Auto trans not shifting passed 3rd
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jainuss, Nov 22, 2020.
  1. Nov 27, 2020 at 7:26 PM
    #61
    gearcruncher
    Canadain bumper technician
    The computer in your truck has to see the problem occur twice before it will set the code and place the transmission into limp mode .
    We know its full on fluid now , so thats out of the way .
    Can you confirm that it only trips the code when hot ? Are you using anything to watch your transmission temps ? Hows your transmission cooling system ?
    My first thought is your SL2 solenoid is a little plugged up with some debris.
    Use this image to identify your SL2 solenoid
    scocar likes this.
  2. Nov 27, 2020 at 7:49 PM
    #62
    Jainuss
    Jainuss [OP] Active Member
    2013 tavoma prerunner
    Yes only hot
    gearcruncher likes this.
  3. Nov 27, 2020 at 7:54 PM
    #63
    gearcruncher
    Grab this file . This is an aftermarket overhaul manual for your transmission . Far better than a factory manual . Enjoy . That file was expensive when these transmissions were first released .
    Hit up page 16 and check out the diagnostic tree for P0776 . Its going to show you how to check for resistance . You need between 5 and 6 ohms at room temp .
    Next , you can also try a voltage test .
    If both those tests pass , you gotta pull the pan and inspect the SL2 solenoid to see if its full of crap .
    Edit : I am pulling the file .
    sorry guys but I am not dumping the file to non members ..
    I will gladly pass it along to members .
    If you want the file , you gotta join Tacoma World and send me a PM
    Biscuits and syswalla like this.
  4. Nov 27, 2020 at 7:56 PM
    #64
    Jainuss
    Got it
  5. Nov 27, 2020 at 7:58 PM
    #65
    Jainuss
    Is the slt same as solenoid b and is that sonething easy to swap?
  6. Nov 27, 2020 at 8:04 PM
    #66
    gearcruncher
    Under ideal conditions using Toyota,s diagnostic breakdown for solenoids , you do a resistance test next . If the resistance test fails , then we pop the pan off and have a good look at the solenoid . Solenoids can be removed and replaced fairly easy but you gotta follow the diagnostic tree in steps layed out by Toyota .
    Do you have a factory repair manual for your truck ?
    Do you have a digital / volt / ohm meter ?
    Going to PM now
  7. Nov 27, 2020 at 8:07 PM
    #67
    Jainuss
    I have a meter but no manual. What does sonething like this gonna cost at a shop u think
  8. Nov 27, 2020 at 8:18 PM
    #68
    gearcruncher
    I am working on arming you up to fix this . At this point , its easy . Read through that book where it shows the solenoids and how to test for resistance.
    In a shop , minumum $500 bucks . Dealerships wont touch this type of job . Stay away from stealerships please .
  9. Nov 27, 2020 at 8:21 PM
    #69
    Jainuss
    Ok thank you. I just feel super stressed lol
    Bleep100 and gearcruncher like this.
  10. Nov 27, 2020 at 8:22 PM
    #70
    gearcruncher
    At the same time you have the pan and filter off , you carefully check the wiring for cracks and if the insualtion is rubbing on metal anywhere . The internal wiring harness is well known for going bad causing your P0776 code . Its not uncommon for something like this to happen when a transmission service is being performed .
    Why ?
    The additives in your old fluid were depleted . You old fluid worked hard all its life depositing sediments to the bottom of the pan .
    When you introduce new transmission fluid with fresh detergents into the transmission , the fresh detergents can lift old sediments and force them into the solenoids and valve body . Gotta be super clean
    .The good news ..Both issues are an easy fix for a do it yourself guy
    If the solenoid is not plugged , chances are its faulty .
    Here is an aftermarket Rostra solenoid .
    https://rostrapowertrain.com/products/52-0576/
    Rostra also sells the internal wiring harness
    https://rostrapowertrain.com/types/wire-harnesses/?makes=toyota&transmissiontypes=a750e
    This job costs well over $500 in a transmission shop and dealerships would be quoting you for a new transmission $4000 .
    Lets see if we can save you some cash
    TnShooter and Biscuits like this.
  11. Nov 27, 2020 at 8:24 PM
    #71
    Jainuss
    Just sbout the slt?
  12. Nov 27, 2020 at 11:22 PM
    #72
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
  13. Dec 2, 2020 at 11:41 AM
    #73
    gearcruncher
    Jimmyh and TnShooter like this.
  14. Dec 2, 2020 at 2:09 PM
    #74
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
  15. Dec 2, 2020 at 6:27 PM
    #75
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    Always comes thru in a Crunch. :thumbsup:
    Jimmyh and Biscuits[QUOTED] like this.
  16. Dec 2, 2020 at 7:19 PM
    #76
    Biscuits
    :laugh:
    :rimshot:
    FastEddy59[QUOTED] likes this.
  17. Dec 2, 2020 at 7:21 PM
    #77
    gearcruncher
    Not awesome yet gentlemen lol .
    We have to wait 3 days to see if the OP is fixed or not .
    Biscuits[QUOTED] likes this.
  18. Dec 2, 2020 at 7:25 PM
    #78
    FastEddy59
    Eddie
    Used to be we just waited for coloured smoke & called ‘er good. :pout:
  19. Dec 5, 2020 at 6:22 AM
    #79
    gearcruncher
    Good morning Jainuss
    Dude !!
    Its been 4 days . Hows the transmission working ?
    Well ladies and gentlemen of the jury , day 3 is over and no sign of the OP . I have to assume we got him fixed or he would be back screaming at me for wasting his money . :)
    I suppose in the end , no news is good news :fingerscrossed:
    FastEddy59 and 07 sport 4x4 like this.
  20. Dec 7, 2020 at 1:12 PM
    #80
    Jainuss
    Quick update. ive been away for a few days sorry i have not had a chance to get back on and give an update. Was not intentional. I will drive it around for another day or two and report, thanks all and huge thank you to Gearcruncher, this guy knows his stuff.
    Jimmyh likes this.
