Audio gurus help me out!!
Discussion in 'Audio & Video' started by Who Dat Popcorn, Jan 17, 2013.
  1. Jan 17, 2013 at 2:40 PM
    Who Dat Popcorn
    Who Dat Popcorn [OP] Dafuq
    Ricky
    Richmond, VA
    Sold :/
    SOLD
    Hey guys, just bought this sub:
    http://www.sonicelectronix.com/item_43403_Rockford-Fosgate-P3S-1X12.html
    My question is, can I use this amp to power it? Some have told me I can't, some told me if I run the wires in series instead of parallel, I can. The sub is wired internally to produce a 1ohm load. I was told since it is dual voice coil, I can open it up, run the wires in series and my amp should be okay. Here is the specs on my amp. It's not stable at 1ohm so I need advice.
    Pioneer GM-5500T with specs:
    Power Specifications - Full Range Channels
    RMS power @ 4 ohms 125 watts x 2 channels
    RMS Power @ 2 ohms 190 watts x 2 channels
    RMS Power @ 1 ohm Not Stable
    Bridged RMS Power 400 watts x 1 channels
    Peak Power Output 820 watts x 1 channels
    Amplifier Specifications
    Amplifier Class AB
    Number of Channels 2
    Total Peak Power Output 820 watts
    Total RMS Power Output 400 watts
    Maximum Input Gauge Size 4 AWG
    Minimum Impedance Unbridged 2 ohms
    Minimum Impedance Bridged 4 ohms
    THD at Rated RMS Power 0.05%
    Speaker Level Inputs Yes
    Preamp Outputs No
    Built-in Crossover Low-pass (LP)
    Low-Pass Crossover Frequency 40 - 500 Hz
    Signal-to-Noise Ratio 98 dB
    Bass Boost Selectable (0, 6, 12dB)
    Bass/Gain Remote No
    Fan Cooled No
    Fuse Rating 25A x 2
    CEA-2006 Compliant Yes
  2. Jan 17, 2013 at 2:45 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    id run a decent class D mono block honestly.........it will power the sub CLEANLY without overheating.
    u always wanna have more power than ur driver can handle, and just use ur head and know when to stop cranking the volume so u dont distort it....especially with a 12, they are more prone to distort due to them being less rigid than some smaller subs due to surface area.
  3. Jan 17, 2013 at 3:00 PM
    Who Dat Popcorn
    Ricky
    Richmond, VA
    Sold :/
    SOLD
    But will it be okay if I do it? My amp generates 400w at 4ohms bridged. If I wire the sub like this
    It will create a 4ohm load, correct? Since the sub is a dual voice coil. If this can be done, I'd rather save some money.
  4. Jan 18, 2013 at 11:02 AM
    96Taco
    96Taco Well-Known Member
    Alberta
    '04 V8 4Runner
    ..stay tuned
    Not sure if Im missing something but the sub you linked is wired for 1 ohm.
    "st make sure you pair it with a 1-ohm stable amplifier. "
  5. Jan 18, 2013 at 11:33 AM
    Who Dat Popcorn
    Ricky
    Richmond, VA
    Sold :/
    SOLD
    It's a dual 2 ohm sub. I opened up the box, they had it wired to 1 ohm.
  6. Jan 19, 2013 at 7:52 PM
    Beach Taco
    Beach Taco Well-Known Member
    Virginia Beach, Virginia
    12' SR5 4x4
    WeatherTech Ventvisors, Dealer Sprayed Underliner, Aries black 3" side bars, Front windows 35% tint
