at 50,000 miles
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Marioso, Jul 30, 2008.
  1. Jul 30, 2008 at 1:56 PM
    Marioso
    Marioso [OP] Risueno
    San diego Ca
    2007 Toyota Fj Cruiser
    at this point im gonna get the oil change done...when i do the oil change they usually do a certain point inspection and tell me if anything else needs to be flushed or filled...is there anything else i should be worrying about right now?
  2. Jul 30, 2008 at 1:58 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    if you havent changed the rear diff at 30k........i would have that changed or change it yourself.
  3. Jul 30, 2008 at 1:59 PM
    Marioso
    San diego Ca
    ok thanks...i looked at the maintance log and whoever had it before me wrote down mobil1 synthetic every 5k...nice to know the guy took care of the truck
  4. Jul 30, 2008 at 2:01 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    definitely nice!!
    that being said......he may have only changed the oil....he may not have done anything to the rear diff.
  5. Jul 30, 2008 at 2:03 PM
    Marioso
    San diego Ca
    is that pricey to do?
  6. Jul 30, 2008 at 2:05 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    at a dealership it is.....but,if you do it, maybe around $45 or so if you do it yourself.
  7. Jul 30, 2008 at 2:20 PM
    Marioso
    San diego Ca
    i gotta lube up the suspension too is that hard to do?
  8. Jul 30, 2008 at 2:22 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    if you have 4x4, then you gotta lube everything on the driveshafts.....if you are 2 wheel drive, nothing to lube under the truck.
  9. Jul 30, 2008 at 2:25 PM
    Marioso
    San diego Ca
    oh cuz thisz guy at discount tire was telling me that umm....the suspension needed lube after it was squeeking after a trrail run
  10. Jul 30, 2008 at 3:18 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    on that my friend......you can spray some dry moly lube or something like that between each leaf in the rear leaf packs......should take care of any squeaking back there.:)
