FS: Auxiliary fuse and relay block mount $89
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by switch, Oct 24, 2022.
  1. Oct 24, 2022 at 9:15 PM
    switch
    switch [OP] Well-Known Member
    Norther California
    2022 Tacoma Access Cab
    If you want to add a waterproof relay/fuse block (sold separately) to your 2016-2022 Toyota Tacoma, you can achieve a factory (OEM) look with these custom 3D printed mounting brackets.
    I designed these mounting brackets for an auxiliary relay/fuse block on my 2022 Tacoma because I wanted a solution that was waterproof, safer, and more reliable than the most popular alternative available. I also wanted my relay/fuse block to look like it was installed by Toyota.
    The most popular alternative is a Blue Sea fuse block mounted on a metal bracket.
    My design is waterproof and does not obstruct access to the Toyota Relay Block #2. It provides for a low voltage shut-off and does not waste space with mounts for grounding wires because:
    1: there are plenty of factory grounding points located throughout your truck.
    2: there is a ground point right next to the battery about 1 foot from the location of the fuse block.
    This mounting bracket set has four pieces:
    1: Factory Relay Block #2 relocation mount. This bracket repositions the existing relay block between the power steering assembly and body, to make room for the new relay/fuse block that goes next to the factory main relay/fuse box. This location ensures accessibility of the factory relay block #2 and does not excessively bend or stretch the cables to the relay block.
    This mount relocates the factory Relay Block #2 to this location
    2: Mounting bracket for a 100A breaker (to be wired between the battery and the auxiliary relay/fuse block). This bracket clips into the existing factory main relay/fuse box.
    https://www.amazon.com/gp/product/B08TWSBPW7?ie=UTF8 (~$18 sold separately)
    This breaker mount fits directly onto the factory primary fuse block
    Before:
    After
    3: A two part mount for the relay/fuse block
    This mount fits this relay/fuse block directly:
    https://www.amazon.com/gp/product/B07MR64XK1?ie=UTF8&th=1 (~$22 sold separately)
    and the Auxbeam 8 Gang Switch Panel: https://www.amazon.com/gp/product/B07KZLB74K?ie=UTF8
    It can easily be adapted to support any relay/fuse block of similar dimensions (7"x4"x3"); including the popular
    Blue Sea Systems ST Blade ATO/ATC and Bussmann RTMR Fuse Blocks by using an optional adaptor plate.
    a: The lower part fits the contours of the engine bay and requires only one hole to be drilled. The lower part mounts an optional Smart Battery Protect (low voltage cut off switch) to prevent accidentally draining your battery:
    https://www.amazon.com/dp/B07MXG5XZ4?ref=ppx_yo2ov_dt_b_product_details (!$60 sold separately)
    b: The upper part adds additional space under the relay/fuse block to conceal wires that may need a little slack under the relay/fuse block.
    Stainless steel mounting hardware included.
    100A (OR 60A) breaker: https://www.amazon.com/gp/product/B08TWSBPW7?ie=UTF8
    Smart Battery Protect (optional):
    In summary, with this option, you get a mount for a waterproof fuse/relay block, a relocation mount for the factory Relay Block #2, and a breaker mount. There are no sharp edges for potential shorts, no wasted space on a negative bus, access to the OEM Relay Block#2, and a professional looking finished installation.
    This kit includes mounting brackets and hardware for the items listed above (but does not include):
    Relay/fuse block:
    OR
    All wires, ring terminals, grommets, heat shrink tubing specific to the relay/ruse box you decide to use.
    You can see more photos and details here
    Please note that before you order this mounting bracket kit, you should already be familiar with the tools and skills required to assemble the Fuse/Relay box. If you are not sure, order the Fuse/Relay box before you order this mounting kit.
    Also compare your engine bay to this photo which shows where my fuse/relay mount kit fits
    I used this fuse/relay mount
    It can power up to 6 fuse and 6 relays
    I've also mounted the Auxbeam for another customer
    As featured by Chloe Kuo on YouTube:
    https://www.youtube.com/shorts/QVErIO-pSwk
    https://www.youtube.com/watch?v=Kd7Yuisq7dE&t=7s
    For sale on Etsy:
    Or message me on TacomaWorld to use PayPal
    Includes free shipping to US48
    Installation PDF is attached to this post.
  2. Oct 24, 2022 at 9:24 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission 5.29 R&P FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Bed Light Kit VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Customized 2WD Low Operable (Switched) Clutch Safety Bypass
    I wish this would work with the manual transmission (or maybe it does?). I don’t think it will based on where the relay box gets relocated to (pretty sure the clutch master cylinder hard line is in the same space). Otherwise I’d love to buy.
  3. Oct 24, 2022 at 9:31 PM
    switch
    Norther California
    Send me a photo of your manual transmission engine bay. This would have worked on my 2006 manual Tacoma.
  4. Oct 24, 2022 at 9:39 PM
    BLtheP
    Plano, TX
    Maybe it’ll work, but I doubt it.
    The Off-Roads and Pros have the reservoir on the fender which puts that rubber hose running straight. Then there’s the hard line going to the trans.
    The Sports have no reservoir, they pull from the brake master cylinder res. So they have a curved hose routing, and I believe the hard line is the same the way it sticks out and then curves down to go to the trans.
    It seems like my reservoir and my hard line/hose will all be problems for this setup. Unless the relay box gets relocated higher than I think it does. Not sure about the reservoir still though.
  5. Oct 24, 2022 at 10:02 PM
    switch
    Norther California
    Yeah, that looks like a show stopper. I had no idea Toyota did that. I have a 2022 TRD Off-road Automatic. This part of the engine bay is wide open on my 2006 manual trans Tacoma too.
