Auto Tranny Fluid Confusion
Discussion in '1st Gen. Tacomas (1995-2004)' started by bajaracer, Oct 10, 2008.
  1. Oct 10, 2008 at 6:28 PM
    bajaracer
    bajaracer [OP] Well-Known Member
    Charly
    Chandler
    05 PRERUNNER DBLCAB SPORT 4.0
    AEM DRY BRUTE FORCE, FLOWMASTER 50 SERIES, 285/70/17 BFG'S AT KO2'S MOTO METALS 17X8 885's with 5100's LOUD STEREO
    Guys I need your help... I decided to change my auto tranny oil on my 01 3.4 Prerunner by just removing the oil pan bolt and was expecting about 4 to 5 liters to drain as told by some of you guys who had done this procedure BUT instead only about and liter and half (1.5) came out. What gives????Idont see any other bolt abound the oil pan???? Help.
  2. Oct 10, 2008 at 6:54 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Pull the dip stick out a little bit to equalize the pressure in the tranny.
  3. Oct 10, 2008 at 7:02 PM
    bajaracer
    Charly
    Chandler
    it was partially removed,,,
  4. Oct 10, 2008 at 7:05 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    To change it a better way is to pull the pan off, and change the filter as well. What part of Phoenix are you in? Maybe I can lend a hand.
  5. Oct 10, 2008 at 7:11 PM
    bajaracer
    Charly
    Chandler
    baseline and 51ave,,, only about 1.5 qts came out,, i am at a friends house in mesa and fear that i mite have messed things up. I poured in close to what came out.
  6. Oct 10, 2008 at 7:18 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I dont think you messed anything up. If you ever feel the need, let me know if I can be of help. :)
  7. Oct 10, 2008 at 7:21 PM
    bajaracer
    Charly
    Chandler
    thanx,, i appreciate your help.
  8. Oct 10, 2008 at 9:24 PM
    VeeRFour05
    VeeRFour05 Active Member
    When you just pull the drain that's all you'll get out. There is fluid in the TC, valve bodies, etc etc. You usually will only get about a quarter to half of the trans' total capacity. You didn't mess anything up. I wouldn't bother droping the filter and changing that unless the fluid hasn't been changed in a while and was pretty dirty.
    Service manual calls for 1.7qts to 2.5qts depending on the trans for a drain and refill.
  9. Oct 11, 2008 at 4:24 PM
    bucs1fan
    bucs1fan Member
    Mount Dora, Fl
    PreRunner TRD SR5
    What is really the best way to change ATF. Drain and Fill, Remove pan and drain and fill, flush and fill. There are so many methods on how to change ATF. I don't get which one is the best.
  10. Oct 11, 2008 at 5:26 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I always remove the pan. Change the filter and fluid that is left. OR, you can have it flushed. Im not sure how I feel about the "Tranny Flush". It does replace 99% of the fluid, but it does so by "Back flushing" the fluid out of your tranny. This can bring the crap stuck in the filter back into the system. BUT, I have no proof of this.
  11. Oct 11, 2008 at 10:13 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    this is how i did mine on my 04.....drained the fluid then dropped the pan. wanted to get it all totally clean. even though i didnt get anything from the torque converter.....now, i'll get a full flush since i cleaned the filter really well.
    also, when i drained mine..........around 5 quarts came out.
  12. Oct 12, 2008 at 7:24 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Now that is precisely what I think is the best. Drop the pan, clean/replace filter, THEN flush the whole thing. :thumbsup:
