Axle Wrap & Traction Bar
Discussion in '1st Gen. Tacomas (1995-2004)' started by tr0gd0r, Feb 19, 2009.
  1. Feb 19, 2009 at 1:17 PM
    tr0gd0r
    tr0gd0r [OP] Well-Known Member
    Pullman, WA
    2012 Silver Streak TRD Offroad DCSB V6 4x4
    TRD Catback Exhaust - 265/75/16 BFG KM2s
    I notice that my 99 Tacoma (stock) has some axle wrap at take off. As I understand it, Traction bars are supposed to stop this wrap. Can anyone recommend a traction bar for a stock (no lift) Tacoma or another way to prevent the wrap?
  2. Feb 19, 2009 at 2:53 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    In most cases, an AAL will eliminate the Axel Wrap, but it will lift the rear up. Any trac bar should be able to cure the issue.
  3. Feb 19, 2009 at 7:39 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    im not sure if anyone even makes a traction bar for a stock tacoma. You can always make one up yourself.
  4. Feb 19, 2009 at 7:40 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    traction bars are usually pretty expensive..................but you can get a set of helper springs from autozone for around $25, and they will help eliminate the axle wrap.
  5. Feb 19, 2009 at 7:41 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    i think budbuilt makes one
  6. Feb 19, 2009 at 7:42 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yep.....they do carry them, but me thinks they are around $450 or so a set.
  7. Dec 19, 2013 at 6:43 AM
    jwiereng
    jwiereng Member
    If one installed traction bars could one remove a leaf or two and add airbags?
  8. Dec 19, 2013 at 1:08 PM
    Alderleet
    Alderleet Ace of Spades
    Nick
    Salty Hell
    '00 Acc Cab TRD 4x4
    I remember reading on pirate 4x4, and there was a thread about a single-link anti wrap bar.
    Someone basically welded a bracket to their pumpkin, and then attached a mount to the cross brace where the center support bearing sits.
    from there, double heim joints, and voila a top mounted anti wrap bar, that articulates with the rear axle through full motion, and doesn't effect ground clearance.
