Ask the Electrician
Discussion in 'Off-Topic Discussion' started by Alexb03, Jan 6, 2012.
  1. Feb 5, 2012 at 11:39 AM
    #41
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    Would the wall buzzing when i turn on the lights (only in one room)
    be a bad indicator? It is an dimmer switch connected to a ceiling fan
  2. Feb 5, 2012 at 11:44 AM
    #42
    Saskquatch11
    Saskquatch11 TRUCK YEAH
    does the dimmer switch control the fan and the light or just the light?
  3. Feb 5, 2012 at 11:47 AM
    #43
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    How come my garage light won't come on when it's been raining / very humid out? Comes on just fine when the weather is nice.
  4. Feb 5, 2012 at 11:48 AM
    #44
    StaticFilter
    StaticFilter Well-Known Member
    Cedar Hills, UT
    2008 Blue FJ Cruiser
    Lifted, N-Fab steps, Roof rack light bar, Grill guard, Volant Snorkel (not installed ye)
    Buzzing COULD indicate arcing which can lead to a fire. I would turn the breaker off and take the switch apart to make sure the connections are tight. Make SURE to test the switch with a non-contact voltage tester to verify the circuit is off so you don't get shocked, otherwise have a qualified individual check it out. If connections appear tight, try replacing with a different switch, the internals on the dimmer could be wearing out and arcing
  5. Feb 5, 2012 at 11:48 AM
    #45
    Saskquatch11
    :notsure:
  6. Feb 5, 2012 at 11:50 AM
    #46
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    Will do thanks!
  7. Feb 5, 2012 at 11:52 AM
    #47
    StaticFilter
    Cedar Hills, UT
    Do you know if the garage light is the only thing on that particular circuit breaker? If other devices are on the breaker and work fine, you may be getting water in your light fixture, you could try replacing the fixture or at least opening it and checking for signs of moisture Make sure to turn power OFF first by shutting off the breaker
  8. Feb 5, 2012 at 12:00 PM
    #48
    Saskquatch11
    G scott04 ^^^
    if the fan shuts off with the dimmer switch you should replace the dimmer with a regular single pole switch. a dimmer switch is not a fan speed control and should not be used as such, also not all fans are compatible with fan speed controls. if the fan does not turn off with the dimmer I'd just check to make sure you don't have a loose connection anywhere. incandescent lamps hum when dimmed, not much you can do about that.
  9. Feb 5, 2012 at 12:00 PM
    #49
    ImpulseRed008
    Susan
    SC
    As far as I know, it's the only thing, but I'll check it out thanks
  10. Feb 5, 2012 at 12:04 PM
    #50
    Saskquatch11
    are we talking about an inside or outside light?
  11. Feb 5, 2012 at 12:06 PM
    #51
    ImpulseRed008
    Susan
    SC
    Inside the garage - a 4' fluorescent tube light... Sometimes I can get it to come on if I flip the switch a dozen or so times :eek: other's it won't come on.
  12. Feb 5, 2012 at 12:14 PM
    #52
    Saskquatch11
    is this an old fixture with tubes about 1 1/2" in diameter (T12) with a large (partially melted) magnetic ballast? if so the ballast is probably shot. T12 fixtures have slowly been getting phased out and you may have difficulty finding a replacement ballast. you'd be further ahead to get a T8 fixture as they have a more reliable electronic ballast and are more efficient than T12 fixtures.
  13. Feb 5, 2012 at 12:16 PM
    #53
    ImpulseRed008
    Susan
    SC
    This one is 9 1/2 yo. I've been thinking about replacing the thing anyway, so guess I'll do it sooner rather than later. Don't know what bulbs are in it
  14. Feb 5, 2012 at 12:20 PM
    #54
    Saskquatch11
    T12 tubes are about 1 1/2" in diameter, T8 tubes are about 1" in diameter.
  15. Apr 10, 2012 at 10:28 AM
    #55
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    So last weekend we had some storms roll through and I believe part of my house or something very near by was hit by lightning. I didn't experience anything inside as I was outside drinking a beer watching the storm at the time :laugh:. So various electrical components around my master bed and living room either no longer work at all, or are handicapped in some way after this event. On to the electrical. The master bed plugs breaker was the only one that got flipped. Turn it back on ... all outlets lights, etc. around the house work fine. My father-in-law recommended I get an electrician out to check out all the electrical system and make sure it's all good. I'm not too fond of this idea because: A) I think if all wires and such are connected and work and power everything then it's all good do go right? and B) who knows how much that will cost on top of the equipment I have to replace. (probably won't be enough to warrant a home owners claim)
    What is there that I should be looking at that could possibly be damaged? Only thing I could think of is something in the breaker panel.
  16. Apr 10, 2012 at 10:58 AM
    #56
    Yota Toy
    Yota Toy Taco Sauce
    FX retros, Blazer fog-light retro, JVC KW-NT30HD head unit, Pioneer 6X9's in front doors, Pioneer 6.5's in rear doors, two Pioneer 12" subs in sealed boxes, Sony X-Plod amp, Hidden Hitch trailer hitch, EGR window visors, two PIAA low-tone horns, Westin light bar with two 100-watt KC low profile driving lights.
    Was the bear happy about this?
  17. Apr 10, 2012 at 11:02 AM
    #57
    xJuice
    Josh
    N. Texas
    19 Tundra MGM
    quite
  18. Apr 10, 2012 at 3:36 PM
    #58
    StaticFilter
    Cedar Hills, UT
    Here are some cheap but effective tools you can use to help diagnose an issue. You could have lost a neutral somewhere in the system...
    Simple meter to check voltage, stick one lead in the hot, one in the neutral of a plug, you should read 110-120volts or somewhere close to it., repeat by placing one l;ead in the hot and one in the ground hole. Plug Tester Plug this into an outlet and read the light codes to see if it's good to go. Voltage tester This will tell you if there is power in a wire, light, outlet, etc... Circuit Breaker Finder Use this tool to figure out what breaker controls what light or receptacle instead of randomly flipping them These are simple easy to use tools, these are cheaper ones but still work fine, you can get higher end stuff
  19. Apr 15, 2012 at 7:58 PM
    #59
    I5runner
    I5runner Well-Known Member
    Ratha
    Belle Chasse
    13 DCLB
    See build page
    My detached garage is about 5ft away from my home, I would like to run 4 12/3 wires inside a 3" pvc conduit under ground to avoid having to use a sub panel in the garage. Is a sub panel required or can I save a few bucks and just run the 4 wires directly into the outlets and lights. My main panel is about 6ft from the garage if this matters.
  20. Apr 15, 2012 at 8:27 PM
    #60
    epa4wd
    epa4wd Well-Known Member
    Eduardo
    2019 SR
    Clazzio Seat Covers OR Wheels 40% tint Side Steps KC Fog Lights
    Looking forward for someone with experience to answer this, 3" PVC SCH X? is pretty big, I don't have the NEC with me but IIRC you can pass bigger wires than #12 on there if you would go about adding a sub-panel. Is a small panel say 8-10 slots really that much money? Not really sure if its needed or not, but for me I would just add a small sub-panel, just for having more options (maybe separating lightning from outlets or future things you might add, for example a 50A 240V circuit).
    How big is the detached garage??
