Auxiliary power.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by neversummeriam, Jun 28, 2012.
  1. Jun 28, 2012 at 7:03 PM
    neversummeriam
    neversummeriam [OP] Well-Known Member
    sam
    colorado
    Black 2012 Tacoma SR5 debadged
    Factory step sides (black). Katskin Leather Heated seats. Tacoma rubber floor mats. Totally Debadged, KCCO sticker added! Front emblem painted (blue). Engine cover painted (blue). Rear differential breather relocated (to rear storage box). Cobra DX 19 IV with a 3' No ground Firestik antenna and a Relentless Fabrications antenna hood mount. Blue sea 12 slot fuse box with ground. 100 amp Circuit breaker. Custom bed rack painted (blue). Mounted to custom rack; shovel, axe, Thule ski rack, 5 GAL. Jerry can holder custom built painted (blue), 20MM ammo can used as tool box. Relocated the 7pin for factory hitch. Under hood LED lights with push pin switch. Sylvania HID xenon filled headlight bulb replacement. Redline Quicklift plus hood struts. Body Armor Rear Plate Bumper w/tire carrier. Daystar 2 1/2" front Spacer lift 1 1/2 rear. 265/75-16 Goodyear Duratrac AVS dark tint Vent Visor. Leer Legend 100 Topper. Painted Gauge circles BLUE.
    Was wondering where there is a power source
    That comes on and off with the key. My cb
    Is hooked straight to the battery. And I forget to
    Turn it off. Sue me I'm a damn stoner!
    Anyway is there a easy power source out there
    That will only be on when the ignition is?
    Thanks.
  2. Jun 28, 2012 at 7:12 PM
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    cig lighter.
  3. Jun 28, 2012 at 7:22 PM
    neversummeriam
    sam
    colorado
    Can I just splice it into one of the lighter
    Or should I do away with the lighter all together?
  4. Jun 28, 2012 at 7:44 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    You can do either. Just keep in mind that the power point socket current rating will be reduced by the amount of the current draw of the CB.
  5. Jun 28, 2012 at 9:46 PM
    Dadic 78
    Dadic 78 Well-Known Member
    Fil
    Edmonton, AB CANADA
    08 Double cab TRD
    Maybe lay off the pot???
  6. Jun 28, 2012 at 9:50 PM
    Forster46
    Forster46 Very nice how much?
    Nick
    Mount Vernon, WA
    The doritos locos taco
    6000k HID's, AUX Reverse Lights, 3" Rough Country Suspension Lift, Pioneer AVH-P4200 Double Din, Underglow and footwell Lights, Camo Seat Covers, Duralast Tool Box, Blacked Out Badges, Grill, Front Emblem, Midland CB Radio, Amber Strobes, POWER REAR WINDOW, cup holder LED's, Firestik 3' in bed, console divider, Ultragauge.
    I hope you have your green card :spy:
  7. Jun 28, 2012 at 10:27 PM
    jackrules
    jackrules Well-Known Member
    Jack
    San Diego
    10 PreRunner Double Cab SR5 TRD Sport LB
    you could put a relay on the cigeratte lighter I think...
    you wouldn't take away from the 100 watt rating of your cig lighter
  8. Jun 29, 2012 at 3:03 AM
    Rellik01
    Rellik01 Well-Known Member
    Craig
    Windermere, Florida
    2012 TRD Sport 4x4 White
    Bull Guard powder coated white, chrome aftermarket tail lights,Led interior lights, Factory roof rack, Bug deflector, Factory tow package, Garmin GPS, Viper 5901 alarm with auto start, Weather tech window wind deflectors, , 3" Tube steps powder coated white, CB Radio, Radio Scanner.
    I put a solenoid on the ignition. It triggers when the key is on. works fine also added a blue sea fuse block. Looks like a pound of spaghetti under the hood but works great and safe.
