attempting my own satoshi
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jsauce8921, Apr 20, 2012.
  1. Apr 20, 2012 at 9:13 PM
    jsauce8921
    jsauce8921 [OP] Well-Known Member
    SoCal
    DblCab sb 4x4 trd off road
    So i have absolutely zero experience with fiberglass or body work, everything seems to be working well. does anyone have advice on how to do this fiberglass. I'm pretty new here, but everyone and everything that i have read so far seems like everyone is really willing to help.
    this is what I've done so far
    the sanding job
    the part where you put the fiberglass
    I am googling and will be following the directions as it reads, but I know that sometimes things aren't as easy as it reads or there are some tricks that can make it easier.
    thanks for the help here is what i will be using.
  2. Apr 20, 2012 at 9:19 PM
    carcharias
    carcharias Giggiddy what what
    Los Angeles, CA
    '11 AC MGM OR
    Kings all-around w/ 700lb coils, Dakar leaf pack, TC uca's, DO single hoop bumper, BAMF bolt-on sliders w/ kickouts, Rigid 20" e-series spot/flood, aFe pro-dry, BFG KM2 255/85/16, silver TRD FJ wheels, WARN M8000-s, Access LE, Grillcraft, BAMF lightbar, BAMF rear dif skid, BAMF LCA skids, window tint, Wet Okoles, WeatherTech floorliners, Silverstar lights, led dome lights, Redline Tuning hood struts, center console lock mod, mag-lite mod, extra d-rings, re-routed exhaust, ATO skids, ATO Hi-Lift mounts, pipe tailgate lock, seatbelt alarm delete, wheel/spare locks, Viper 5901, LoJack... WISHLIST: a golden canary that poops platinum
    I don't know anything about it, but I'm rooting for you. I did my own Grillcraft, and it wasn't so bad. You're already passed the point where it annoyed me, though. A number of knowledgeable people will chime in. Look forward to seeing it done!
  3. Apr 21, 2012 at 12:21 AM
    LBtaco
    LBtaco Thread killer
    Long Beach , CA
    15 Nissan Leaf
    Jetsons mod
    search around youtube for glassing tips. it's not that hard.
    or you could just epoxy some pieces in like one guy on the site did.
    OR.. I plastic welded mine in :D
    either way, take your time and sand sand sand
  4. Apr 21, 2012 at 12:38 AM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Sand the living shit out of the area that you will be glassing.
    I did and it still peeled off like a banana peel when I flexed the plastic.
    I ended up cutting filler panels from the center bars, backing those up with Plastruct sheets, and cementing the whole thing together with ABS plumbing cement.
    Everything I read online indicated that you can not glass onto ABS... you must plastic-weld or ABS-cement it.
    But a ton of people have been successful using glass, so it is possible.
    The majority of your time and work is going to be in the bondo. I spent almost a week of evenings (hour or two) getting mine smooth enough to shoot.
  5. Apr 21, 2012 at 12:38 AM
    jdmdcfan
    jdmdcfan Well-Known Member
    east WA
    dcsb
    The middle part of the satoshi that you cut out has enough material to make patches for the 4 cuts you made. Epoxy them and brace them from the inside with some plastic recycled from the middle part of the grill. Use a little bit of bondo and sand to smooth.
  6. Apr 21, 2012 at 12:39 AM
    jdmdcfan
    east WA
    dcsb
    beat me to it
  7. Apr 21, 2012 at 12:43 AM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Buuuut.... be careful. Those clips snap into the headlight and if you go too thick there will be interference.
    I ended up right on the edge of being too thick.
  8. Apr 21, 2012 at 1:10 AM
    J0hnMata
    J0hnMata Well-Known Member
    Orange County
    09 PreRunner
    BHLM, bilstein 5100's, satoshi grillcraft grill, k&n cold air intake, tinted windows all around, interior map and dome light led's, hid fog lights and headlights, yellow fog light lenses, black lower valence.
    don't use the fiberglass dude its a waste of time
  9. Apr 21, 2012 at 1:19 AM
    Frostbyte
    Frostbyte Well-Known Member
    Northern Utah
    18 Super White TRD OR Manual
    SOLD - 03 Black SR5 4x4 TRD OR RIP - 07 Radiant Red SR5 4x4 TRD Sport Fabtech 6" lift, 33x12.50.18 Toyo M/T on All black XD Hoss wheels
    If I were in your shoes, I would trace the gaps in picture #2 onto some cardboard, cut the cardboard pieces out, retrace them on the center plastic parts of the grill that your going to discard, cut them out, and glue them into place of the gaps, then sand and fill with bondo if needed.... Doing it this way, i bet you could use something as simple as superglue to glue the pieces into place. Fiberblass just seems messy and time consuming....
