automatic "slapshift"
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jeeezy, Feb 6, 2011.
  1. Feb 7, 2011 at 10:35 PM
    #41
    Super Werty
    Super Werty Sleeper 4x4
    Arizona
    07 TRD Tacoma
    air and fuel
    it's not a built trans. Just a modified valve body. Quickens and firms up the shifts. ;)
  2. Feb 7, 2011 at 10:47 PM
    #42
    jeeezy
    jeeezy [OP] jeeezy
    Jesse
    Timmins
    07 dbc long box speedway blue
    custom cold air intake 4 inch tubing, MBRP dual catback exhaust, readylift leveling kit with 265/75-17 on eagle alloy rims
    now it gets technical
  3. Feb 9, 2011 at 10:17 PM
    #43
    pinktaco808
    pinktaco808 Hot Steppa
    up more info on this
  4. Feb 9, 2011 at 10:18 PM
    #44
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Picccssssss
  5. Feb 10, 2011 at 8:04 PM
    #45
    jeeezy
    jeeezy [OP] jeeezy
    Jesse
    Timmins
    pics of what?
  6. Feb 10, 2011 at 10:52 PM
    #46
    OZ-T
    Peter North
    British Columbia
    Exactly
  7. Feb 11, 2011 at 5:41 AM
    #47
    pinktaco808
    so when you shift do you let go of the gas or just holf gas and shift????
  8. Feb 11, 2011 at 6:09 AM
    #48
    BritMike
    BritMike Well-Known Member
    NJ
    10 Black TRD OR
    Reading the A750E/F tech manual there's a couple of other things that only work in Drive (assuming the systems are the same as the tundra as I can only find the A750E/F tech manual wrt the tundra).
    One is AI-Shift and the other is Accel/Decel Flex Lock up.
    AI-Shift is designed to be cleverer about shifting on up and down slopes and Flex Lock is meant to improve mpg.
    If you're shifting manually you don't care about those systems as you're making those decisions for the transmission.
  9. Feb 11, 2011 at 6:22 AM
    #49
    Who Dat Popcorn
    Who Dat Popcorn Dafuq
    Ricky
    Richmond, VA
    Sold :/
    SOLD
    Hold gas. Just don't downshift while holding gas, lol.
  10. Feb 11, 2011 at 3:20 PM
    #50
    jeeezy
    jeeezy [OP] jeeezy
    Jesse
    Timmins
    i usually let go?
  11. Feb 11, 2011 at 3:27 PM
    #51
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Correct. And for those that dont know about the "Flex Lock up", it allows the torque converter to lock up either partially, or fully in 4th and 5th gears.
  12. Feb 11, 2011 at 3:36 PM
    #52
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    No. Only 4th and 5th. It might be able to lock in 3rd, but I cant find my notes on this.
  13. Feb 11, 2011 at 3:39 PM
    #53
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    aThe only ones I know of that lock in other gears, are heavy duty/industrial trannys. And those wont lock in first. The tranny in my Moms Cummins can lock in 3rd up thru 6th, but I dont think other trannys for light trucks do the same. My Buddies alison locks in 4th thru 6th.
  14. Feb 11, 2011 at 10:23 PM
    #54
    pinktaco808
    do you loose gas mileage like this??? if you shift up from low gear 3,4 Drive
  15. Feb 11, 2011 at 10:31 PM
    #55
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
    probably considering how much time and effort toyota or any other dealer puts into the timing of the shifting in automatics in order to make them as fuel efficient as possible
  16. Feb 12, 2011 at 5:34 PM
    #56
    pinktaco808
    i thought so, so slap shifting is only for down shifting????
  17. Apr 6, 2011 at 10:58 PM
    #57
    pinktaco808
    doesnt your gas drop much faster with upshifitng instead of d
  18. Apr 6, 2011 at 11:29 PM
    #58
    RedTaco2134
    RedTaco2134 Well-Known Member
    Scott
    Portland, Or
    08 Long Bed TRD Sport
    295/70/17 Cooper STT Pro, Revtek 3" lift. TSB rear and Blistein 5100's http://www.cardomain.com/ride/3097063
    I never use "D" unless I am on the highway. In town and mostly everywhere else. I use "4" and I frequently drop to 3. Seems to be just fine, although it d the tranny does have a little more slip ever since the 33's, I can feel the loss of power too and the 3.73's are much to high of gears to be running...wish I had at least 4.10's, more like 5.13's and 37's lol
  19. Nov 14, 2011 at 2:41 AM
    #59
    SPORT55
    SPORT55 Well-Known Member
    Clinton, N.Y.
    2011 Double Cab TRD Sport Black
    I find that in town and city driving at speeds of about 40ish and less are better in 4 , you have better throttle response and available power on tap, but once I get to 45ish or on the freeway I slap it back to D... Been driving like this for about 1500 miles now and I'm averaging about 17 miles a gallon (mostly city mpg)..also it gives my TRD exhaust a deeper tone and it feels more spirited driving....
  20. Nov 14, 2011 at 3:39 AM
    #60
    NC15TRD
    NC15TRD Well-Known Member
    Nick
    PA
    16 Sierra SLT All Terrain
    Readylift, Truxedo, Husky Liners, Carven
    ZOMBIE THREAD!
