, 2016 at 7:29 PM
    #54
    jtweezy
    jtweezy Well-Known Member
    Austin
    2014 4X4 DCSB OR V6
    I pour in just shy of 5qts and then start checking/adding/checking/adding. When I'm close I shut everything, start it for a few seconds and shut it off and check again. This starting seems to give me a clearer reading. Then I top off if necessary.
  15. Jul 26, 2016 at 7:45 PM
    #55
    LiveFreeOrDie2015
    LiveFreeOrDie2015 Well-Known Member
    York PA
    15 DCSB TRD OFFROAD
    3in lift,Fox suspension,chaos UCA,AAL,leer 180 topper,SilverStar zXe headlights & fog lights,BAMF kickout sliders,Mobtown full skids,Pelfreybuilt center hoop, Pelfreybuilt Gas Tank Skid,50" curved LED light bar, Hood scoop LED, Tran cooler and fan,Oil Catch can,LED Strip lights under hood & Bed,
    I just fill it until I see the oil at the top for fill tube and then reinstall the 710 cap. Your truck will burn off what it doesn't need.:anonymous:
    5.5 gets me right to the full level
  16. Jul 26, 2016 at 8:00 PM
    #56
    sr57e
    sr57e Well-Known Member
    Alex
    Dallas, TX
    05 preRunner
    Motor: k&n intake -Wheels: xd wheels/ dynopro 265/70/17 -Front: icon LT coilovers w/ camburg uniball UCA -Rear: Weavers HD, Icon 2.0r soon: 4.56 gearing/ arb / dual compressor
    its really not a big deal to run 5.5 quarts even if its "over" full line. you also got to understand under load oil shifts and unless your baffles are insanely good, you can starve the motor out. chances are you are not doing much of that (happens a lot drifting etc) so running even a quart over is not going to hurt anything. now, dont go crazy with more than 6 imho, its detrimental.
    btw, i run 13 quarts in my 5.7 drift car with front oil cooler and 3 quart accusump. oil chage is a mother there...
  17. Jul 27, 2016 at 7:32 AM
    #57
    boomer6
    boomer6 Well-Known Member
    TN
    Tacoma TRD Offroad
    disabled DRLs disabled seat belt chime disabled the key in the ignition with door open buzzer Installed Illuminated 4wd switch circuit board Marker lights Flashing with turn signals Toggle switch ABS Disable Fog Lights on AnyTime Mod Changed to Yellow bulbs in the Fog Lights Converted interior lights to leds Installed oem roof rack Installed Firestone Ride Rite Air Bags and Daystar Cradles for the air bags Added oil catch can Relentless Tailgate Protector installed
    5.5 qts each time
  18. Jul 27, 2016 at 11:59 AM
    #58
    TexasWhiteIce
    Texas
    Lol, for "alone" time at the dealership
  19. Jul 27, 2016 at 12:01 PM
    #59
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    I check ( Dad taught me too) but damn our dipsticks suck, almost to the point of being useless.
    yotaTom and dtopgun515 like this.
