axle shims?
Discussion in 'Suspension' started by Justin626, Sep 6, 2008.
  1. Sep 6, 2008 at 10:01 AM
    Justin626
    Justin626 [OP] Well-Known Member
    Palmer, Alaska
    2007 4x4 TRD Sport DC Super White
    Toytec 3" w/ AAL, N-Fab Nerf Bars, Lightforce 170mm Strikers, N-Fab Light Bar, Metra Ipod Adapter, Scosche Auto Start
    Hey guys. Installing my lift today and I'm not 100% sure on how exactly to install the axle degree shims. I'm sure once I get in there it will be a bit clearer to me. Could I get a little guidance.....Chris, Beastly, 05.....anybody????:D
  2. Sep 6, 2008 at 3:01 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    if u got the ones from toytec, just install them w/ the arrow up and pointing in from the rear to the front. they will go under the leafs/above the axle or above the blocks/under the leafs, depending on the lift. the fat part of the shim is to the rear of the truck
  3. Sep 6, 2008 at 3:41 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Not sure how your lift goes.... The shim can be attached to the leafs using the center bolt or it doesn't necessarily have to be attached to it.
    Just make sure the 'head' of the centering bolt is in the hole on the spring perch.
  4. Sep 6, 2008 at 3:54 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    jhodge83 is right. Thick part to the rear. Inbetween the Leaf pack and the axel. You should only need 2.5* or less. :)
  5. Sep 6, 2008 at 10:11 PM
    Justin626
    Palmer, Alaska
    Thanks Hodge, and Chris for backing him up. Thanks Janster.
  6. Dec 12, 2008 at 10:05 PM
    skierpunk
    skierpunk Well-Known Member
    Oregon
    08 DC Off Road.
    TRD mats and seat covers, smoked tail lights, smoked turn signal corners, Revtek lift, Access LE tonnaeu, HIDs, grillcraft mesh grill, TRD CAI, custom bike racks, Alpine system.
    Shims are or getting rid of vibrations, right? If I'm not experiencing vibrations is there any reason to get them?
  7. Dec 13, 2008 at 12:14 AM
    The_Hodge
    SC
    exactamundo
  8. Dec 13, 2008 at 5:29 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    If your not getting vibrations, no reason to get them.
  9. Oct 28, 2011 at 10:17 AM
    geoandrew
    geoandrew Member
    George
    North Alabama
    2011 Tacoma 4x4
    3 " Lift Kit Tuff Country
    was your spring pack bolt head long enough to go through the shim and into the axle or did you have to add some 3/8" washers to achieve connection?
