ATF for 2020 Tacoma Limited
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ldmarcht931, Aug 13, 2020.
  1. Aug 13, 2020 at 10:30 AM
    ldmarcht931
    ldmarcht931 [OP] Member
    Texas
    2020 Limited
    bedliner, tannou cover
    Hi Eveyone;
    Recently purchased a 2020 Limited and totally love it! I'm getting a 5000 lb travel trailer and the dealer has told me I have the towing package in the truck but there's no mention about a transmission fluid cooler in the package. Does anyone know if it's not needed or was I misinformed by the dealer. Thanks very much!
  2. Aug 13, 2020 at 10:37 AM
    Dirk Diggler
    Dirk Diggler Under the Stun Gun
    Columbus, GA
    2017 MGM OR DCSB
    A thread around here mentions that Toyota deemed the trans cooler unnecessary for the newer models.
    That being said, ANOTHER thread has an upgraded trans cooler. I'll see if I can find both.
    Edit: do you know what a trans cooler looks like ? Look behind your grill and if you have a smaller cooler (looks like a mini radiator, in front of your radiator)
    Missing trans cooler thread with updated info about not "requiring" https://www.tacomaworld.com/threads/missing-transmission-cooler.671079/
    Upgraded trans cooler. I'm certain more threads exist, and possibly better coolers? This one seems to work well and is much larger at cooling and fluid volume. https://www.tacomaworld.com/threads/3rd-gen-transmission-cooler-upgrade.482280/
    Finally, check out the towing section of tacomaworld. Plenty of good stuff from measuring tongue weight, distribution and hitches, braking, suspension, etc for towing.
  3. Aug 13, 2020 at 10:58 AM
    mchertel
    mchertel Well-Known Member
    Mark
    Colorado Springs CO
    2020 Tacoma Off-road
    Toytec 2 inch boss lift
    There is a thread on here discussing how the newer 2020’s don’t have an external cooler in front of the radiator. I guess it uses the main radiator or something. My 2020 built in Nov 2019 does have an external cooler. I personally would not pull a 5K trailer with the Tacoma. By the time you add water and other stuff it adds up fast. Just me though, good luck.
    jetfishn, Grindstone and Dirk Diggler like this.
  4. Aug 13, 2020 at 11:56 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Ordered my 2020 in january, got it the first week of march...it has what appears a 3''x9'' external trans cooler thats attached to the radiator.
  5. Aug 13, 2020 at 2:01 PM
    ldmarcht931
    Texas
    2020 Limited
    Thanks everyone, very helpful!
  6. Aug 13, 2020 at 2:09 PM
    Pilsner
    Pilsner Well-Known Member
    18 TRDOR
    255/85r16 ST Maxx 6112/5160 w/ Dakar RCI armor, sliders, and rear bumper CBI hidden winch mount w/ Smity 20k
    Agreed. That would be pushing the GCWR of 11360 unless you were the only one in the truck and everything was empty. Truck at 4445lbs dry and empty. Add fluids, people, weight distribution hitch, tongue weight, and fill the bed. Then add water to your tanks, propane bottles, and food and gear to the trailer. That's pretty heavy. I wouldn't want to do that very far even if you are in spec. It would probably pull, but it would be a long trip I think.
  7. Aug 14, 2020 at 11:22 AM
    ldmarcht931
    Texas
    2020 Limited
    I took delivery on my 2020 Limited in Houston late in March. It has a ATF cooler in front of the radiator. The funny thing about that is the this component isn't listed in the dealer's towing package. When I went in for first 5k service I asked them to look it up in their system. It's not listed.
  8. Aug 14, 2020 at 11:59 AM
    zoo truck
    None
    When i ordered the truck my dealer had it listed on the invoice among other stuff.
