audio shop says....
Discussion in 'Audio & Video' started by bevans, Apr 2, 2010.
  1. Apr 2, 2010 at 5:27 PM
    bevans
    bevans [OP] Well-Known Member
    GA
    Hey,
    I'm new here... just bought an 07 access cab and am wanting to upgrade the speakers. I did a search and thought that any speaker replacement would require new mounts(like *********). So I go to a couple audio shops today and both places tell me that 6x9s up front and 6.5s in the rear will fit in the stock locations without any additional mounts. Is this true?
    I'm trying to decide between alpine type r's and polk db651's if anyone has any info on both these speakers. I want to keep the truck interior looking stock so I plan on keeping the factory HU and probably will run a 4 channel amp.
    Thanks
    bevans
  2. Apr 2, 2010 at 6:16 PM
    TorenApart
    TorenApart Well-Known Member
    06 Double Cab SR5 TRD Sport
    Toytec Ultimate Lift Kit, OME Nitrocharger shocks and Dakar leafs, Total Chaos UCA's, 18'' Black XD Monster, 285/60R18 Cooper Zeon LTZ, Leer shell, OEM Skid Plate, Weather Tech Floor Mats, Lund Tonneau, Custom 2-tone gray leather, Aero Turbine 2525 muffler with AR25 resonator, Aero Turbine Exhaust Tip, Mr. Marv subwoofer enclosure w/ 2 JL 10W3v2's, AFE Pro Dry S, Eclipse AVN-6620, Pioneer PRS-D2100T, Hybrid Audio Clarus 6.5'' Front Components, Black Headlight Mod, Tinted tail lights, PL5300 with Eclipse BEC-109
    I believe this is correct, however I believe you may need the speaker baffles because of mounting depth restrictions. I would STRONGLY suggest calling MrMarv for your baffles. Taco Tunes does not have a good reputation.
    Depending on your budget, there are after market options (in particular a double din HU) that look completely stock. Some that are even plug and play (Eclipse AVN 6620).
    If you are not interested in changing out your HU, you will need an external processor to clean up the signal from your factory head unit, like the JL cleansweep.
  3. Apr 2, 2010 at 8:02 PM
    Ese Loco
    Ese Loco Taco Man Sam
    Vero Beach, FL / Tampa, FL
    2009 DC TRD Off-Road 4x4 V6 6-speed
    Legal Florida Tint all-around, 1.5" add-a-leaf, bilstein 5100 rear shocks, Light Racing Coilovers, Removed secondary air filter, K&N airfilter, Amsoil 100% synthetic motor oil, Amsoil synthetic severe gear in rear differential, Differential breather mod, Painted rims and logo's black, amsoil oil filter
    Rockford Fosgate 360.2 is a much more customizable solution to keeping that OEM look over the JL Cleansweep.
    I'd look into it.
  4. Apr 2, 2010 at 8:03 PM
    Schully
    Schully Well-Known Member
    Aaron
    Austin
    Black 09 2.7 AC 4x4
    Yep it's true. My 6x9's fit in the front with no mods
  5. Apr 2, 2010 at 8:06 PM
    TaComatoseSR5
    TaComatoseSR5 Mud Junkie
    Stephen
    Tampa, FL
    White 05' SR5 Access Cab 3" lift
    3" Toytec lift (coils and aal), 285/75/16 terra grapplers, HID conversions,led taillights, grillcraft grill, on board air with air horn
    I took a dremel tool to my factory 6x9s and made my speaker mount out of my factory speaker. It is timely but I didnt have to buy anything.
  6. Apr 2, 2010 at 8:06 PM
    TorenApart
    That looks pretty sweet! Have you had a chance to hear and see one installed? I wonder how the bluetooth works with the cell phone...
  7. Apr 2, 2010 at 8:25 PM
    EricT
    EricT Well-Known Member
    Arizona
    '09 4x4 shortbed TRD Sport
    Audio shop I just had put in a new set of Hybrid Imagine series 6.5"ers built 1" thick baffles out of mdf. They just measured up, drew a template, cut em out and blammo.
  8. Apr 2, 2010 at 9:03 PM
    bevans
    GA
    What 6x9's did you go with?