  10. Apr 21, 2012 at 5:02 AM
    jsauce8921
    SoCal
    Sounds like I see a trip back to o'riely's in my future.
    Thanks a lot dudes I will definitely use your advice and return this fiberglass. I'll update my progress.
  11. Apr 21, 2012 at 9:48 AM
    jsauce8921
    SoCal
    any tips on cutting through this thick plastic, i asked jeeves and he suggests using my soldering iron with a flat tip.
  12. Apr 21, 2012 at 9:51 AM
    HomerTaco
    HomerTaco Chillin & Grillin Vendor
    Craig
    Bucks County Pa.
    four sticks, dual cases, zero fucks...
    Core-Hurst short throw shifter & T-handle / Carbon Fiber Interior / custom console light / De-badged / leather interior / Heated Front seats / Red Line Hood Struts / Painted speaker grills /one-off TRD Satoshi Grill with 12-15 front-end swap/ Pioneer AVIC-X920BT HU / Scangauge II / Black LED Tails / Dash Mount for iPad mini / Safari Snorkel / Auto-pilot mode / Leer 100XQ Cap / 4x Innovations sliders / Rear Diff Breather Mod / front windows tinted to 35% / Brute Force Fab Hybrid Front Bumper / BAMF Rear Diff Skid / Budbuilt Skids / CBI Trail Master 2.0 rear hybrid bumper / Fox rr coils/ TC UCA's/ TC spindle gussets/ TC Cam Tab gussets / Dakar leafs / Defined Engineering shackles / All pro U bolt flip / Timbren Rear Bumpstops / BAMF LCA skids / Exhaust re-route / Fog Light anytime Mod / LowRange Off Road extended rear brake lines / ATO Shackle Flip / sectioned Bushwhacker flares / re-geared to 4.56 / ARB Front & Rear Locking Diff / ARB CKMA12 compressor / PrInSu full rack system / 1" body lift / Inchworm 4.7 crawlbox / twin stick FJ t-case / Davez off-road triple-stick kit/
    lots of solid advice here. :)
  13. Apr 21, 2012 at 10:34 AM
    river rat 69
    river rat 69 Well-Known Member
    Jim
    Orlando, Fla., Green side of the grass
    007, trd, sr5, fmf.
    NO Chrome,3" NFab's steps,TRD skid,Wet okie's.011 grill, k&n,5100's,All this comes right off when the old lady says let's go get a NEW ONE!!!
    ^^^ This is it, Epoxy or do over in no time.use tin snips to cut out the filler plastic [​IMG] Im on # 24 so almost know what Im doing now... PM me if you get lost... Jim:)
  14. Apr 21, 2012 at 1:18 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Not superglue... it does not work well on plastic, is horrible on butt-joints (it works okay where there's a large surface area with no gaps), and does not hold up well to vibration and impact.
    When I worked at Douglas we'd use superglue to temporarily assemble tooling... get it into position, superglue it, drill and tap, test fit the fasteners, then remove the fasteners and a quick rap with a hammer would release the glue.
    You need a solvent-based cement designed specifically for ABS.
    ABS has different properties from PCV and Polystyrene... cements for PVC and Poly won't work properly on ABS.
    Regular old black plumbing ABS cement worked like a champ on mine.
    Now... The center section cut to make filler material works great if you are using one of Homer's mesh inserts, but there's not enough material left to fill in the curve at the "top" edge if you are using a Grillcraft or making your own flat mesh.
    I went with Homer's M1 material and love it.
  15. Apr 21, 2012 at 1:21 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Dremel. Hacksaw for the vertical "supports" then sand flush.
  16. Apr 21, 2012 at 1:24 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    You aren't filling in the little notch at the top center?
    I did and since I went with a colormatched inside, I'm glad I did.
  17. Apr 21, 2012 at 2:55 PM
    jsauce8921
    SoCal
    went to the local flea market and got a set of tin snips for $1
    left side
    right side
    going to find some abs cement or something for abs. thanks guys
  18. Apr 21, 2012 at 3:04 PM
    Bogg
    Bogg Well-Known Member
    Surrey, Canada
    07 TRD Sport 4x4
  19. Apr 21, 2012 at 3:20 PM
    Fiolo
    Fiolo Senior member
    98 Regular cab lifted 4wd
    Lost track many mods ago
    Well put, it's easy and cleaner
  20. Apr 21, 2012 at 3:46 PM
    jsauce8921
    SoCal
    here is the grill kit i am putting in. I am pretty sure i am going to get it sprayed black. I don't know who it is made buy. I got it from a guy i bought my rims from for free. he got rid of his taco and wanted someone to enjoy it.
