B.A.M.F 2nd Gen rear shock relocation kit GB feeler
Discussion in 'Group Buys' started by JLee, Nov 7, 2012.
Thread Status:
Not open for further replies.
  1. Nov 15, 2012 at 9:33 AM
    #61
    JLee
    JLee [OP] The Man! Vendor
    Jerry
    Benicia, CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    BUMP!
    This GB is open and the page is up pricing is set at 20% off we will start shipping DIY kits Monday and the welded kits mid week click HERE to order
  2. Nov 15, 2012 at 9:43 AM
    #62
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    OP, this is great! However, I think you should provide the exact collapsed and extended length of the shocks these were designed around so people dont experience premature bottoming out or over extension. Shocks within the same brand are drastically different when it comes down to different bodies, mounts, and rod end lengths. Just my .02
  3. Nov 15, 2012 at 9:46 AM
    #63
    JLee
    Jerry
    Benicia, CA
    Yeah I'll have to get that info from Alex.
  4. Nov 15, 2012 at 10:16 AM
    #64
    NoSoup4You
    NoSoup4You Well-Known Member
    David
    Palos Verdes
    2008 DCSB DMZ LT 4x4
    Camburg | King | Glassworks | DMZ | Nitro | Banks | Pelfreybilt | Brute Force Fab | Bay Area Metal Fab | Baja Designs | Rigid Industries | STL
    :woot: got mine ordered!
  5. Nov 15, 2012 at 10:32 AM
    #65
    mgrande
    mgrande iKill
    Raleigh
    2011 TRD off road
    Kings, AP 3" leaf pack, timbrens front and rear, TC UCA's, pro comp 7189's, baja ATZ's, CBI sliders and rear, relentless front, dynomax catback
    Well shit. I can't afford it right now :(
  6. Nov 15, 2012 at 10:53 AM
    #66
    JLee
    Jerry
    Benicia, CA
    thanks for the order!
    :eek:
  7. Nov 15, 2012 at 12:13 PM
    #67
    kcbmx
    kcbmx doing my thing.
    Marco
    Bakersfield CaLiFoRnIa
    2tr-fe 4wd
    spit cup, weathertech floor mats, riffle rack, and bilsteins.
    Ordered, thanks Jerry!
  8. Nov 15, 2012 at 12:27 PM
    #68
    bulhas
    bulhas the habs fan
    Joe
    Edmonton, Alberta
    1997 Rexus
    LS Swap 500 hp......
    So do I even need to reply :p
  9. Nov 15, 2012 at 1:17 PM
    #69
    mgrande
    mgrande iKill
    Raleigh
    2011 TRD off road
    Any chance I can still order mine after Thanksgiving?
  10. Nov 15, 2012 at 1:46 PM
    #70
    JLee
    Jerry
    Benicia, CA
    Sure I don't know if they will be 20% off still but you can order.
  11. Nov 15, 2012 at 1:56 PM
    #71
    Manwithoutaplan
    ID
    very tempted:rolleyes:
  12. Nov 15, 2012 at 5:12 PM
    #72
    hard2kill
    hard2kill Well-Known Member
    Rhinebeck NY
    06 4door trd sport white 6spd
    ...315's,2in bora wheel spacers,safari snorkel,wheel spacers,bruteforcefab rear bumper and sliders,afe filter,hi-lift jack,5100 with OME 886 & 1/2in spacer,allpro expo's,icon 10in rear shox,flip kit,ss brake lines,cobra cb,fog light mod,yellow fogs,weathertech mats,fullsize spare tire and extra sport rim,tinted windows,aeroturbine 2525 muffler dumped over axle...rear diff breather mod...removed factory spare...removed 2nd air filter...THULE roof rack and fairing....bud builts front to back,allpoo front bumper,BAMF lca skids,overland Offroad roof and bed racks,
    watching this.....got the shackle flip waiting just need this and 12in shocks......my 10in icons i dont think will handle this
  13. Nov 18, 2012 at 9:58 AM
    #73
    JLee
    Jerry
    Benicia, CA
    BUMP for shock specs these are the shocks we used in the mock up.
    KING Part# PR2012-SSNR 12.0" stroke 31.585" Extended Length 19.585" Collapsed Length 7/8" Shaft Dia
  14. Nov 20, 2012 at 6:22 AM
    #74
    disc0monkey
    disc0monkey All right. I believe ya. But my Tommy Gun don't!
    I have an idea and you guys can tell me if its stupid.
    Can you make a set of upper brackets that will keep the shocks in their current location? make the bracket to move the mount up 2" to try to fit a set of 10" shocks.
    maybe at worst we'll have to take a hole-saw to the bed on the one side. using an eyelet bushing on top should also help our cause.
    the reason for this is, i don't want to get bigger bumpstops and reduce up-travel, also this will keep the bottom shock mounts at the lower mounting point.
  15. Nov 20, 2012 at 10:43 AM
    #75
    mgrande
    mgrande iKill
    Raleigh
    2011 TRD off road
    You shouldn't need to bump
    early if you weld the shock mounts in the right location. I always forget his name (stfyu?) But his are welded on a little high. Also in some of the pictures he has negative arch, but that was due to the shackle flip, not the shocks.
  16. Nov 21, 2012 at 4:55 AM
    #76
    disc0monkey
    I hear ya, I think the main reason being is I cannot weld to cast, so I'd rather keep my stock lower mounting points on the shock.
    The truck can't really have any downtime other than the weekend, so I can't take it anywhere.
    edit: after looking at the pics on the first page, are the axle tubes steel or cast?
  17. Nov 21, 2012 at 12:40 PM
    #77
    sytfu510
    sytfu510 Instagram: tacoma510
    Alex
    Bay Area
    06 DBL Cab Long Bed TRD Sport
    Dirt Designs LT kit front and 3 link kit rear SCS Wheels BAMF rack, bumper ,sliders
    The problem is your bottom mounts are not on the same side; one is in front and one is on the back of the axle housing. With the Relocation kit it puts both shocks in front of the axle. I still get negative arc if I flex the truck hard. My bumps need to be moved down a bit but I have them out right now getting the travel shortened from 4" to 2".
  18. Nov 21, 2012 at 1:05 PM
    #78
    Supra TT
    Supra TT Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
    They are steel. Easily welded too. ;)
  19. Nov 21, 2012 at 3:06 PM
    #79
    mgrande
    mgrande iKill
    Raleigh
    2011 TRD off road
    Why are you changing the bumps from 4" to 2"? If you removed the shackle flip and you still get negative arc, that should have nothing to do with the shock kit right?
  20. Nov 21, 2012 at 4:07 PM
    #80
    sytfu510
    Alex
    Bay Area
    It's doesn't. I get negative arc because my air bumps allowed too much up travel. I have to shorten them because I can only mount them so far up without cutting into the bed. At 4" of travel the bump stop was only 3" above the strike plate. Every other bump it would hit.
Thread Status:
