Aww yea 5100's & 885's!
Discussion in 'Suspension' started by Tacoluver, Nov 5, 2009.
  1. Nov 5, 2009 at 4:31 PM
    Tacoluver
    Tacoluver [OP] Well-Known Member
    Norcal
    TRD Off Road shortbed
    Volant cold air intake, RevTek 3" Lift, Snug Top Toneau cover, Kenwood Navi, Jamoshi grill
    UPS just dropped these off, can't wait to install them tomorrow. I plan on setting them at .85" with the 885's like "usnaclee's" taco, but I also plan to use the 1/4" steel top plate spacers (not the actual coil spring spacers) that came with my REvtek lift. All on stock UCA's (yea I know). Should get just under 4" of lift. Anyone else done this?
  2. Nov 5, 2009 at 4:33 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    Thats sexy right there :laugh: Congrats man!
  3. Nov 5, 2009 at 4:33 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    You are gonna have a ride that is sligtly softer than an old wagon.
  4. Nov 5, 2009 at 4:38 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    :facepalm: You realize you will have NO down travel....right? Good possibility that if you hit a bump, you could break your shocks too.....Which means, you will get the oppertunity to see your truck on a flat bed trailor.
  5. Nov 5, 2009 at 4:40 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Yeah man...I wouldn't be so flippant about your stock parts. Cause Chris is right- 4 inches of lift is great...until you can't use your truck cause it breaks.
    Best of luck...
  6. Nov 5, 2009 at 4:40 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    are you 4wd cause if you are your cvs are going to die a slow miserable death
  7. Nov 5, 2009 at 4:41 PM
    texasbowhunter
    texasbowhunter Third Coast
    Texas Gulf Coast
    04 Double Cab 4x4 TRD
    Tinted Windows, Moto Metal 955's, Cooper 305/70/16 STT's, Deckplate Mod.,AFE Pro Dry, Toytec Coilovers, 2" AAL, Diff. Drop, Bilstein 5100's On the Corners, Alpine 10" Sub, Alpine 305 Head, Polk Mids
    I smell trouble!
  8. Nov 5, 2009 at 4:41 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Actually...They would die a rather quick death.
  9. Nov 5, 2009 at 4:43 PM
    WNYTACOMA
    WNYTACOMA Well-Known Member
    Clarence, New York
    09 Metalic Grey TRD OFF ROAD
    Toyota Nerf steps Bugflector 2 Tool box Weathertech floor liners Wet Okole F/R - Bk/Char
    Sounds like someone needs to suggest a 'Plan B' to the OP.
  10. Nov 5, 2009 at 4:51 PM
    ColtsTRD
    Scott
    AZ
    Don't do that!!!! Just leave your billys set at 0...the springs will give you 3" of lift alone :) and no spacer!!
  11. Nov 5, 2009 at 4:56 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    After all the info on this site, you managed yourself into this setup?
    Wow and good luck with that!
  12. Nov 5, 2009 at 4:56 PM
    ColtsTRD
    Scott
    AZ
    x2...I hope he listens :(
  13. Nov 5, 2009 at 4:58 PM
    MY50cal
    MY50cal ---- Tread Lightly ---- Leave No Trace
    Mojo
    Camden County, NC
    09 PM RC / 05 SWB AC (RIP)
    Yep.
    :facepalm:
    i hope he reads this before tomorrow...
  14. Nov 5, 2009 at 4:59 PM
    ColtsTRD
    Scott
    AZ
  15. Nov 5, 2009 at 5:02 PM
    Tacoluver
    Norcal
    Whoa thanks for the advice my taco brothers but this has been done before (minus the 1/4" top plate spacer). There's a thread on here using the same combo also set .85" without the top plate spacer he got 3.35" of lift and reported good ride quality. Also I have a Prerunner not a 4X4 so CV's aren't a factor. Their should be plenty of shock rebound at this setting vs. a stock spring set at 2.5". The only difference here is that I plan on adding the 1/4" top plate spacer, which does not compress the spring at all, for a little added lift. If anything if something fails it oughta be my balljoints. I'll report back tomorrow after the install.
  16. Nov 5, 2009 at 5:05 PM
    WNYTACOMA
    Clarence, New York
    Its in the good Lords hands now...
  17. Nov 5, 2009 at 5:05 PM
    Tacoluver
    Norcal
    BTW these springs only give 1.75-2" of lift sans the top plate spacer sold on Toytec. 3" is only achieved with the top plate.
  18. Nov 5, 2009 at 5:06 PM
    Tacoluver
    Norcal
    Again I appreciate all the concern. But if anyone else was crazy enough to do this please feel free to chime in.
  19. Nov 5, 2009 at 5:06 PM
    ColtsTRD
    Scott
    AZ
    x100000000
  20. Nov 5, 2009 at 5:09 PM
    Tsenekos
    Tsenekos Well-Known Member
    Greg
    Edmonton, CANADA
    2005 DC 4WD trd offroad
    Toytec 3" lift w coils,1.5 AAL,5100's all around,diff drop kit, axel shims,N-Fab nerf bars,bestop supertop,fog mod, weathertech mats
    just set them @ zero use the top plate and get a good safe 3" lift that will work very well
