ATRAC vs Rear Locker?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Lightsped, Dec 26, 2017.
  1. May 8, 2022 at 2:42 PM
    CAtacoWaves
    CAtacoWaves Active Member
    2019 MT DCSB OR
    Rhino Rack Gutter Channels & Rack, Thule Bed Rack (old model mod), Bed Platform,[Switches: Stereo Brightness, NAV Bypass, White Noise Backup Alarm], Interior AC plugs w/400W anytime, Gate King, Bed & Underhood Lights, SPIKER Eng Hood Struts, MICTUNING Tailgate Light Bar, Blinker Genie 2 Mod for side mirrors and side markers. CBI 0deg Rock Rails, Riccochet Al Full Skids, Bed Divider Rear Window Block, Rostra Front Rock Crawl Camera, Rostra Front/Rear Dashcams, [Alarm Upgrades: Glass Break Sensor, and Tilt Sensor, Shock Sensor, Tailgate Sensor with off switches]. Snail Armor Tailgate Insert. Pop&Lock Tailgate Lock. SaBellCo Tailgate Security Lock. Wheeler's OR 1.5" Prog Add-a-leaf with stock Overload spring. TIMBREN Active OR Rear Bump Stops. FOB free key. HitchSafe. TUFFY Lock Boxes in Center Console & Rear Seat. Toyota Wheel and Spare Tire Locks. In progress: Bilstein 5100s & OME 886 coils, Durobumps Front Bumpstops, CBI hidden front hitch, Hitch mounted winch with front and rear wiring, Eco Gapshield, War Fab Inc Sheridan Hitch Skid, Battery Upgrade. Make me stop...
    I’m having a problem with my A-TRAC button. Can someone please press that button and tell me if it clicks into position, or if it just pops right out like a momentary switch? Thanks :)
  2. May 8, 2022 at 3:13 PM
    Bertlow
    Bertlow Well-Known Member
    Alberto
    Tocoma
    2016 TRD MT off road A-trac doese work with locker on mostly controls the front wheel slip is what I have seen when locked
  3. May 8, 2022 at 3:20 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    ATRAC/MTS and the rear locker are different and complimentary features.
    ATRAC/MTS advantages:
    - works on all 4 wheels
    - doesn’t interfere with steering
    - less risk of damaging drivetrain components
    - trivial to engage/disengage
    ATRAC/MTS disadvantages:
    - it’s reactive; a wheel needs to slip before it activates
    - never truly delivers equal speed to both wheels on the axle
    rear locker advantages:
    - non-reactive: always active
    - delivers maximum traction to the axle
    Rear locker disadvantages:
    - only affects rear axle
    - interferes with steering
    - increased risk of drivetrain damage
    - finicky to engage/disengage
    Crawl Control is a different sort of thing that is often misunderstood. Think of it as off road cruise control that works on top of MTS.
    More info here:
    https://www.tacomaworld.com/threads/3rd-gen-traction-control-modes-explained.530695/
    Canadian Caber, David K and danojeno like this.
  4. May 8, 2022 at 3:32 PM
    gudujarlson
    Minnesota
    I don’t think I’ve used the button more than once. I’ve never found a reason to disable ATRAC. There is a on/off indicator light on the dash I think.
  5. May 8, 2022 at 3:33 PM
    jasmits1
    jasmits1 Well-Known Member
    2018 DCSB Off Road 6MT
    Ironman FCP with SPC UCAs
    This, and that significant difference can either be an advantage or disadvantage depending on the situation.
    Advantage locker:
    The biggest advantage of the locker is that it is a proactive system, not a reactive one. ATRAC helps regain traction after a wheel starts to spin, with a locker you can prevent a wheel from spinning in the first place. This is why the locker is superior in rocks.
    ATRAC also significantly robs power. It doesn't interfere with the throttle at all, which is a common misconception, but by aggressively pulsing and dragging brakes it does burn a lot of power and can kill your momentum.
    Related to the last, another big advantage of the locker is that when you do need wheelspin you can have it. If you're climbing a big sand dune or a snowy hill there is no way to get up without breaking traction, the wheels will be spinning and effectively paddling you along. ATRAC does not let both wheels slip simultaneously, and sometimes that's necessary.
    Advantage ATRAC:
    The last disadvantage is actually also ATRAC's biggest advantage. By not allowing simultaneous wheelspin, ATRAC prevents side slipping and crabbing. On a slick and off camber surface(think like deep snow on a road with a good amount of side angle) spinning both tires on an axle at the same time causes the truck to slide that direction. ATRAC does a phenomenal job of preventing that while providing much more traction than open diffs.
    ATRAC also helps prevent digging into the surface, particularly snow and sand by not letting you wildly spin if you're not moving.
    ATRAC does not effect your turning circle, while the locker does.
    There is no drawback to running with ATRAC active, if it doesn't need to interfere it's as if it's not there at all. The locker should only be locked when you need it. I can think of many times a hill or something I wouldn't have locked up for was slicker than it looked and ATRAC jumping in was the difference between making it up and backing down a sketchy hill to take another run at it.
    Personally I almost always run with ATRAC active if I'm in low range. Even in the situations where I listed as advantages for the locker, keeping ATRAC active on the front axle is still always beneficial. In the momentum scenarios I mentioned it won't kill momentum as ATRAC only interferes when the rear is locked at under like 5mph, so going back to the dune example at that point I've already lost my momentum and ATRAC can help me not dig in.
