Axle shims to cure vibes?
Discussion in 'Suspension' started by Voos, Nov 3, 2009.
  1. Nov 3, 2009 at 5:39 PM
    Voos
    Voos [OP] Well-Known Member
    Eric
    Albuquerque, NM
    Dbl Cab SB TRD Off Road
    Icon CO's, Total Chaos UCA's All-Pro 3" leaf packs w/ U bolt flip +Timbren, Rear Bilstein 5100's, Dick Cepek DC1's Black, 285/70R17 BFG ATko, ProDryS drop in, Dynomax Super Turbo
    I currently am running all pro 3" leaf packs and 3 degree shims with a carrier drop..
    Anyone has tried a shim with more angle to cure vibes? Trying to avoid the cost of a new shaft..
  2. Nov 3, 2009 at 5:54 PM
    bajamoon
    bajamoon Well-Known Member
    STEVE
    Whittier
    try less not more, every truck is defferent. shims on mine made it worse, great with just the cb. you can try a 2.5* shim, toytec has them in the 1st gen section i think.