  9. Apr 3, 2010 at 8:20 AM
    leo08pirate
    leo08pirate Katzo production
    Leo
    Oceanside CA
    08 PreRunner 4.0L
    TRD exaust - Tinted Windows - TRD Intake - Alpine type S speakers
    if they dont fit use your stock speakers and cut the speaker and use the the frame then just mount the new speaker and you could save some money them buying some spacers from *********. I dont think you would be able to just just put the 6x9 withought any mods cause you will need a spacer or would have to use your old speakers frame cause the magnet would not clear the window inside the door when you roll down the windows.
    Do the same with the back and they are easier to mount using the factory speaker frame
  10. Apr 3, 2010 at 6:35 PM
    bevans
    GA
    Thanks for the replies. I'll try to use the factory mounts or just buy some MDF and make my own.
  11. Apr 3, 2010 at 8:46 PM
    EricT
    Arizona
    All you need is a handheld jigsaw. Take the old 6x9 out, trace the outer mounting plastic, then trace whatever size circle you need for your new speaker in the middle. Cut both parts out. Doesn't need to look pretty, you'll never see em. Also remember the mount for the existing 6x9 (assuming you have the jbl audio upgrade) is part of that speaker, there's no decoupling the speaker from the mount.
  12. Apr 4, 2010 at 11:53 PM
    taco06
    taco06 Well-Known Member
    Alex
    pomona ,California
    06 sprt
    I can't let the wife know
  13. Apr 5, 2010 at 12:07 AM
    Schully
    Aaron
    Austin
    Black 09 2.7 AC 4x4
    A set of Alpine Type R's. They were brand new in 2005. Still runnin strong!
  14. Apr 5, 2010 at 8:43 AM
    leo08pirate
    Leo
    Oceanside CA
    08 PreRunner 4.0L
    do you have an amp connected with those type R cause it dosent sound as clean as with an amp
    so thats why i went with the type S cause i wont be running a amp for now but it still sounds clean
  15. Apr 5, 2010 at 5:37 PM
    winterboy04
    winterboy04 Professional Cube-Jockey
    MA
    07 SR5 TRD (Bright Red)
    Alpine CDA-9886 Hybrid Audio Unity Series components JL 250.1, JL300.4 Infinity Perfect 10.1 SVC 4ohm in custom enclosure / amp rack Alpine PXA-H100 Processor FatMat everywhere URD short shifter OEM Bed Mat Tail Gate Safety Mod (Plumbing clamps) Pro-Dry S Filter
    Just to throw in my two cents, the RF 360.2 is a SERIOUS piece of equipment and not for the "installation challenged" nor the person who just wants a cleaner sound. i had it in my last car and yes, it made the stock stereo amazing, but it was a SERIOUS pain in the arse. I had planned on writing a separate review, so i will leave it at that
  16. Apr 5, 2010 at 6:27 PM
    hookedontronics
    hookedontronics Well-Known Member
    Jake
    Glenville, NY
    2010 DC Off Road 4x4
    Icon extended travel 3.5" front coilovers, DSM UCAs, TSB leaf pack w/ wheelers AAL, All Pro U-bolt flip kit, Walker Evans 2.0 rear shocks, 18" XD Monster rims, Nitto trail grappler 285/65R18 Tires, Color matched grill, Grillcraft, Kragen HIDs, Carling switches, my bed light mod, diff drop, Alpine IVA-W505, JL Audio C5 componets and coaxials, JL 300/4 and 250/1 amps and JL stealthbox, wheathertechs, avs vent visors, toyota bed x-tender, alcantara center console cover and door pocket covers, console vault, color matched mirrors, heated mirrors, etc etc etc
    use retrofit mounts. you don't want 6x9s up front. 6x9s are junk speakers. use 6.5 components in the front and 6.5 coax in the rear
  17. Apr 5, 2010 at 9:02 PM
    TorenApart
    Why are 6x9 junk speakers?
  18. Apr 6, 2010 at 7:16 AM
    Tdup
    Tdup Well-Known Member
    Trey
    Columbia, SC
    2021 TRD Off-Road 4x4 DCSB 6MT
    Redarc brake controller, CamLocker tool box, OEM Bed lights.
    there not really junk...but it is true that a round speaker will sound better than an oval speaker. i'm not really sure why but i have heard this for years
  19. Apr 6, 2010 at 7:42 AM
    TorenApart
    It's because of the shape of the sound wave is round as opposed to oval.... If applied correctly a 6x9 can be damn good.
    I agree, 6.5'' is the way to go, but to each their own. :D
