ARP Hub Stud Question
Discussion in '1st Gen. Tacomas (1995-2004)' started by bigwill837, Feb 13, 2017.
  1. Feb 13, 2017 at 1:23 PM
    bigwill837
    bigwill837 [OP] Well-Known Member
    Will
    Austin, TX
    1996 HZJ75 Land Cruiser Pickup
  2. Feb 13, 2017 at 1:34 PM
    BamaToy1997
    Bill
    Navarre, FL
    Those are the manual hub stud and centering pin with nut kit. Basically replaces the original hub mounting bolts. Should have no problem fitting your truck if it has manual hubs. Why are you replacing the original ones?
  3. Feb 13, 2017 at 1:45 PM
    bigwill837
    Will
    Austin, TX
    I'm going to swap out to some refurbished and powder-coated Aisin hubs, and I was going to upgrade the studs while I had it all apart.
    BamaToy1997[QUOTED] likes this.
  4. Feb 13, 2017 at 2:41 PM
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    Only one way to find out!