    It doesn't do anything going downhill. I use ATRAC a ton and need to feather the brake myself to prevent locking up.
  6. May 8, 2022 at 3:34 PM
    gudujarlson
    Minnesota
    Omfg, did I just spend all that time replying to a thread from 2017? Lol
  7. May 8, 2022 at 3:37 PM
    jasmits1
    Fuck me why did you point that out instead of letting me live in blissful ignorance?
  8. May 8, 2022 at 3:38 PM
    gudujarlson
    Minnesota
  9. May 8, 2022 at 4:19 PM
    CAtacoWaves
    2019 MT DCSB OR
    Yes, there is an indicator on the dash. It turns on when I press the button (when in 4 Low), and turns off when I let it go. I thought I remember it clicking in and staying depressed, and the dash light just came on automatically when in 4 Low. I may have broken my button.
  10. May 8, 2022 at 5:03 PM
    gudujarlson
    Minnesota
    It’s obvious when it’s on and you cause wheel spin. Makes a loud reciprocating noise and you move forward instead of becoming stuff.
    Come to think about it, the rear locker button does not remain depressed. I don’t think the ATRAC button does either.
  11. May 8, 2022 at 6:07 PM
    CAtacoWaves
    2019 MT DCSB OR
    Next time you’re in the car, give it a tap and let me know if it clicks. I’d really appreciate it. Thanks
  12. May 8, 2022 at 7:15 PM
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    The A-TRAC button is latching and should stay depressed until you press it again to unlatch.
    jasmits1 likes this.
  13. May 8, 2022 at 7:30 PM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    DAC was on the 2nd gen taco's at the end [mine has it] but the 3rd gen got crawl control. However, the FJ Cruiser had that before it was discontinued in the States on the OR version. [my 2014 had it]
  14. May 9, 2022 at 2:33 AM
    m shark
    m shark Well-Known Member
    Infinity QX-50, E46 M3
  15. Nov 17, 2022 at 5:59 AM
    #35
    icer22x
    icer22x Too Poor For Mods
    Northwest Arkansas
    2022 TRD Off Road MT - Barcelona Red
    KDMax Tune 10.0 ADM
    If only there was a video showing all of this for MTs... Would love to see the situations in which to use AUTO LSD, 4LO (with/without TRAC/VSC/A-TRAC/lockers), and 4HI (with/without TRAC/VSC).
  16. Nov 17, 2022 at 8:22 AM
    #36
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    haha, I have done it before too!
    Gotta love thread bumpers, then you come in and try to help, and realize you are talking to someone who hasn't logged in,,, in years :D
    71tattooguy likes this.
  17. Nov 17, 2022 at 8:48 AM
    #37
    Xero
    Xero Well-Known Member
    18 Tacoma TRD Off Road, 22 4R, 08 4R
    18 Tacoma TRD off road OME BP51 front Fox 2.0 Resi rear OME Dakar Meduim Yoko G006 325/75r16 Black Rhino stadium wheels Cali raised ditch light brackets Baja Designs S1 pods Baja Designs Squadron SAE fogs Prinsu Cab rack TRD Pro grille AVS rain guards Backwoods adventure mods hi-lite bumper BL Apex 12k winch Dobinsons 4x4 snorkel Sy-clone prefilter ARB rear diff breather relocation RRW rock sliders RCI full skids At the helm bed stiffeners lil b LCA skids Warfab Phantom rear bumper Warfab tie rod sleeves C4 fender liners Dirt king UCA Duro bump stops
    You can run rear locked and MTS for the front.
    4Lo TRAC OFF, VSC OFF, MTS on and rear locker engaged.
    SnuggleTruck likes this.
  18. Nov 17, 2022 at 8:49 AM
    #38
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Great to see the conversation continue.
    It was great fun trying to explain A-TRAC and TRAC system, over 12 years ago!
    One thing is for sure, I have never been stuck in a situation that A-TRAC didn't solve... along with helping others without A-TRAC get unstuck!
    Now with 3rd Gen automatics, A-TRAC has been upgraded to MTS (Multi Terrain Select) which is simply adjustable A-TRAC, plus CRAWL, which is pedal free, low range cruise control. That is basically letting the computer apply the correct amout of throttle so the stupid human driver doesn't bury the truck! LOL
    Canadian Caber, SnuggleTruck and Xero like this.
  19. Nov 17, 2022 at 8:59 AM
    #39
    Xero
    I’ve been in multiple situations where 4Lo locked and MTS didn’t get me through it and had to winch. :rofl:
  20. Nov 17, 2022 at 9:09 AM
    #40
    ShimStack
    Ben
    NC
    No picking on you specifically, but this is what's kind of frustrating for someone like me when it comes to explaining these systems. Trying to explain the systems based on "situations" just doesn't adequately provide the fundamental knowledge to using them wisely. It's more beneficial, imo, to understand the particular traction system and what it does functionally. Once you know each system's functional properties, you then can apply the functionality to the situation as needed because every situation and driving style is nuanced and doesn't automatically fit an exact set of traction tools.
    gudujarlson and Xero like this.
