Automatic shifter problem
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Sideways, Jul 22, 2010.
  1. Nov 30, 2013 at 8:23 AM
    Coolerman
    Coolerman Well-Known Member
    Dan
    Rochester, NY
    2005 4x4 SR5 AC / 2007 4x4 FJC / 2021 Tesla Y
    Pro/2015 Coil-overs n shocks, Icon progressive AAL, Firestone Ride-Rite Air Bags and cradles, ECGS clamshell bushing, Extang Solid Fold Tonneau cover, 2014 Navigation radio and backup camera, Wet Okole seat covers, rcbs204 lighted 4x4 switch, Weathertech digifit floor mats and in channel window vents, Scanguage II, Hayden 678 Trans cooler, Western Suburbanite plow, Pop and Lock PL8521
    I have this exact same problem/symptom. I will be trying the fix Kirk used.
    I hope it works!
    Thanks Kirk +rep incoming. :)
  2. Nov 30, 2013 at 9:18 AM
    kirkofwimbo
    kirkofwimbo Well-Known Member
    Clayton
    Wimberley, TX
    ‘21 Tundra SR 4x4
    Woot! Glad it helped :)
  3. Feb 24, 2014 at 10:26 AM
    cliffhanger4
    cliffhanger4 Member
    Paul
    Toronto Ont Canada
    2005 Toyota PreRunner TRD
    I have a 2005 tacoma that has the same trouble. What I discovered the problem is a connector down in the left hand kick panel by driver left footI had this issue last year and doing some research this is what I discovered.And I mentioned it to a toyota mechanic this year when he was doing a oil change for me ( to cold out for me to do) and he confirmed that is where the problem is, he was a little shocked that I new about it! It seem to happen to my truck in the winter after a rain or car wash. There is a junction box that get damp and messes up the signal to the tranny so it would allow it to shift. I have to do mine again this week and will take some pictures. All you need to do is spray contact cleaner on the connector and the junction box I have had to do this 3 times now (this junction box allows 2 different connectors to be put together). The 1 post I found last year said the only way to totally fix this is to put in a updated wiring harness that is sealed better going through the firewall.
  4. Feb 24, 2014 at 10:45 AM
    Utard
    Utard Well-Known Member
    Mark
    Tidewater, OR
    2019 Tacoma SR5
    Maybe a stick or rock was in the linkage underneath?
  5. Jun 19, 2016 at 11:14 PM
    BohlaaH
    BohlaaH Loading...
    ALEX
    Thunder Bay, Ontario
    2015 TRD Sport DCLB
    Rigid Industries Grille and 20' fitted LED bar 6" BDS Lift w/ FOX 2.5 (front) FOX 2.0 (rear) 35x12.5 TOYO M/T Open Country Tires Fuel Assault 18" Wheels OPT 7 LED 9003 Headlight Cut Cab Mount & Pinch Weld Trimmed Fender Flares 4.88 Yukon Gears ARB air locker Front & Rear Dent in Driver door... Relentless Fab CB antenna hood mounts Rigid Industries Dually "Amber" spot lights Adventure Offroad Fabrication Overhead Console OTTRAW Switch Mod
    Just had that in my 2015. Good homework! I will be calling about that part
  6. Jan 7, 2017 at 7:39 AM
    MHDutle
    MHDutle Member
    Newport, KY
    05 Tacoma 4X4 Automatic
    My 2005 Tacoma has the same problem. Following a rain and then snow and bitter cold (10 deg F), the shifter wouldn't move and the truck wouldn't start. Had it towed to Toyota Service, and they were able to get the shifter into neutral (it probably thawed) and they lubed the cable and "associated parts". No charge! They said it was all rusty in there and that I should have them check on it when I bring it back for service. I'd like to do this myself if someone could give me some detailed instructions (or point me to a video) on how to get to the cable and "associated parts". I just juiced up my steering universal with white lithium grease, so maybe that would work well on the shifter problem, too.
  7. Apr 2, 2017 at 8:13 AM
    nobescare
    nobescare Well-Known Member
    Mark
    43.5448° N, 80.2482° W
    2019 Highlander SE
    My 2005 prerunner had frame failure Aug 2024
    I know this is an old thread but I just ran into the exact same problem. Thanks for the pics and info kirk.
  8. Apr 5, 2017 at 11:04 AM
    Coolerman
    Dan
    Rochester, NY
    Mine ended up needing to have the Park neutral safety switch replaced. The problem was resolved on my truck after the switch was replaced.
    nobescare likes this.
  9. May 30, 2017 at 1:23 PM
    Tac Woman
    Tac Woman New Member
    2007 Silver quad cab V6 4X4
    Coolerman - what did they charge to replace that switch? My 07 started having this problem last winter - worse when it sits, worse when it's been wet - better with the warmer weather. I pulled the connector apart under the left foot panel and "aired it out" seemed a little better but could be my imagination! Will try the centre console and see what happens - hope for the best would like to know cost to replace the switch. Thanks!
  10. May 30, 2017 at 1:26 PM
    Coolerman
    Dan
    Rochester, NY
    I don't recall the actual cost, it was a few years ago. I'm guessing it was a couple hundred bucks. The problem has not returned since the repair was done.
  11. May 30, 2017 at 1:30 PM
    Tac Woman
    OK - thanks!
  12. May 31, 2017 at 6:31 AM
    nobescare
    Mark
    2019 Highlander SE
    Just a follow up to this. the linkages from your shifter down to the trans will require greasing as well. what i did was have someone shift the transmission from park thru all 5 gears. as that was done i was underneath spraying grease into all the moving parts/links (there's linkages on both sides of the transmission fyi). just make sure when you do this that you put the parking brake on and block your tires.
