Ask the Electrician
Discussion in 'Off-Topic Discussion' started by Alexb03, Jan 6, 2012.
  1. Jan 29, 2018 at 11:13 AM
    #241
    cory02taco
    cory02taco Well-Known Member
    Cory
    Maine
    2013 trd super sport
    Here ya go. Section f from the 2017 nec has gotcha covered.
    Edit: section (A)1 is really the correct one, but it says the same thing
  2. Jan 29, 2018 at 12:00 PM
    #242
    Dimestore55
    Dimestore55 Well-Known Member
    William
    Richmond, VA
    2016 TRD OR 4x4 DCSB
    I knew it, thanks :thumbsup:
  3. Jan 29, 2018 at 12:03 PM
    #243
    Dimestore55
    William
    Richmond, VA
    Thats pure artistry right there, it should be in the Louvre.
  4. Jan 29, 2018 at 12:34 PM
    #244
    CurtB
    CurtB Old Timer knowitall
    Curt
    Kansas
    2010 Tacoma SR5
    Here's one for you electrickity guys. My shop has 6, 4 bulb, 4' florescent lights.They are probably 25 years old. For the last 5 years or so, when the humidity gets higher than about 50% some of the lights don't come on. Some no bulbs light, some 2 and sometimes all. The temperature in the shop does not matter. Cold or hot, if the humidity is high, no worky.
    Here's the kicker... if I use a propane torch to heat them up, the lights will come on after a minute. If I light my weed burner torch they will come on fairly quickly. Just letting the heat ride up, not roasting them. So if it's humid and I want full light, it's a pita.
    Things I've tried: cleaning the bulb pins and sockets.
    tin foil between the bulb and reflector
    ran a temp ground wire from a fixture to the ground rod outside
    new bulbs
    A couple sparkys I know were stumped, they said buy new lights. Well screw that!
    Again, it's the humidity that seems to cause the problem, not the temperature.
    Thanks for any suggestions you may have, I don't need to hear buy new lights. Although that may be the only fix. :(
    And to tag the smart guy I know on TW @Jimmyh
  5. Jan 29, 2018 at 12:41 PM
    #245
    Toyko Joe
    Toyko Joe Here for the pictures
  6. Jan 29, 2018 at 12:45 PM
    #246
    cory02taco
    Cory
    Maine
    Fixtures that old probably have t12 ballasts with starters. Toss them and replace with t8's, or do LED retrofits. You'll save on energy bills and have more light
    Toyko Joe likes this.
  7. Jan 29, 2018 at 12:58 PM
    #247
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    The ballasts do not have starters. I do have some spare ballasts. I am retired, I don't spend a lot of time in the shop. Back in the day, yeah many late nights, being self employed.
  8. Jan 29, 2018 at 1:00 PM
    #248
    Toyko Joe
    LED conversion is worth it!! We did a conversion here in my office... Paid for itself already, in parts, labor and utility bill!
  9. Jan 29, 2018 at 1:02 PM
    #249
    Toyko Joe
    Check to see if the GFCI is tripped or had a Red instead of Green light, if green light --> problem with the welder, if Red light --> GFCI.
    cory02taco likes this.
  10. Jan 29, 2018 at 1:13 PM
    #250
    cory02taco
    Cory
    Maine
    I work in the electric shop on a college campus. We have been converting to led for a few years now (we've got some 200 buildings). A lot of times we replace 30-50 year old ballasts that are hot as a pistol when you take them out. It's definitely worth the swap.
  11. Jan 29, 2018 at 1:14 PM
    #251
    cory02taco
    Cory
    Maine
    If it didn't trip a gfci or a breaker check the receptacle it was plugged into. It may have melted the contacts causing everything downstream to be dead.
  12. Jan 29, 2018 at 1:20 PM
    #252
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    Um, that’s not even legal. lol
  13. Jan 29, 2018 at 1:33 PM
    #253
    Toyko Joe
  14. Jan 29, 2018 at 1:38 PM
    #254
    cory02taco
    Cory
    Maine
    What, the tie wraps or the MC?
  15. Jan 29, 2018 at 2:53 PM
    #255
    cory02taco
    Cory
    Maine
    Did you take it out of the wall?
  16. Jan 29, 2018 at 3:26 PM
    #256
    moondeath
    Pa, Gardners
    Thats not MC. That’s just flex tied down with tie wire run by a bunch of unskilled idiots that don’t know how to run pipe.
  17. Jan 29, 2018 at 3:38 PM
    #257
    cory02taco
    Cory
    Maine
    Looks like big gauge mc to me. I helped wire an arena and convention center with it. We had it as big as 250kcmil compact aluminum.
  18. Jan 29, 2018 at 3:44 PM
    #258
    moondeath
    Pa, Gardners
    Look at the connectors. Those are flex connectors, not MC connectors.
  19. Jan 29, 2018 at 3:49 PM
    #259
    tacoburrito
    tacoburrito Well-Known Member
    boston
    2013 regular cab
    5100s. eibach coils. 285/75/16 km2s. leer cap
    Never seen mc connectors that big. Have always used flex connectors. Think about flex vs mc. No way would you by flex and run lengths like that and try and pull wire into it
  20. Jan 29, 2018 at 3:49 PM
    #260
    wirenut
    wirenut I like this place
    Andrew
    NH
    98’ T4R
    OME/5100 - 300lb 3.5” loft setup Prinsu 3/4 rack
    Kind of blurry when you zoom in, i’d call it flex.
