AUX port is not working
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 336tacoma, Aug 12, 2013.
  1. Aug 12, 2013 at 9:48 AM
    336tacoma
    336tacoma [OP] Active Member
    NC
    TRD SR5
    15% tint on rear, 35% tint on front, delta low-pro tool box, 5k HID hi-lo and fogs
    I have a 2010 tacoma, and the AUX port only works for a few seconds then switches over to the radio. When I purchased the truck from Brown Toyota, this was not in its spot. Any suggestions on how to fix? I've tried multiple aux cables and different iPhones, so I've ruled that out for the problem.
    Thanks!
  2. Aug 12, 2013 at 4:49 PM
    336tacoma
    NC
    TRD SR5
    anyone?
  3. Aug 12, 2013 at 5:01 PM
    ziggynagy
    ziggynagy All Glory To The Hypnotoad
    Stoughton, MA
    '11 Sport AC 4x4 V6 Auto Tow
    Westin step bars, led dome & map lights, tailgate hoseclamp, BluLogic, MetalMiller emblem, 35 tinted front windows, extra OEM d-rings, WeatherTech front/rear
  4. Aug 13, 2013 at 9:01 AM
    rhavin42
    rhavin42 Well-Known Member
    Vladimir
    Phoenix, AZ
    09 DC LB SPORT 4x4
    I recently fixed the AUX port in my sisters tundra. Her issue was she had to wiggle the cord around and the AUX port would work for a few seconds then switch back to radio.
    What I ended up doing was pulling the aux port out and resoldered all the connections to the PCB. (Almost all of the solder joints on the PCB had broken)
    Don't know if this is the same as your issue, but it'd be worthwhile to just pull the AUX connector and take a look at the solder connections.
  5. Aug 20, 2013 at 2:04 PM
    Ghumps
    Ghumps Well-Known Member
    how do you take it out?
