Axle Flip
Discussion in 'Suspension' started by MowTaco, Oct 11, 2010.
  1. Oct 12, 2010 at 8:23 AM
    Beefed Taco
    Beefed Taco Taco Vending Machine
    Brian
    My Metal Shop
    99 Taco
    streetacos.com parts!
    2nd gen isn't as easy unfortunately. They use inverted shackles stock, requiring an entire shackle flip kit...but there is a very nice kit out there I've seen. The only Toyota model built this way for some reason.
  2. Oct 12, 2010 at 8:45 AM
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    And how much do you think he's going to get on a trade in on his 5 lugger towards a pre runner? really. Maybe you should do the research.
    There are quite a few bolt on SPOA kits available for several makes on the market. Suzuki's I am quite sure of.
    And even if he had to pay a full fledged shop to do his SPOA because he didn't have a "garage" or a few basic handtools and a few friends to help out.
    Do you think that justifies a stealership raping him ass to ear trading in his 5 lugger just cause he wants a little bit of lift?
  3. Oct 12, 2010 at 8:59 AM
    Beefed Taco
    Brian
    My Metal Shop
    99 Taco
    spring over & u-bolt flip:
    weld new perches to the top of the axle
    custom u-bolt plates
    weld on shock mounts
    longer shocks
    possible driveshaft lengthening
    spring over / no u-bolt flip
    weld new perches to the to of the axle
    square u-bolts
    6 lug u-bolt plates
    grind off old axle perches
    longer shocks
    best setup
    He's better off keeping it spring under. Deaver makes a little 3 leaf kit that replaces his overloads, turning his pack into a 5 leaf pack. Then he can run longer shocks and shackles if he wanted more lift, which he probably would. He could do spindles for the front, but the best (and most expensive) is a LT kit. Search for seibler, he has a 5-lug with this very setup.
  4. Oct 12, 2010 at 9:42 AM
    PreRunnerSeth
    PreRunnerSeth Well-Known Member
    Apex, NC
    16 Super White Limited 4x4
    Not enough lift. I'm definitely going SOA. SOA will give me clearance for 35"s. I have a Chevy dana 44 with flat tops that will get cut and turned for my SOA. will be doing the CPT Long Travel / Reverse shackle kit. Check out my build page in other builds.
  5. Oct 12, 2010 at 12:11 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I was just throwing that suggestion out there. Obviously, it depends on WHY he wants more lift to begin with. 5" lift is a lot for a 5 lugger. If he plans on putting bigger tires under it and going offroad - he's got a lot more to worry about in terms of overall integrity, strength, & power of his truck.
    Why would I do any research? It's not my truck.
    Yeah...I'm totally familiar with SOA. I'm totally familiar with what it takes to do one. I swapped axles under my jeep and the amount of work it took to do that is about the same as it would to do a SOA. For the most part, my husband and I did everything ourselves except having the perches checked, alligned, and professionally welded. I've had friends jeeps complete SOA's.
    Personally, I wouldn't trust a SOA KIT.....
  6. Oct 12, 2010 at 5:47 PM
    MowTaco
    MowTaco [OP] Well-Known Member
    Kansas
    16 Chevrolet Silverado
    I understand the concern for too much of a project... and thank you but I have quite a bit of willing help from a 10 year BMW master tech, a class full of "buddies" for an hour and a half every morning, and a full shop with 3 lifts and about all the tools I can think of "at my disposal" I think it's something we can handle, just wondering if it was possible. It sounds like it's gonna be way too high anyway. And thank you Beef for all those options. I'm guessing shackles will be my new option (I was thinking about it, wouldn't an aal actually drop the rear, being sprung under? again... me thinking... probably ends badly) and of course long travel would be optimal but no way in hell I'm putting like 10k into a truck worth maybe that. Anyway I'll continue my search... I don't wanna try to turn like 35s but maybe 30s or 31s. I'm just sick of sitting so low. Thanks guys
  7. Oct 12, 2010 at 8:29 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    The reason i asked what you would do to the front was because soa would give you 4 or 5" of lift. You won't be able to get anywhere near that in the front. Better off 2" up front and 2" in the rear to clear 31s. IMO
  8. Oct 13, 2010 at 4:22 AM
    Janster
    Jandy
    Lancaster, PA
    Another option....Do some research. Sounds like you have the right *thinking* process going on where you could figure something out with a little bit of research.
    The other thought I had....was looking for a used axle off a Prerunner or 4X4.
    **This is under the assumption the axles are the same width**
    It'll already be SOA, be an overall stronger axle, not sure how the gearing will be compared to what you have now.... The only concerns would be if your u-joints / driveshaft (flange?) would mate up to the pinion yoke. Aside from other concerns - brake lines, ebrake configuration, yadda yadda yadda.
    The springs you put on that axle would affect the actual height you'd get.
    Definately something to ponder on....
  9. Oct 13, 2010 at 8:57 PM
    MowTaco
    Kansas
    I have been researching. Just looking for cost savings (I know, do it right or don't do it). I just figured I had a few free inches there that would be relatively easy and cheap to use. I considered the prerunner axle to have an elocker but it turned out to be too much hassle.
  10. Oct 14, 2010 at 10:13 AM
    Janster
    Jandy
    Lancaster, PA
    YOu know you wanna trade that sucker in...and get a 4WD. :D:D:p:p
  11. Oct 14, 2010 at 10:18 AM
    Beefed Taco
    Brian
    My Metal Shop
    99 Taco
    Yeah, I'd just do shackles or an AAL. The leafs will raise the truck because you're simply adding more arc to the leaf pack, but the ride will get stiffer, the shackles will keep the suspension riding like stock.
  12. Oct 14, 2010 at 4:44 PM
    MowTaco
    Kansas
    I've considered it many a time... But I'm hoping to soon have a Samurai for my heavy offroading needs :D. Plus where's the fun in just trading in? "It's what you build, not what you buy"
