ATX Mojave?
Discussion in '1st Gen. Tacomas (1995-2004)' started by 1998tacoma4x4, Sep 28, 2010.
  1. Sep 28, 2010 at 12:53 PM
    1998tacoma4x4
    1998tacoma4x4 [OP] Well-Known Member
    Orange County
    1998 Tacoma 4x4 3.4L Auto
    Deaver j59 pack 2.5 SAW coilovers, rear bilstein 5100's. Extened stainless rear brake line, deck plate mod, drop in K&N filter, Kenwood headunit & pioneer speakers, SnugTop Shell.
  2. Sep 28, 2010 at 1:22 PM
    Manlaan
    Manlaan Well-Known Member
    Greg
    Riverton, Utah
    2002 XtraCab SR5 V6 4x4 Black
    See Signature
    Thats quite a bit of backspacing. I think they're just completely messed up though.
    The real part number for the Mojave starts with AX398 and all have around 4.5" backspacing in 16" wheels. I believe the AX39816883 would be the one you want with the larger hub hole. Not sure if you wanted to go to a 15" wheel or not, but if thats the case, that would be AX39815883 for the part number with 3.75" backspacing.
    http://www.americanracing.com/browse_atx.asp
    Wheelers is selling some Procomp wheels that have a similar design that is considerably cheaper.
    Alloy: Steel:
  3. Sep 28, 2010 at 5:38 PM
    1998tacoma4x4
    Orange County
    Thanks man, that reply had all the info i needed! And i like those Pro Comp wheels, but i like the flat black look, but if i cant find a set of used Mojaves for cheap I am gonna go with the Pro Comps.
  4. Sep 28, 2010 at 11:34 PM
    1998tacoma4x4
    Orange County
    Btw your truck is awesome! Maybe im wrong but in your sig, i didnt see that anything is done to your rear suspenion, what are your plans for it?
  5. Sep 28, 2010 at 11:53 PM
    Manlaan
    Greg
    Riverton, Utah
    See Signature
    I just have some spacers on it now that the previous owner put on. Nothing too fantastic. When/if my springs start to wear, I'll replace them with something with the same amount of lift (about 2").
    As far as shocks go, the previous owner put on some kyb gas busters, which seem to be holding up well. I do have some Billy's sitting next to me that I'll eventually put on.
  6. Sep 29, 2010 at 12:02 AM
    1998tacoma4x4
    Orange County
    Sounds good man, if you go with an aftermarket pack i know the deaver J59 gives about 2" of lift. I have them and am very pleased.
