Audio System Question 2nd Gen
Discussion in '2nd Gen. Tacomas (2005-2015)' started by idaho_flyfisher, Oct 5, 2019.
  1. Oct 5, 2019 at 12:27 PM
    idaho_flyfisher
    idaho_flyfisher [OP] Member
    Chad
    2008 Black Tacoma TRD
    I replaced my head unit and all 6 speakers in my 2008 access cab Tacoma. All the speakers are 4 ohm. From my understanding the factory speakers I ripped out were all 4 ohm also. I am going to get a small amp for my 6x9s in the front doors and was wondering what to do with the old wires. The new Rockford Fosgate tweeters are just running from the old original wiring and I was wondering if I should leave them or double up the old 6x9 wires and the tweeter wires and run them both to the tweeters. Any advice would be appreciated. I guess the best thing might be to find the split box and take the wire incoming from the head unit and just run it to the tweeter.
  2. Oct 5, 2019 at 6:46 PM
    Corny Taco
    Corny Taco The Sauce
    Blake
    Columbus/Atlanta Georgia
    06 SR5 DCSB Prerunner
    -33 inch Nitto Ridge Grapplers -18 inch fuel kranks -Bilstein 5100s -OME normal duty dakars -Toytec/Eibach coils -Magnaflow off-road pro exhaust -Prinsu roof rack -nfab rock guards -EBay Faux Trd Pro Grille -Custom basshead audio build in progress
    Nahhhhh don’t do that, it’s pointless. Just keep the tweets on the original wires. I don’t use my old door speaker wires anymore either. I would just ziptie or tuck them somewhere where they won’t rattle and just call it a day.
  3. Oct 5, 2019 at 6:52 PM
    robfox
    robfox Well-Known Member
  4. Oct 5, 2019 at 6:57 PM
    Corny Taco
    Blake
    All aftermarket door speakers have the brackets, you just still need to buy the adapters from Amazon.
  5. Oct 5, 2019 at 7:00 PM
    robfox
    I meant to say that they seem to come with the adapters too. You can check the fit against the make / model and it says will fit the tacoma.
  6. Oct 5, 2019 at 10:48 PM
    idaho_flyfisher
    Chad
    When I put my 6x9s in I had to get the Amazon brackets (Metra 82-8146) and take my Dremel and cut out some of the plastic on the inside of the door panel. It was a tight fit. The 6x9s I put in are Kicker 43DSC69304s. My 6.5s are Kicker DSC6504s and I used Metra 82-8148 brackets. I just got a Rockford Fostgate R250X4 amp for those 4 speakers, it should sound good.
