Ask the Electrician
Discussion in 'Off-Topic Discussion' started by Alexb03, Jan 6, 2012.
  1. Jul 22, 2012 at 11:54 AM
    #81
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    :thumbsup: thanks Squishy
  2. Jul 22, 2012 at 12:08 PM
    #82
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Ditto... That, and it can function as a "Joe Homeowner" lockout.
    When working on the circuit, slip the hoop over the handles and it'll prevent the wife from energizing it.
    Commercial electrical requires a physical lock and tag warning that the circuit is being worked on.
  3. Jul 22, 2012 at 12:15 PM
    #83
    ImpulseRed008
    Susan
    SC
    Or prevent the BOY FRIEND from energizing it :cool:
  4. Jul 22, 2012 at 12:20 PM
    #84
    Rich91710
    Rich
    Los Angeles
    08 Base
    True true....
    My wife used to build seeker heads for the Sidewinder missile.
    Today, she wouldn't be able to pick up a soldering iron without getting burned.
  5. Jul 22, 2012 at 12:23 PM
    #85
    Palooka
    Palooka Well-Known Member
    Brett
    Crescent Valley, BC
    09 TRD Sport
    Yeah, You see those a lot in commercial applications... IE. essential services like fire pumps or emergency phone systems.
  6. Jul 23, 2012 at 1:34 PM
    #86
    newfie8
    newfie8 Well-Known Member
    newfoundland
    09 tacoma
    Tinted windows all around. Fog lights. Intermittent wiper switch. Skid plate. Extra D rings. Grillcraft. Color matched grill. Hella 500ff HID behind grillcraft. Rcbs204 Lighting. 5100's up front. 265/75/16 Duratracs.Firestone riderites. Bora Wheel spacers. Tinted tails. De badged. Blacked out rims.
    Ok thanks guys I had to ask! Guess I'll run a new wire in there. Not a stranger to plastering so it won't be that bad.
  7. Dec 4, 2012 at 11:08 AM
    #87
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    I kind of have a dumb question. What makes, say an extension cord ok for outdoor use? What's the difference between one for outdoor use, and one only for indoor?
  8. Dec 4, 2012 at 11:16 AM
    #88
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    The insulation on the outdoor should be more durable to better protect from the elements. Also might have some resistance to oil and such.
  9. Dec 4, 2012 at 11:25 AM
    #89
    tls01taco
    tls01taco Well-Known Member
    Tanner
    Oklahoma
    2021 White TRD OR DCSB
    Sub'd
    apprentice in Oklahoma, learning the ropes!
  10. Dec 4, 2012 at 11:27 AM
    #90
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    That makes sense. Thanks.
  11. Dec 4, 2012 at 7:11 PM
    #91
    Rich91710
    Rich
    Los Angeles
    08 Base
    Don't fall for:
    Wire stretcher
    Conduit stretcher
    Wire bender
    Stud spanner
    And a "hickey" actually IS a tool ;)
  12. Dec 4, 2012 at 7:40 PM
    #92
    StaticFilter
    StaticFilter Well-Known Member
    Cedar Hills, UT
    2008 Blue FJ Cruiser
    Lifted, N-Fab steps, Roof rack light bar, Grill guard, Volant Snorkel (not installed ye)
    and don't fall for "chin nuts" :)
  13. Dec 4, 2012 at 7:49 PM
    #93
    Saskquatch11
    Saskquatch11 TRUCK YEAH
    ...and always keep a bucket near by to catch the volt drop.
  14. Dec 4, 2012 at 7:54 PM
    #94
    Gramps
    Gramps My walker is faster than your Prius!
    Gramps
    Colorado! Where else?
    07 TRD DC 4x4
    A small handful of select mods.
    Alright gents
    Looking to do a box upgrade from 100amp to 250amp this spring(2013). Looking for a solid reliable electrician to do this along with the other options I want to include in this upgrade. Located in the Denver area. PM me if you, or if you know someone that you would recommend here in Denver to do this work. My plan is to take 3 bids and weigh the options. Here is what I am looking to do:
    250amp box
    Sub-panel in the Garage with additional outlets and 220v outlet
    Exterior LED can lights under eves for security. Wired back to a timer switch
    Exterior quad outlet for gutter hot wire and Xmas lights
    Line conditioner/surge protector at box
    House was built in the 60's so original wiring is AL. I had an Alumiconn fix done when I bought but would like to pull back major rooms (I.E. Kitchen, bathrooms) in copper to box. Need some opinions on this. Is it really needed? How bad is AL wiring really?
    This is all I have considered so far. Shoot some holes in my plans and let me know what or what not I should really do. It is not something I can do myself but do not want to get screwed with the price. Based on the above work what am I looking at spending?
    Thanks in advance for the info.!
  15. Dec 4, 2012 at 8:07 PM
    #95
    Saskquatch11
    aluminum's expansion coefficient is higher than copper's. expands under load and contracts when the load is turned off. this can cause loose connections and arcing which can cause in a fire.
    this is a receptacle that I took out of a garage about a year ago
  16. Dec 4, 2012 at 8:26 PM
    #96
    Gramps
    Gramps
    07 TRD DC 4x4
    Yeap got that part hence the Alumiconn fix prior to purchase. So far has been legit. Are you familiar with this? As electricians is this a decent fix or really just a band aid and I should consider re-wiring the entire house?
    http://www.alcopstore.com/
    Was that an AL rated outlet? It does not appear to be but I am no expert.
  17. Dec 4, 2012 at 8:32 PM
    #97
    mattgecko
    mattgecko The LED Lighting Guy. MattGeckoLEDs.com
    South San Jose, CA
    2011 DCSB O.R. 4wd TRD Super Charged
    I want to run a wire from the truck battery to a trailer battery to charge it while I am driving. It will go through a switch and rely.
    What gauge wire do you recommend?
    Thanks in advance
  18. Dec 4, 2012 at 8:34 PM
    #98
    Rich91710
    Rich
    Los Angeles
    08 Base
    Rewire.
    The connectors look like a fair band-aid to replace wire nuts, but it's not going to take care of the receptacles and other connections.
    Fair band-aid? If the screws loosen, you're back to the original problem.
  19. Dec 4, 2012 at 8:41 PM
    #99
    Rich91710
    Rich
    Los Angeles
    08 Base
    Fixed that for you.
    High current calls for a contactor, not just a simple relay.
    Standard automotive relays are generally only 30-40 amps, meaning they should be fused at 25-30a and not run continuous at more than 20-25a.
    Your charge current COULD exceed that.... up to the output of the alternator sounds right, but it's not.
    If the battery is very low, when you hit the switch to engage it, it's going to yank some major current from the truck's battery... that inrush current could be a couple of hundred amps and it could remain fairly high for a while.
    There are battery isolation circuits built for slide-in campers that automatically charge when the truck is running, but limit the charge current to safe levels.
    I'd run one of those with either 2ga or single ought "0" due to the length of the run to the trailer.
    Don't forget... your ground needs to be the same size as your hot, and yes, you can use the frame, but tie the frame to the truck's battery in the engine compartment.
  20. Dec 4, 2012 at 8:44 PM
    #100
    Saskquatch11
    I wire/rewire houses for a living, I've seen dozens of near disasters because of aluminum wire.
    The receptacle was not rated for AL, to the best of my knowledge no new receptacles or switches are rated for AL.
