At my wits end....(Shake)
Discussion in '1st Gen. Tacomas (1995-2004)' started by Pujo, Dec 26, 2013.
  1. Dec 26, 2013 at 8:11 AM
    Pujo
    Pujo [OP] Active Member
    Central Louisiana
    2000 Tacoma 4x4 Regular Cab
    Hey guys,
    I'm at my wits end trying to find out the source of the shake.
    I think I have it narrowed down to the front end. Checked the inner/outer tie rods, they seem to be ok with the exception of one of the inner rods. There is some slack but very minimal. I mean you can feel a little something, but I cannot actually see it. There also may be a slight slippage but not much in the rack an pinion unit, at the bushing on the right side. I went to the shop to have the tires balanced, but no one want's to do it due to the custom rims. The U-joint's also seem to be fine. When I get up the 50 mph, the shake starting in the seat, like a rear end shake, then at 53 it's all in the steering wheel and you don't feel the shake in the seat any longer. I literally cannot drive the taco faster than 50 without the massive vibration in the steering wheel. I have the taco up on jack stands now in my shop and really cannot see what is making it shake so dong much. So other than not being able to get my tires balanced, what else can I look for?
    The shake wasn't bad last year, but this year it's almost unbearable.
    I only use the taco during hunting season but do try and drive it at least once a month, when I'm not offshore.
    Any advice?
    Thanks,
    Pujo
    2000 Tacoma
    Regular Cab
    4x4 4 banger.
  2. Dec 26, 2013 at 8:15 AM
    Large
    Large Red
    Find a place that will balance the tires, better yet find a place that will do a road force balance. Find an empty parking lot, throw it in 4wd and remove the rear driveshaft, see if you can get it to 50ish mph and see if the vibe goes away. If it does, it's the rear making the vibes, if not it's the front.
  3. Dec 26, 2013 at 8:19 AM
    Pujo
    Central Louisiana
    Don't mean to be lame, but what is a road force balance?
    I will see if I can remove the drive shaft, but will I loose all my oil?
    With the truck up on jack stands, I was unable to get any vibration running the truck up to 70 mph.
    So does mean that the issue is not in the rear end? (Forgot to mention that in my first post)
  4. Dec 26, 2013 at 8:25 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Years ago, I bought one of these: I did my own static balancing ( severe offroading would sometimes strip off the balancing weights, or tear off chunks of tread ). I was on 33's and aftermarket steel rims. Worked well. No guarantees it would work on your 'custom' rims.
  5. Dec 26, 2013 at 8:28 AM
    medic2230
    Murph
    Bama! Roll Tide
    The road force balancing machine applies force like the truck has on it when the tire is on the ground to get a better balance. All Toyota dealers should have a road force balancing machine. What's so special with the wheels that the others won't touch it?
    Could also be some worn out bushings or other suspension part. It is a 13 year old truck.
  6. Dec 26, 2013 at 8:42 AM
    tacomataco2
    tacomataco2 A dude
    Mass
    02 Dbl cab Lunar Mist
    Some of this Some of that
    Custom rims meaning? Chrome rims? Plenty of shops balence bling bling wheels, find one that does to eliminate that as a problem
  7. Dec 26, 2013 at 8:43 AM
    Pujo
    Central Louisiana
    I don't know what makes these wheels so special.
    I have called all the shops in a 30 mile radius, no one has even heard of "Road Force Balancing" I live in a rural area, so I expected that. Not wanting to drive over an hour for a balance, I will just have them done the old fashion way. Not too bad at $50 for a balance. Maybe the guy will see something when he get's it up on the lift. The only shop that said they would do it will not take responsibility for any rim damage. At this point, I really don't care. I just want the shakes to go away!
    With the truck up on jack stands, I was unable to get any vibration running the truck up to 70 mph. So does mean that the issue is not in the rear end??
  8. Dec 26, 2013 at 8:46 AM
    Boone
    Boone Vaginas are rad.
    Boone, NC
    Airbags deployed
    Are your wheels hub centric or lug centric? Could be part of it.
    And holy shit that sounds sketchy.
  9. Dec 26, 2013 at 8:47 AM
    TeamSarcasm
    TeamSarcasm Flawless Escalation to the Ludicrous
    The better coast
    how about a picture of your wheels :notsure:
  10. Dec 26, 2013 at 8:52 AM
    medic2230
    Murph
    Bama! Roll Tide
    Bingo! Could be the problem. You did say it did it when you first got them put on and has gotten worse (last year, maybe?).
  11. Dec 26, 2013 at 9:19 AM
    Pujo
    Central Louisiana
    [​IMG][​IMG]
    http://sdrv.ms/1eGqAs0
    Ok guys. When I purchased the taco several years ago it was fine.
    The wheels came on the taco, I did not purchase them after, the previous owner did. I am guessing that the wheels are lug centric. The wheels are 32x11.5 R15 if that says anything. I was wanting to find some factory rims and put a little narrower tire, but haven't found the wheels yet.
    Tried using my skydrive to post a pic, but doesn't seem to work, so I just posted a link.
  12. Dec 26, 2013 at 9:24 AM
    Pujo
    Central Louisiana
    These rims are not worth the effort.
    Looks like some regular old paint peeling aluminum rims. Just a little bigger.
    There is no bling unless you like the peeling paint......:cool:
  13. Dec 26, 2013 at 9:35 AM
    The End
    The End Support our troops!
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    HP60/14 bolt, Atlas 5.0.
    No way those are hub centric. They make a ring that offsets the bore difference. You can try that.
  14. Dec 26, 2013 at 9:43 AM
    Pujo
    Central Louisiana
    Ok, Try what? I have not clue as to what you guys are talking about.
    I will assume that you mean the wheels are off center and to reposition them? If so, is there a proper way to do this?
  15. Dec 26, 2013 at 9:46 AM
    Boone
    Boone, NC
    Airbags deployed
  16. Dec 26, 2013 at 9:52 AM
    offrdmania
    offrdmania Taco Wagon
    Templeton, Ca
    96 Tacoma LX 4 banger
    Do you have your stock wheels and tires? If you do, put them back on and if the shake is still there then you know it isnt your aftermarket wheels and tires.
  17. Dec 26, 2013 at 9:56 AM
    Pujo
    Central Louisiana
    Wish I did, however I do not have any other wheels for the unit.
    I'm off to the tire shop for a balancing. Let you know what happens in a bit.
    Thanks guys
    Pujo
  18. Dec 26, 2013 at 9:56 AM
    The End
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    Yeah sorry the hub centric rings.
  19. Dec 26, 2013 at 10:43 AM
    Pujo
    Central Louisiana
    Quick trip and back home.
    Wheels did not get balanced. The repair guy said that he could not guarantee the balance due to the fact that he could not put weights on the outside of the wheel. It is a steel wheel and most of the chrome was missing. He also said that if I could get some new wheels, he could almost guarantee that a balance would resolve all my problems. Wow, he didn't even drive it. Anyway, I am not on the hunt for some wheels, and looking for recommendations. It's a weekend driver during the hunting season, and I am not spending a mega bucks on wheels.
    Any recommendations?
    Thanks,
    Pujo
  20. Dec 26, 2013 at 12:27 PM
    tan4x4
    Rick
    Folsom, CA
    Check craigslist for stock Tacoma wheels that someone has leftover from 'upgrading' to mediocre aftermarket wheels :D .
    There are lots of them around Sacramento that even come with tires, for around $200. You might have to drive a bit to get them, if you are in a rural area.
