AT Transmission question
Discussion in 'Technical Chat' started by SCFirefighter, Sep 12, 2010.
  1. Sep 12, 2010 at 5:30 AM
    SCFirefighter
    SCFirefighter [OP] on idiot patrol ;)
    Stephan
    Cary, NC
    Silver 2010 DC TRD Sport 4x4 5'
    MagnaFlow Performance Exhaust, ScanGauge II, Map, dome and license plate LED's, Custom Fire/Rescue decals, Weathertech deflectors, Removed mud flaps, Rear spring TSB, Spidertrax spacers, Tinted windows (5%/27%), Black Tacoma badges, 5100 Billstein x4, ToyTec Coilovers, ToyTec TSB AAL, Devil horns, Hose clamp tailgate mod, OEM bed mat, HomeLink module, Hardwire GPS, Weathertech digital fit floor lines, Front Diff drop, Rear Diff breather mod, 4xInnovation welded sliders, Pioneer AVH-X5800BHS+SiriusXM.
    I just saw a local ad for a transmission shop that claims a transmission has about 2000 moving parts? I am not very mechanically includes (but I did install my TT ultimate lol).
    That made me think, I don't have a clue how exactly a transmission (MT/AT) works. Never had any interest to find out until now.
    Any pointers? (I can google, but I'm asking for some GOOD info lol)
  2. Sep 12, 2010 at 5:41 AM
    travelingman
    travelingman What would Scooby do?
    Brian
    Ohio
    07lb4x4DC
    ticking eng.mo,ventvisors,locking tailgate,wheelmasters ss spare tire inflation line,weathertech mats
    Check out a site called "How stuff works".It's pretty detailed explanations with pictures,etc.
  3. Sep 12, 2010 at 6:52 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    x2, that's a pretty open ended question. That how stuff works thing will at least give you the basics, then you can post back more specific questions if you have any. Not trying to be an ass, but there are a lot of moving parts so a full out response on how a transmission works would take a while.
  4. Sep 12, 2010 at 9:04 AM
    SCFirefighter
    Stephan
    Cary, NC
    Yeah, I guess y'all have a point. I'll be back (I'm sure) :)
  5. Sep 12, 2010 at 8:26 PM
    2TRunner
    2TRunner Snoop Dad
    My House Usually
    M/T:
    In the bellhousing: Consists of the flywheel, clutch and pressure plate. Without getting extremely technical, when the m/t is "in gear" all 3 components basically become 1 large rotating unit. When you press in the clutch, you disengage the pressure plate as you shift into another gear and when you let the clutch out, the pressure plate will once again engage the clutch disc and you'll be in gear.
    There are a number of shafts (3/Trans input/output shafts and countershaft) in the m/t containing numerous gears with varying ratios. All gears in the m/t are always moving. Really just kind of spinning and spinning until they become engaged. A shift fork is responsible for selecting the desired gear. When you select a gear, the shift fork engages a gear and it basically locks it with the trans output shaft. The gear on the trans output shaft will turn a corresponding gear on a countershaft which turns a pinion gear, which turns a ring gear, which turn the wheels.
    Take a look here:
    http://www.ratwell.com/technical/Transaxle/002-SideCutaway.jpg
    The red shaft on the right in the input shaft, the orange on the left is the output and the shaft below the orange is the countershaft. The large brown gear next to the white circle under the red input shaft is the pinion gear.
    There is a lot more to it than that, but thats the jist.
    An automatic transmission...does the same thing...execpt automatically. Valve bodies, fluid pressure, etc help accomplish this.
  6. Sep 12, 2010 at 8:30 PM
    HondaGM
    HondaGM CallSign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
  7. Sep 12, 2010 at 8:39 PM
    2TRunner
    2TRunner Snoop Dad
    My House Usually
    Dinglearm...hehehe.
  8. Sep 12, 2010 at 8:42 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Don't forget the torque converter. It's a turbine. The engine turns one impeller which forces fluid into another impeller, which is connected to the input shaft of the transmission. The input shaft turns a hydraulic pump and a series of planetary gears which change gear ratios based on which part is held by a clutch band. Disc clutches are used as well to change gear ratios.
    All of this is made possible by careful control of hydraulic(transmission) fluid. Pressure must be closely regulated and ported to provide smooth shifting.
  9. Sep 12, 2010 at 8:43 PM
    larryde09
    larryde09 Well-Known Member
    Larry
    Boston, MA
    2019 TRD Sport, White Double Cab "Yeti"
    Current: DR750S-2CH Dash Cam, USB Fast Charger in stock blank, Hondo Garage phone mount Previous: 2006 Black 2.7L 5-spd SR5 4x4 Access Cab - K&N Cold Air Intake, Modified Magnaflow Cat-back Exhaust, Altezza Tail Lights, Pop&Lock Tailgate Lock, Extang Trifecta Tonneau Cover, PIAA foglights with stock switch, DrawTite Hitch, OBX Shift Knob, Hood Protector, Vent Visors, DIY step bars, DIY Bed Lights, DIY Ground Lights, DIY Tailgate Electrical Box, Aftermarket switches in stock dash blanks, Sony Head Unit, Illuminated 4x4 switch mod
    wikipedia actually has a fairly simple description of each type to get you started.
  10. Sep 12, 2010 at 8:43 PM
    2TRunner
    2TRunner Snoop Dad
    My House Usually
    To add to this and clairify for the OP, a Torque Converter is only used with Automatic Transmissions.
    I had torque converters explained in a very understandable terms to me once. Think of 2 fans facing each other. 1 fan is plugged in, one is not. When the plugged in fan is turned on and air flow happens, it spins the fins of the 2nd fan.
  11. Sep 12, 2010 at 9:28 PM
    Isthatahemi
    Isthatahemi Well-Known Member
    TRD OFF ROAD
    BFG AT's, Weathertechs, Hoppy's brake controller.
    I've had transmissions apart, for an auto, between 400 and 600 moving parts is my guess.
    A manual I would guess less than 200.
    But it depends how you count. Is a roller bearing on moving part, or 20?
  12. Sep 13, 2010 at 7:15 AM
    cinch
    cinch Member Extraordinaire
    Al
    Boulder Creek Ca
    2010 Prerunner double cab
