Auto vs Manual which one is stronger?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jtgroce, Apr 21, 2012.
Auto or Manual which is more reliable?
  1. Auto
    550 vote(s)
    51.4%
  2. Manual
    521 vote(s)
    48.6%
  1. Apr 25, 2012 at 5:43 PM
    #81
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
  2. Apr 25, 2012 at 5:49 PM
    #82
    jandrews
    '09 FourDubDee TRD OR
    The manual trans in these trucks had some trouble in the 05's and very early 06's with shift forks taking a shit. You can read about one such rebuild caused by this problem here: The nice thing about manual trannies is that they're relatively easy to rebuild, compared to autos.
    That said, since late '06 ToMoCo changed the construction of some of the components and I'd now call the two transmissions equal in terms of durability.
  3. Apr 25, 2012 at 6:02 PM
    #83
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    I would say that they are pretty close these days, in reliability and stregnth. The manual takes more skill to drive, and is easier to repair. The auto is easier to drive, but has more moving parts, requires more specialized tools to repair, damages more components when it fails, and is more expensive to rebuild. So, I will keep on driving my manuals. I like to hold on to my money. Everything fails after the warranty anyways.
  4. Apr 25, 2012 at 6:06 PM
    #84
    sudafed
    sudafed Well-Known Member
    It's the planetary out of the t-case......which is the same exact spline count and size as the output shaft in the tranny....;)
  5. Apr 25, 2012 at 6:09 PM
    #85
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Thats not a very accurate way to decide which tranny is stronger.
  6. Apr 25, 2012 at 6:20 PM
    #86
    Brody133
    Brody133 Member
    Brody
    Jonesborough, TN
    2011 Toyota Tacoma Acc. Cab Short Bed 4x4 SR5
    Bone stock.
    Speaking of two stroke dirtbikes... man I love my 2 smoke!
  7. Apr 25, 2012 at 6:21 PM
    #87
    sudafed
    Speaking of trannies I love trannies!
  8. Apr 25, 2012 at 9:15 PM
    #88
    Monkeyboy
    Monkeyboy Well-Known Member
    Grand Junction, CO
    2012 AC TRD Sport
    THUNDERDOME!!!!!
  9. Apr 25, 2012 at 9:20 PM
    #89
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    LOL!! Two trannys in....wait....nevermind.
  10. Apr 25, 2012 at 9:39 PM
    #90
    Brody133
    Brody133 Member
    Brody
    Jonesborough, TN
    Bone stock.
    Mine's an 09! What do you ride?
  11. Apr 25, 2012 at 10:24 PM
    #91
    BlazeTaco
    BlazeTaco Well-Known Member
    PA
    4.0l 6sp SR5
    TRD Exhaust TRD Filter
    An auto trans has multiple wet clutch packs similar to your motorcycle clutch and friction bands. That is how it switches between gears. When you come to a stop the torque converter uncouples for the most part and allows the turbine and pump to spin freely. This is why there is the stall rating on torque converters, this is the speed at which it has the greatest coupling force. But they never lock 100 percent. That is why there is another clutch in the torque converter that locks it for better efficiency. An auto can go bad really quick if overheated or incorrectly shifted ( like a stuck shift solenoid) typically the clutch packs burn up. Both stick and manual transmissions are fairly strong as long as they are properly maintained or have no failures. But the automatic would probably be the most expensive to fix and most complicated to fix.
  12. Apr 25, 2012 at 10:32 PM
    #92
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Where do you run a cooler from on an auto tranny?
  13. Apr 26, 2012 at 12:52 AM
    #93
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    I never thought of it that way, but it is sad to see the MT and 2 stroke dying out. Even though I ride a 4, if the right KTM or Gas Gas smoker came into my hands, I'd get one!
  14. Apr 26, 2012 at 4:48 AM
    #94
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
  15. Apr 26, 2012 at 9:27 AM
    #95
    Mikk
    Mikk Active Member
    Nevada
    2011 Reg. Cab, Auto, 4x4
    K&N CAI, Magnaflow muffler, Xenon (non-HID) high/low, Reese aftermarket reciever/plug n play 4 pin, "Taco" badge, 4x4 mud flaps and no further markings Bilstein 5100's at all 4 corners - struts set at 2 inches taller, rear stock height. Magnaflow Exhaust, K&N intake, Husky box carpeted w/LED lights - secured by pros, mounts for AR15.
    I HATE changing gears in 4low. Also, I think F1 cars run automatics, Coke and Pepsi, even some of the newer UPS rigs run autos.
  16. Apr 26, 2012 at 9:42 AM
    #96
    Mikk
    Mikk Active Member
    Nevada
    I waited a long time To find a 6spd I wanted. I enjoy every aspect of it and really like feeling connected to the truck.
    My daughters are learning to drive now and I am insisting they learn to drive my truck too.
    Straight drives are becoming a lost art. I want them prepared to drive anything.
    Oh and BTW. While it sucks to lose a clutch in BF nowhere, Ive taught my daughter how to push start it in case of a low battery.
    Try to do that with your slush box.
    Yes a downside of auto. But I run nothing but optima red top, and when my starter makes noise (of the breaking variety) it is replaced. People don't realize if your battery is too dead to support FI, still not going to start; bump or otherwise.
  17. Apr 26, 2012 at 12:22 PM
    #97
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    On the output line from the transmission. The one inside the radiator regulates the temp of the fluid in this configuration. This way, it reaches operating temp faster. Putting on the return line shoud only be done on a "desert only" vehicle.
  18. Apr 26, 2012 at 12:27 PM
    #98
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    Usually the starter will fail before the FI, since the starter draws many more amps than the pump. Also, residual fuel pressure combined with a partail field on the alternator should be plenty to start a normally driven manual.
    A totally dead battery? Auto/manual=screwed without a jump.
  19. Apr 27, 2012 at 4:19 AM
    #99
    LeftyTom
    LeftyTom Well-Known Member
    Yadkinville NC
    2011 Tacoma AccessCab, 2WD, 5spd, SR5
    I prefer the manual trans, as it seems to have a bit more take off (without accelerating hard) than an auto transmission.
    I like to keep my shifting skills sharp, as getting a rental car with an auto trans (at least) doubles the cost in Ireland. One does not need to be fighting jet lag, driving on the left side, AND a manual trans. Not to worry, as the first 2 are old hat after the first holiday.
  20. Apr 27, 2012 at 5:57 AM
    #100
    Dragons Taco
    Dragons Taco Well-Known Member
    Derek
    Cary/Raleigh NC
    06 Black TRD-S 4WD 4D 6SPD and MINE!
    Can ya spell Tonneau
    No, but computer controlled. Multi disc clutch packs long before it was fashionable. Now you can get most sportscars that way, and diesel VWs for that matter.
