automatic tailgate lock quit working
Discussion in '2nd Gen. Tacomas (2005-2015)' started by comtntop, Aug 15, 2012.
  1. Aug 15, 2012 at 3:47 PM
    comtntop
    comtntop [OP] New Member
    I have a 08 tacoma 4 door. the tailgate lock has quit working. all the other doors seem to be working normally regardless of whether I use the key, the clicker or the two door lock switches on the front doors....
    any ideas how to fix?
    tks
    dave
    boulder,co
    (new to forum)
  2. Aug 15, 2012 at 3:48 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    Stock tailgate lock ? No such thing
  3. Aug 15, 2012 at 3:49 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    X2. Must be a pop n lock.
  4. Aug 15, 2012 at 3:49 PM
    Taqoma
    Taqoma Well-Known Member
    Brennan
    Los Angeles
    2011 TRD Off-Road
    TRD Supercharger, TRD CAI, Camburg LT, Fox 2.5x8 coilovers, Fox 2.0 bumps, Deaver e30 leafs, Fox 3.0x18 triples, Avid sliders, Yaesu 2900R, Pro Comp 7089 16x8, DDM 55w HID Hella 500FF, DDM 35w HID headlights, Magnaflow 11255 muffler, PLX DM-100 OBDII, Autometer Ultra-Lite II Boost gauge, Flex Pod gauge mount, LSK tube bumper, McNeil fenders, Fiberwerx bedsides, 285/75/16 Toyo MT's
    maybe he bought it used and the previous owner installed the electric pop n lock?
  5. Aug 15, 2012 at 3:51 PM
    OZ-T
    Peter North
    British Columbia
    It could be a pop n lock
  6. Aug 15, 2012 at 4:21 PM
    Raylo
    Raylo Well-Known Member
    MD, USA
    2023 Tundra SR5 OffRoad; (2009 Tacoma - sold)
    All stock, except for audio and convenience add-ons
    Maybe a Dynolock electric. These have been available longer than the P&L variety. In any case just pull the plastic tailgate panel then check that you are getting voltage to the lock actuator on lock/unlock call. If yes, replace the actuator. If not, find the break in the wire supplying the +12v. Also check the ground.
  7. Aug 15, 2012 at 4:54 PM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    It probably just needs to be cleaned and a little WD40 or if someone tries to open the tailgate when its locked they can bend the assembly causing it to jam. Screw off the tailgate top cover and take a look, you should be able to put your hand in and reach the assembly. Just give it a little push while you press the remote.
