axle shims??
Discussion in 'Suspension' started by countryboy22, Oct 24, 2009.
  1. Oct 24, 2009 at 11:55 AM
    countryboy22
    countryboy22 [OP] Well-Known Member
    Arizona Mountains
    05 SR5 4x4
    TRD cold air intake, Bilstein 5100's @ 2.5, Toytec 1.5" aal w/rear bilsteins. MBRP tip, Flowmaster Delta Flow 50 series, Toytec axle shims and carrier bearing drop.
    `do you need longer u bolts to install shims? i also have a 2 aal already installed.
  2. Oct 24, 2009 at 11:57 AM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    As long as you have a little thread showing past the u-bolt nuts you should be fine.
  3. Oct 24, 2009 at 12:00 PM
    countryboy22
    Arizona Mountains
    05 SR5 4x4
    well i dont know i havent put the axle shims in i jus wondering if once the shims are in if the stock u bolts will work
  4. Oct 24, 2009 at 12:01 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
    They are not big at all. All you need to worry about is if you have enough thread to tighten the nuts.
  5. Oct 24, 2009 at 12:06 PM
    countryboy22
    Arizona Mountains
    05 SR5 4x4
    ok i think i going to order new ones from toytec cuz i think once i get the shims in i wont have alot of thread left
  6. Oct 24, 2009 at 12:06 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
    Thats a good idea. They are not expensive. better to be safe than sorry.
  7. Oct 24, 2009 at 12:13 PM
    countryboy22
    Arizona Mountains
    05 SR5 4x4
    ok thanks i just ordered the carrier bearing drop axle shims and u bolts. i got bad vibes since i put the billys on and the aal
  8. Oct 24, 2009 at 12:16 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Very good idea to order new u-bolts. It's NOT a good idea to reuse u-bolts because they don't stay tight as well as new ones will.