    Mr. Excitement likes this.
  6. Oct 24, 2022 at 10:04 PM
    BLtheP
    Plano, TX
    Bummer for sure! Probably going to resort to a powertrays or similar. Not terrible but certainly more wire running and custom organization I’ll have to do.
  7. Oct 25, 2022 at 12:25 AM
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    Nice work OP, lots of good stuff from you.
    Chasespeed likes this.
  8. Oct 25, 2022 at 6:57 AM
    flat_tire
    flat_tire Well-Known Member
    Independence, KY 41051
    2016 Tacoma TRD Off-road ACLB blue, 2018 Tacoma TRD Sport DCSB white, 2020 supercharged Tacoma Limited DCSB magnetic grey metallic, 1993 AMGE HMMWV, 1993 Ford Mustang GT 5.0 supercharged
    2020 Tacoma: Icon stage 9, Magnuson supercharger, URD full exhaust, solar 2018 Tacoma; OME 2in suspension 2016 Tacoma: Falcon front and rear rate adjustable suspension, rear airbag lift
    Really incredibly awesome work!
  9. Oct 25, 2022 at 5:13 PM
    Mclovin80
    Mclovin80 Not Well-Known
    Tampa, FL
    2021 LR TRD Pro
    This is a really clean set up. I want it all, take my :spending: and send me the whole bag of tricks :D
  10. Oct 25, 2022 at 6:20 PM
    c_walters
    c_walters Well-Known Member
    Mooresville, Nc
    2019 TRD Sport 6MT MGM
    Can’t go one day without needing something else for this daggum truck…
    Kolache007 and Mclovin80 like this.
  11. Oct 25, 2022 at 6:35 PM
    switch
    Norther California
    Thanks!
    Just FYI: these take 15 hours to print. I'm printing these as fast as I can and will update stock on Esty when I'm done with the back log.
    daveeasa and Mclovin80[QUOTED] like this.
  12. Oct 29, 2022 at 2:13 PM
    switch
    Norther California
    I looked at some old photos of my 2006 Tacoma & I'm pretty sure these mounts will work on 2nd gen Tacomas too, The only part I'm not sure about is the way my break mount clips into the factory fuse block.
  13. Nov 4, 2022 at 9:04 PM
    switch
    Norther California
    adding more pics
    Complete set of parts
    Main fuse/relay block mount. This fits Auxbeam and this Fuse/Relay Block.
    Extra spacer for this Fuse/Relay Block not need for Auxbeam.
    Relocation mount for Factory Relay Block #2
    Parts fit together for Auxbeam configuration:
    Parts fit together for this Fuse/Relay Block configuration:
    Mclovin80 likes this.
  14. Nov 4, 2022 at 9:18 PM
    daveeasa
    David
    PNW
    I can get photos of my 2005 but it’s MT so probably a no go?
  15. Nov 4, 2022 at 9:50 PM
    switch
    Norther California
    I put an entire axillary battery next to the fuse block of my manual 06.
    see Taco_Dual_Battery_Figure_2a_858aaf778d9203aac5eb83f9de0ed01cbe99df28.jpg
    If you have this much space on your 05, then my mounts would fit just fine. The open question is will the breaker mount work?
    What does this look like on your Taco factory fuse box?
    my kit uses this location for the breaker mount
  16. Nov 4, 2022 at 10:07 PM
    daveeasa
    David
    PNW
    I’ll get some better photos once I have it back. It’s on a 2 week timeout at shop #2 after shop #1 trashed the collars on my brand new 2.5’s.
    I have some similar blue sea circuit breakers but the kind you install with a hole saw. And some marine board with holes ready to go, as well as a compressor bracket to mount it to. I thought it’d be a tiny bit cleaner than the panel mount to have the studs physically protected. But your solution is fantastically more compact and looks nice.
    My 2nd Gen is meant to be a “minimalist” build so I’m trying hard to not go too crazy, but that’s an easy battle to lose.
    One other odd preference of mine, I really do like dual batteries with the aux on the passenger side to help even weight out.
  17. Nov 6, 2022 at 10:23 AM
    Mclovin80
    Tampa, FL
    2021 LR TRD Pro
    Loving this set up with my Auxbeam 8
    switch[OP] likes this.
  18. Nov 8, 2022 at 9:36 PM
    switch
    Norther California
    Great to see that the Auxbeam8 setup worked out so sweet! When you first reached out to me about that, I wasn't sure & I'm glad I took the time to modify my design to work with the Auxbeam 8. If anyone has a different fuse block they want to use, message me & I'll see if I can make this work. I'm pretty sure it will work with Bussman fuse blocks but supply issues have prevented me from getting one.
  19. Nov 9, 2022 at 4:48 AM
    Mclovin80
    Tampa, FL
    2021 LR TRD Pro
    I appreciate the design work you have put into this.
    Side note/suggestion: I might turn the Auxbeam backward facing the firewall, because the space between the smart battery protect and the slots to run +/- wires through is tight. Adding side tabs to the square spacer to mount the Auxbeam higher would solve this issue. I can send pictures if needed.
  20. Nov 11, 2022 at 9:01 AM
    clock11
    clock11 Well-Known Member
    Aaron
    Southern California
    2020 White TRD Off Road
    Deaver Stage III, Icon Stage 3 (minus Icon leafs), BFG K02s, Prinsu roof rack, Diamondback HD, CaliRaised Ditch lights and Brackets, Clazzio Seat Covers, Rearseat 12v Power & USB, Bed cubby 12v Power & USB, Interior LED bulbs, Toyota OEM tailgate lock.
