auxillary lighting bracket
Discussion in 'Lighting' started by dustinclm, Nov 17, 2010.
  1. Nov 17, 2010 at 7:18 PM
    dustinclm
    dustinclm [OP] Well-Known Member
    Thibodaux, La
    2012 Super White DC 4x4 V6
    Bilstein 5100 set at .85" WeatherTech Floor Mats
    this weekend i am looking to install some extra lights in the rear of the truck and while searching the threads i had seen that Scocar [OP] installed some pilot lights onto his towing package that came with brackets that allowed you to mount the lights to the towing package. does anyone have this set up (or similar) and used a different type of bracket because i wanted to do this on friday and i would have to order the pilot backup light kit just for the brackets.
    here is Scocar's reverse light set up: http://www.tacomaworld.com/forum/lighting/83616-1st-gen-extra-backup-lights-mod-writeup.html
  2. Nov 17, 2010 at 7:41 PM
    kinkrider101
    kinkrider101 Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
    there is already holes underneith so you just put whatever lights u want
  3. Nov 17, 2010 at 7:47 PM
    dustinclm
    Thibodaux, La
    i noticed the holes in the bumper already but there is a metal bar bolted across with come pretty odd looking "star" headed bolts and covers the holes and the trailer hitch will help shield the lights from debris and if i mount them to the bumper they will be "exposed" more
  4. Nov 19, 2010 at 7:36 AM
    iroc409
    iroc409 Well-Known Member
    Washington
    A red one
    Do you off road a lot? I have slim cheap-o fogs mounted to the bottom of the bumper, and I have had no issues romping around in snow or anything. I don't do any bumper-dragging off road, though. Mine hang down probably 2" or less.
  5. Nov 19, 2010 at 7:43 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    You obviously have a hitch so try to find lights that don't hang down lower or sit further back than the receiver. The hitch will provide some protection but that's a vulnerable area unfortunately. You could get the battering ram from Timicha for some more protection from the occassional bumper drag.
