auto trans questions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by chilic82, Jan 19, 2009.
  1. Jan 19, 2009 at 4:42 PM
    chilic82
    chilic82 [OP] Well-Known Member
    TX
    07 DC PreRunner SR5
    I have a 07 Tacoma with 30,000 miles on it. Yesterday I went over a speed bump that was headed down hill. When I got back on the gas right after the bump my truck sounded like it reved up and wasn't really going anywhere. It was almost as if it was in neutral. My wife and I both have noticed it in both an 05 and 07 taco's we have owned. Is this just a characteristic of these tranny's or is there something wrong?
  2. Jan 19, 2009 at 4:51 PM
    JimmyCrackCorn
    JimmyCrackCorn Atlanta Falcons
    Cumming, GA (N. Atlanta Area)
    2008 Black PreRunner TRD Sport
    Aero Kit, 3" Lift, 18% All Around Tint, 50% Windshield Tint, MO 957's (Polished), 285/65/18 Terra Grappler's
    Did you come off the ground? [​IMG]
  3. Jan 19, 2009 at 4:55 PM
    Lentsnh
    Lentsnh Well-Known Member
    2007 Hummer H3 Tactical Edition
    None yet- Future: HIDs, Tinted tails, LED interior lights,
    no i noticed if you brake pretty sudden or on a constant firm brake and then press the gas right after you go over, its just the tranny going to the beginning of 1st gear. Assisted Engine Braking
  4. Jan 19, 2009 at 4:59 PM
    Trackmaster
    Trackmaster Active Member
    TRD 4X4
    I know what you mean mine does the same thing. I don't know if it right or not. But I have the same issue 36000 miles.
  5. Jan 19, 2009 at 5:02 PM
    surfsupl
    surfsupl Well-Known Member
    Gregg
    WestCoast
    I DONT CARE IF IT'S A RE-POST
    Rear Diff Breather~ 5100's ~Fog Light Anytime~Tint~TRD Seat Covers~Weather Tech's~Pioneer H.U.~Lift~Eibach Springs~LED's......blah...blah...blah
    My 05 does this but my 09 has yet to show any signs?
  6. Jan 19, 2009 at 5:07 PM
    Lentsnh
    does it do it when your coasting down a steep hill? like slow down really fast or downshift fast?
  7. Jan 19, 2009 at 5:37 PM
    chilic82
    TX
    07 DC PreRunner SR5
    well I have noticed it most when going around a corner fast and getting back on the gas slowly, or over certain kinds of terrain. It sounds like it is hung between 1st and 2nd or in neutral, then when it shifts again it kinda surges forward. I dunno, just haven't had any other truck transmission act like this.
  8. Jan 19, 2009 at 8:55 PM
    carlsv650
    carlsv650 Well-Known Member
    Colfax, NC
    05 PreRunner TRD
    Extra "D" Rings, ARE MX Truck cap carpet lined with entry door. mods to bicycle mounts
    My 05 has problems shifting going down hill. I have to get the RPM's up before it finally shifts into a higher gear. Toyota has sent me two owner surveys over the last four years. I have expressed this issue though the survey in detail but never received any response. Further more I haven't followed up with my local dealer.
  9. Jan 20, 2009 at 4:03 AM
    Lentsnh
    Yeah I know what you are talking about its just the ECU trying to find a good gear... and like I said before it could also be a little bit of Assisted Engine Braking......
  10. Jan 20, 2009 at 4:07 AM
    Lentsnh
    The Tacomas tranny is made more for pulling and handling that immense torque. so instead of shifting all through the higher gears it (family sedans, etc.) the ECU takes hold of that gear until you go UP the hill... Which in most cases you do.
  11. Jan 20, 2009 at 4:12 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    These trucks are kinda weird in how they run sometimes....
    I'll be sitting at a stop light or drive-thru window with my foot on the brake for a period of time. As soon as I let my foot off the brake (no gas), the thing jumps up in idle a good bit. It's weird..... And I know, just sitting still - it idles up, idles down, idels up, idles down....like 500rpm's between the two or more. Turning the fans (no AC) on or off causes it to idle up.
  12. Jan 20, 2009 at 4:14 AM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    12 Tundra TRDRW
    Nada, Zip, Zilch, Nothing
    That sounds good to me...
    x2 :D
  13. Jan 20, 2009 at 5:40 AM
    Bernie
    Bernie Member
    Pa.
    taco access cab TRD sport
    none
    I have an 09 Taco TRD sport with an v6 engine and auto trans. I have the same problem and the bump is not the cause. If I would lift off the gas and coast through a turn and apply the fuel I get the netural feeling with the RPM's going up to 2300 for about 1-2 seconds. It will then shift into low at the hight end. I wish someone would tell me it's normal.
  14. Jan 20, 2009 at 5:47 AM
    106Tacoma
    106Tacoma Well-Known Member
    Debadged 06 Black Sand Pearl 4x4 Every option.
    I drove over a huhe snow bank the other day and when i came off it on the other side my truck did the same thing, i thought it was in neutral. It was wierd! I have 24000 miles on her. Shifts good otherwise.
  15. Jan 20, 2009 at 7:44 AM
    carlsv650
    Colfax, NC
    05 PreRunner TRD
    Thanks for the info. I don't consider this a problem with my Tacoma.How did you come across this information?
  16. Jan 20, 2009 at 6:08 PM
    Trackmaster
    TRD 4X4
    Mine does exactly what everyone is talking about. I just put some new tire's on it and thought maybe they were the cause. But really couldn't figure out why. It was starting to give me a complex LOL. I really enjoy all the great information that is on this site.
  17. Jan 20, 2009 at 6:10 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2005 Prerunner TRD Off Road
    265/75/16 BFG A/T, 18" Magnaflow, K&N Intake Filter, Ultra-Gauge, Kobalt Toolbox, Metal Tail Light Guards, Cobra 19 and 4ft fiberglass antenna, Plasti dipped Badges/lower valance/rear bumper/grill/bullbar/ac controls, black DIN kit, JVC KD-X40, Wet Suit Seat Covers
    I usually just put my truck in neutral when going down hill. But then again Florida only has about 9 hills so...
  18. Jan 20, 2009 at 6:13 PM
    Lentsnh
    its ok guys its normal!!!!
  19. Jan 20, 2009 at 6:13 PM
    Lentsnh
    haha So True!!!
