Ask the Electrician
Discussion in 'Off-Topic Discussion' started by Alexb03, Jan 6, 2012.
  1. May 11, 2014 at 3:31 PM
    #161
    Round II
    Round II Member #12005
    Yes you can wire NM from one panel to the other, but why not just run some carflex/Liquid tight and use THHN. It just makes for a better install IMO. Oh and not that you were gonna forget but make sure you add some sort of interlock if you plan on back-feeding from a portable genny.;)
  2. May 12, 2014 at 3:09 AM
    #162
    dexdawg
    dexdawg Well-Known Member
    Frederick, MD
    2010 DC SB OFF-ROAD
    I had some left over 12 and 14 gauge romex so I spliced inside panel and ran it to the other panel. I will be using a Square D interlock kit so I can run my cable through inlet box and 30a breaker inside my panel.
  3. Jul 27, 2014 at 10:19 PM
    #163
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
    Hey guys, I need help with a problem. Last week, the light switch in my bedroom burned out. The wires inside were fried. It tripped the breaker. Well, I replaced the burned wires and put in a new light switch. When I turned the breaker back on, I was able to operate the lights, but now the outlets on three of my bedroom walls have no power. I tried to reset the breakers and checked the outlets, but the wires in there are fine. Where should I be looking next?
  4. Jul 27, 2014 at 10:31 PM
    #164
    Greenbergler
    Greenbergler Well-Known Member
    Corey
    Orange County, CA
    2017 trd sport DCLB 4x4
    Is there a gfi plug around? Or are the plugs spliced into the hot on the switch and it's a loose connection? Do the plugs work with the light switch on? I doubt that it's either of the two but you never know...
  5. Jul 27, 2014 at 11:17 PM
    #165
    ppham444
    Phuong
    Portland, OR
    Nope, there aren't any gfi in this house. I'm not sure how the home is wired up. The light switch works and one wall outlet works. The other three wall outlets have no power.
  6. Jul 28, 2014 at 9:42 AM
    #166
    Greenbergler
    Corey
    Orange County, CA
    Hmm doesn't make sense to me. The plugs should have nothing to do with the switch. It's hard to say without seeing it
  7. Jul 29, 2014 at 10:28 AM
    #167
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    You might have lost the neutral to the plugs when something happened with your switch, do you have a plug tester? If so plug it in and hopefully a light or 2 shines on your tester. And let's you know.
  8. Jul 29, 2014 at 5:01 PM
    #168
    ppham444
    Phuong
    Portland, OR
    Neutral is the white wire, right?
  9. Jul 29, 2014 at 5:31 PM
    #169
    Greenbergler
    Corey
    Orange County, CA
    Yessir
  10. Jul 29, 2014 at 6:09 PM
    #170
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    How did you replace the wire with finished walls? Was it the line or load side you replaced?
  11. Jul 29, 2014 at 11:18 PM
    #171
    ppham444
    Phuong
    Portland, OR
    Just the ends that go into the switch. I used those twisting caps to connect my wires that go from the main line into my switch.
  12. Jul 30, 2014 at 5:53 AM
    #172
    Greenbergler
    Corey
    Orange County, CA
    Did you pull new wire? Or just replace the little peices that are like 8" long?
  13. Jul 30, 2014 at 5:57 AM
    #173
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    Wire nuts.
    Are you able to post a pic of what's inside the box where the switch is? Maybe we can spot something.
  14. Jul 30, 2014 at 6:11 AM
    #174
    Got2ryde
    Got2ryde Well-Known Member
    Ryder
    Maryland
    AC OR 6spd silverstreak
    Off Road tow pac. GTCovers wetskinz seat covers, Direct wired Escort 9500xi, Leer 180 w/ARB awning, bed mat, extra d-rings, rear dif breather relocated, Weathertec mats, Elite front with Warn M8000-s and Rigid D2's, BAMF sliders, ABS killswitch, Kicker Hideaway sub, UltraGauge, ATO rear with flush mount duallys, FJ Trail Team black rims w/Duratracs.
    Hey all. Wondering what your thoughts are on Generac generators. Liquid versus air cooled. The motherboard in our old unit is fried and I've been quoted about $3k to repair it. Motor is strong but the output is low and run speed is fast. I'd like to think it has some salvage value. I've been quoted $8k for a 22kw air cooled Generac and about $13k for a 22kw liquid cooled. These prices are up and running.
    Thx.
  15. Jul 30, 2014 at 5:53 PM
    #175
    ppham444
    Phuong
    Portland, OR
    Yeah, I replaced the sections of the wire that was burned. Then I connected the new wire to the old wire using wire nuts.
    I'll see if I can post a pic behind the new switch in little later.
  16. Sep 22, 2014 at 8:47 AM
    #176
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Ok. Question for the electricians. So 2 nights ago I smell an electrical burning. I was sitting at my computer at the time, and I was messing around with it. So after searching the house I chalked it up to the computer which is older. The smell dissipated, so without finding the source there was not much to do.
    Today, I just happened to being doing some work on the dryer and found this :
    So what would cause this? The dryer was not on at the time. In fact it hasn't been used in a few days because the washer is broke.
    I haven't had any surges that I know of. Nothing else has been affected if I did.
    I know a little about wiring. Comfortable working with most stuff, switching plugs, running wire, switching out a.breaker etc...
    I just don't have a clue why this would happen. And obviously don't want it to happen again or worse have a fire. Should I just change the.plug out? Dryer still works by the way.
  17. Sep 22, 2014 at 8:49 AM
    #177
    Large
    Large Red
    Loose wire, that looks like the neutral one of the hot wires (receptacle is upside down)
  18. Sep 22, 2014 at 8:59 AM
    #178
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Loose wire on the dryer?
  19. Sep 22, 2014 at 9:03 AM
    #179
    Large
    Large Red
    Loose wire inside the receptacle will cause it to get hot and melt (in part or whole). I would meg the wires (if you have a megger) and if they are good, cut off 6" of the wiring and make new terminations with a new receptacle.
  20. Sep 22, 2014 at 9:04 AM
    #180
    TacomaPrime
    TacomaPrime Cybertronian Tacoma
    Gregory
    Illinois
    14 TRD sport 4x4 Barcelona Red
    Weathertech front floor liners, window vent visors. Custom bedside decals. OEM bed mat, tonneau covrew. Added D rings to bed.
    So I bought a house a few years ago that has 4 lights hanging inside the attic. They are all connected together. They worked for a time, and then just stopped working. I replaced all the bulbs thinking that maybe one went bad. Still nothing. I inspected the wiring for maybe a broken section, can't find anything. I checked every breaker/fuse/outlet/switch I could find that I thought might even be even remotely the one that would control them. Nothing. I found the electrical box the wiring goes to, and I know it's good, cause the attic fan gets it's power from the same box, and the attic fan works fine. Any other ideas?
