at what psi will your tpms light activate?
Discussion in 'Wheels & Tires' started by NWtacoma, Oct 29, 2009.
  1. Oct 29, 2009 at 3:59 PM
    NWtacoma
    NWtacoma [OP] Well-Known Member
    Kent,WA
    2011 TRD Sport 4x4
    265/70/17 bfg AT
    anything under 29?
  2. Oct 29, 2009 at 3:59 PM
    thestrangebrew
    thestrangebrew AlphaPlanner
    Brian
    Dos Palos CA
    TRD 4x4 Rugged Trail Edition
    Black Badges, Black Center Console
    I think 25 but I'm not exactly sure...
  3. Oct 29, 2009 at 4:00 PM
    NWtacoma
    Kent,WA
    2011 TRD Sport 4x4
    265/70/17 bfg AT
    hmm i just checked my tire pressure and all four were over 30psi...must be my spare thats low
  4. Oct 29, 2009 at 4:03 PM
    dysfunctnlretard
    dysfunctnlretard Hi
    Manny
    CA
    2021 Jeep Rubicon
    I was told it was when air pressure deviates from standard by 4 psibut others say 25% off. :confused:
  5. Oct 29, 2009 at 4:04 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    It's a margin (4 or 5 psi I think) around where ever you set it to with the reset button...
    So yeah..Check the spare...and make sure they are all inside of a few psi of each other.
  6. Oct 29, 2009 at 4:05 PM
    The End
    The End #allenfab
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    HP60/14 bolt, Atlas 5.0.
    7% difference. I don't think it's a set number but more like if one is 7% lower than the other 4.
  7. Oct 29, 2009 at 9:49 PM
    judd94
    judd94 Well-Known Member
    Ponchatoula, LA
    17 4Runner TRD Off Road Premium
    Mods in Progress
    my tpms activated the other morning. all main tires were good. spare was only 23psi. refilled and reset tpms.
    good to go
  8. Oct 29, 2009 at 10:01 PM
    NWtacoma
    Kent,WA
    2011 TRD Sport 4x4
    265/70/17 bfg AT
    how do you reset tpms?
  9. Oct 29, 2009 at 10:02 PM
    SocalMan22
    SocalMan22 Well-Known Member
    Steve-0
    So*Cal
    06 PreRunner Dbl Cab
    What Mods!
    Judd94 and i had the same problem i went to see which one set my light off and sure enough the spare set it off and was at 23psi
  10. Oct 29, 2009 at 10:03 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Yep. Mine seems to go off around 23-25 psi.
  11. Oct 29, 2009 at 11:45 PM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    I'm not sure... but when I had them at 8PSI at Pismo the light was definitely on
  12. Oct 30, 2009 at 4:01 AM
    FoxySandChick
    FoxySandChick Well-Known Member
    Kristin
    Henderson, NV
    07 DC 4x4 Base model V6 Impulse Red Pearl
    De-badged, limo tint, black wet okole's, weathertechs, extra d-rings, TSB bilsteins
    25% lower than the PSI you have them set at...so stock at 29psi is around 22-23 psi that it will turn on...to reset, put in the PSI you want in all 5 tires, then hold down the button under the steering wheel...check the owners manual for more detailed procedure.
  13. Oct 30, 2009 at 10:58 AM
    07runner
    07runner Active Member
    SANTA CLARITA
    07 prerunner trd debadged &black headlights
    debadged, black headlights
    Mine came on at 25psi it was my spare
  14. Oct 30, 2009 at 12:29 PM
    Cryer
    Cryer O shizzle!
    Bryan, Tx
    '11 Tacoma TRD Sport
    3" lift
    does the spare have the valve stem sensors, or the bands? my spare doesnt have to bulky exteral valve stem like the other ones.??
  15. Oct 30, 2009 at 10:18 PM
    SocalMan22
    Steve-0
    So*Cal
    What Mods!
    From what i understand the spare doesnt have the sensor in it and thats for the 09 i could be wrong
  16. Oct 31, 2009 at 12:43 PM
    The End
    The End #allenfab
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    Some do some don't. The only cars with banded sensors are Fords.
