Axle replacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Smurf rig329, Dec 27, 2017.
  1. Dec 27, 2017 at 8:37 AM
    Smurf rig329
    Smurf rig329 [OP] Member
    Jorge
    2010 blue tacome sport
    33 in buckshot maxxis mudders, it has a 2 inch rough country leveling kit on it. Pioneer toich screen radio.
    NEED HELP!!!
    Axle replacement for 2nd gen taco...and GO
  2. Dec 27, 2017 at 8:57 AM
    craigs1
    craigs1 Well-Known Member
    2007 4Runner Limited, 4.0L
    Are you looking for somebody to come over to your place and do the swap for you, or somebody to search and post the multitude of info here on how to do it?
    Pigpen and dtaco06 like this.
  3. Dec 27, 2017 at 9:28 AM
    Smurf rig329
    Jorge
    I bowed up on my crow bar and still can get it to come out of the front diff...
  4. Dec 27, 2017 at 9:32 AM
    craigs1
    Rotate the axle a few degrees, retry the pry bar with quick and hard force, and repeat as necessary. When you find the sweet spot on the C-clip the axle will pop right out.
  5. Dec 27, 2017 at 9:33 AM
    Smurf rig329
    Jorge
    Thanks, did t want to break anything by beat him it but sounds like I'm gonna have to beat it
  6. Dec 27, 2017 at 9:45 AM
    badger
    badger Well-Known Member
    07 SR5
    it just needs a good pop
  7. Dec 27, 2017 at 9:54 AM
    Smurf rig329
    Jorge
    What about a hammer and punch
  8. Dec 27, 2017 at 10:01 AM
    badger
    07 SR5
    I think the safest and best way is with a slide hammer, but I'm sure all manner of implements have been used.
    dtaco06 likes this.
  9. Dec 27, 2017 at 10:11 AM
    craigs1
    There's a video of a guy using metal cable and a sledgehammer or axe as an improvised slide hammer, and much easier to use than a regular slide hammer. Basically loop the cable around the axle end nearest the differential like a noose, then loop the other end...
    https://www.youtube.com/watch?v=ZZ5JSWu6mTE
    ThunderOne likes this.
  10. Dec 27, 2017 at 10:22 AM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    My cv will not come out unless I use this method
    Works every time and have used it on other people rigs too
    scottalot and dtaco06 like this.
  11. Dec 27, 2017 at 10:37 AM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Just beat it
    Just beat it...
    scottalot likes this.
  12. Dec 27, 2017 at 11:52 AM
    Bebop
    Nick
    Axle popper tool. Just looks like a big pickle fork
    dtaco06 likes this.
  13. Dec 27, 2017 at 3:07 PM
    tacofish
    tacofish Well-Known Member
    N NJ
    14 ext cab 4x4
    3/1 lowrange spacer lift 285/70/17 wildpeaks
    Mine was a pain to get out used a bar and 5pd sledge
    When u put it back in make sure you have the c clip the right way (not sure if its up or dowm)
    goes back in alot easier - ask me how i know
    When i did mine didnt remove sway bar
    watch video
    Good luck
