AUTO trans gear selector messed up
Discussion in '1st Gen. Tacomas (1995-2004)' started by ywen, Feb 18, 2011.
  1. Feb 18, 2011 at 5:36 PM
    ywen
    ywen [OP] Well-Known Member
    Okay so while the truck was parked in the garage, I put the truck into neutral by means of pushing down the shift lock. Then pushed it back up to Park via shift lock after I was done examining the U joints..
    Now I've noticed that the orange indicator no longer matches up for the various gears. In fact, I was driving in 2nd gear when I thought I was in D. Between Neutral and Drive, there seems to be two indents. What the hell did I do?
  2. Feb 18, 2011 at 6:00 PM
    geoff06
    geoff06 261k and counting
    WI
    '01 PreRunner Xcab lifted
    3" lift, Bilstein 5100/OME coilovers, rear AAL, Swiss camper shell, Rough Country 9000 rear shocks, 265/75/16 AT's on stock steel rims painted black, All-Pro 1.5"F/1.25"R wheel spacers, airbox elbow mod, Flowmaster Super 44, Davico post-cat, I took off my DIY angle iron bed/light bar!, bed wheel well shovel-mount, blacked out grill emblem, Poineer DEH-P3900 head unit, Alpine Type R front component speakers, Pioneer Coaxial rears, Dynamat in door panels, scratchbuilt aluminum holders for my ipod nano and phone, and for some reason, I painted the headlight fillers black...
    maybe if you repeat the shift lock maneuver and match up the shifter with the orange thing, then turn the truck on? :notsure: that might make it stay the right way...
    then again, i ain't sure if the truck will start if it's not in "park". i haven't heard of this happening before
  3. Feb 18, 2011 at 6:35 PM
    Supra TT
    Supra TT Solid Axle FTMFW!!
    Eric
    Lafayette, Indiana
    2000 SAS D60 F/R
    SAS.. Need I say more.
    You can adjust the orange mark on the shifter lever. It's just a 12mm or 14mm nut that you can see holding 2 levers together on drivers side of trans.
  4. Feb 18, 2011 at 10:00 PM
    ywen
    thanks.. do you know of a write up anywhere?
  5. Feb 19, 2011 at 8:48 AM
    Supra TT
    Eric
    Lafayette, Indiana
    2000 SAS D60 F/R
    Nope, sorry
  6. Feb 19, 2011 at 10:29 AM
    ywen
    Okay found out more about the issue.. the issue seems to be that I can shift From d to 2nd without pressing the shifter button(but the orange indicator is on d).. from d to n and from d to 2nd it feels like a 1/2 or 3/4 indent as opposed to the full indent... after shifting from d to 2nd without pressing ths shifter button, if then I press the button and shift down, I get into the actual position for the 2nd gear(where the orange indicator also lines up) any idea what's causing this?
  7. Feb 19, 2011 at 1:03 PM
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    Ive got the same issue not sure what it is but ive thrown it into 2 on accident a few times thinkin it was in drive or just bumping it
