auto vs. manual mpg
Discussion in '2nd Gen. Tacomas (2005-2015)' started by adub, Aug 15, 2008.
  1. Aug 15, 2008 at 6:37 AM
    adub
    adub [OP] Member
    what are the mpg comparisons for you owners of dc 4x4 v6? I read that autos will get about 2mpgs better at higher speeds. is that correct?
  2. Aug 15, 2008 at 7:30 AM
    TacoCo
    TacoCo Aspiring wrench monkey
    Colorado
    09 TRD Off-Road DC V6 Magnetic Gray
    Snugtop XV Shell, Yakima Rack, AFE Pro Dry Filter, Secondary Air Filter Removed, Michelin AT2's, Partially Debadged, HID conversion, Dynomax Super Turbo Muffler, Rear leaf spring TSB, Foglights always on Mod, URD Short Throw Shifter, Toytec Coilovers on the way!
    Sticker says 19mpg highway on the '09 manuals, and that a range of 16-22mpg could be expected. Highway is 20mpg on an automatic. It all depends on how you drive... high speeds, fast acceleration, etc.
  3. Aug 15, 2008 at 8:17 AM
    Jester243
    Jester243 rabble rabble rabble
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    Just filled up this morning and with all city driving and a healthy dose of a/c i got 17.8. Not too bad!!! :D
  4. Aug 15, 2008 at 10:12 AM
    swervin22
    swervin22 "Obviously, You're not a Golfer..."
    Jonas
    Chesapeake
    2004 Radiant Red Access Cab Off Road
    got a 08 reg cab 4x4, usually get about 24mpg. hardly ever use the ac, and mostly highway driving. i think the automatic would help on the highway, but i really dont have any idea??
  5. Aug 15, 2008 at 1:53 PM
    adub
    adub [OP] Member
    thanks for input. i realize mpg performance has many factors and variables but i have never heard of an auto outperforming a standard. for the most part i figured manuals get better mpg due to control of gearing and what not. i just read where someone was saying this general rule of thumb doesn't apply to Tacos at highway speeds and was confused.
  6. Aug 15, 2008 at 5:03 PM
    Wood
    Wood Well-Known Member
    Comes down to efficiency. The auto tranny in the Taco (and many newer vehicles) is very efficient at torque sensing and keeping you in the right gear without any excessive high rpm shifts, except when you need it of course.
  7. Aug 15, 2008 at 5:04 PM
    beastlytaco
    beastlytaco Well-Known Member
    Ian
    08 Access Cab SR5
    yeah glad i have a I4.
  8. Aug 15, 2008 at 5:17 PM
    08WhiteTRD
    08WhiteTRD Well-Known Member
    Ben
    Rocklin, NorCal
    2008 White 4x4 TRD Sport
    Fox Suspension 2.5 Front and 2.0 Rear, All-Pro Skids, BAMF LCA Skid, Leer 100R, Scangauge II, WeatherTech Floorliners, WeatherTech window visors, Satoshi grill with HomerTaco mesh, Sockmonkey Tailgate Decal, BHLM, Center Console lock, ImMrYo Rear-view bracket, Rally Armor mud flaps, Crawford Eco-Block, USA-Spec PA-15
    I have a 08 dc lb 4x4 auto and I usually get around 18-19 city. I mostly drive it to work and thats about it. I dont' really drive it that hard though so I think that kinda helps.
  9. Aug 15, 2008 at 5:51 PM
    Ridingontrd
    Ridingontrd Well-Known Member
    Richard
    Laughlin,N.V
    trd sport 4x4 w/towpkg
    aFe prodry,Dynomax ultra flo ss,Scangauge2,Demello front bumper,BudBuilt skids,sliders(local)AllPro rear bumper,Wet O's cobalt blu,w/halfpiping,TRD logo in gold,R/L hood struts,5150's@10"aal 3 pack,T/C uca,Light racing c/o,1"diff.drop,de-badged,
    The auto's over drive is taller then the man. :)
  10. Aug 15, 2008 at 9:55 PM
    MikeS.
    MikeS. Well-Known Member
    Far Eastern WVa
    2008 DC LB 4x4 in Speedway Blue.
    Undercover bed topper, Nerf style step bars, Python alarm, Ham radio with 250 watt amp and chrome wheel well bling.
    I'm getting high 22 - low 23 mixed hwy/city in mine.
  11. Aug 16, 2008 at 11:03 AM
    4x4x4trd
    4x4x4trd My other ride weighs 200 tons
    North Texas
    08 White Access Cab TRD OR, Debadged
    AFE oil free drop in, Secondary removed, tint, front D-rings, Toyota bed mat, Undercover tonneau, TRD seat covers and floor mats, Pioneer speakers, Westin Platinum bars, Fumoto oil valve, short antena, Nifty Xtreme's, TSB leaf springs, Bilstein 5100's set at .85" in the front
    Just got back from a 1200+ mile road trip. Not loaded very heavy and mostly highway and hills in the Ozarks of MO.
    Averaged 19.6 mpg for the whole trip with 20.9 being the best tank while driving 70-75 on the highway with the AC turned on and hills and stop and go in Branson.
  12. Aug 16, 2008 at 12:03 PM
    Evil Monkey
    Evil Monkey There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
    It's not an efficiency issue. The manual is geared different than the auto (much taller). If I cruise at 2000 rpm, I'm only going about 55-60 mph whereas an auto will be doing close to 65-70.
    Manual
    First Gear Ratio :)1) 4.17
    Second Gear Ratio :)1) 2.19
    Third Gear Ratio :)1) 1.49
    Fourth Gear Rato :)1) 1.19
    Fifth Gear Ratio :)1) 1.00
    Sixth Gear Ratio :)1) 0.85
    Automatic
    First Gear Ratio :)1) 3.52
    Second Gear Ratio :)1) 2.04
    Third Gear Ratio :)1) 1.40
    Fourth Gear Rato :)1) 1.00
    Fifth Gear Ratio :)1) 0.72
  13. Aug 16, 2008 at 1:23 PM
    TacoCo
    Colorado
    Can you explain this a little better? If I'm cruising at 2500 RPM's in 6th gear with my manual, I'm at about 75mph. My old '98 4Runner would be at about 3000 RPM's in 5th gear @ 75 mph, so I would think the Taco is more efficient? I get about 20 mpg on the 4Runner, but haven't burned through a full tank on the Taco yet.
  14. Aug 16, 2008 at 5:36 PM
    Evil Monkey
    Robert
    Escondido, CA
    The old 4Runner is a smaller vehicle and it's a different engine so you can't really compare the two. When comparing the two Tacomas everything in the truck is the same (about the same weight, same aerodynamics, same engine, etc). The only difference is the gearing. Optimal gas mileage is acheived on our trucks when the RPMs are below 2000. Once you go over 2000 rpm, gas mileage starts to suffer. So, because of the gearing, the engine on the manual has to turn faster than it would on the automatic to achieve the same speed. As a result, it's gas mileage is going to be lower than the automatic. It will also have a lower top speed than the automatic. The upside is the manual will have better torque at low speeds and the automatic's engine would lug a little more (if you had two Tacomas running at 70 mph, I would expect the manual would be able to accelerate to 80 slightly faster, but it would also top out sooner).
    Think about it like a 10-speed bike. If you have two bikes that are identical and one person runs in 5th gear (smaller gearing up front), whereas the other runs in 10th (larger gearing up front), the rider using 10th gear will be turning the pedals slower at any given speed. As such he can go faster with equal effort.
