B.A.M.F BPV Relocate bracket
Discussion in 'Bay Area Metal Fabrication' started by JLee, Oct 23, 2011.
  1. Oct 25, 2011 at 6:56 PM
    #41
    JLee
    JLee [OP] The Man! Vendor
    Jerry
    Benicia, CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Invoice sent and take a picture of your bracket and send it to me it shouldn't be touching your axle.
  2. Oct 25, 2011 at 7:06 PM
    #42
    TACOMABOSS
    TACOMABOSS Well-Known Member
    96 SR5 4x4
    Bilstein 5100s, Toytec AAL, Deck plate mod, Hella 500ff's, Sportsman Camo seat covers, Total Chaos 1" diff drop, JVC stereo, Painted bumpers and grille, Custom grille insert, HID projectors, Black spray paint
    Is this an important part for lifted trucks?
  3. Oct 25, 2011 at 7:17 PM
    #43
    JLee
    Jerry
    Benicia, CA
    Yes it is your rear brakes have a load sensing valve so if you load your truck up is applies more braking power to the rear brakes. If you have lifted your truck and didn't relocate your BPV arm your truck will never know if you have anything in the back. Plus it's moved down even more so will be using less brakes unloaded as well.
    In a nut shell if you want to stop better you need to relocate your BPV arm as high as you lifted the truck in the rear.
  4. Oct 25, 2011 at 7:20 PM
    #44
    TACOMABOSS
    96 SR5 4x4
    oh ok. so my truck is lifted around 2 inches in the back. So the valve should be raised 2 inches as well?
  5. Oct 25, 2011 at 7:55 PM
    #45
    JLee
    Jerry
    Benicia, CA
    Yes.
  6. Oct 25, 2011 at 8:57 PM
    #46
    brs127s
    brs127s Well-Known Member
    O'Fallon, MO
    04 D-Cab 4x4 Limited TRD
    TRD Headers, Aero Turbine AT2525XL Deckplate Mod, TRD tranny cooler, King Coilovers, LR UCAs, Alcan 5 Leaf springs and Bilstein 5100s, Shrockworks front bumper, CBI rear bumper.
    Sorry to hijack this thread, but here are some pictures of the BPV bracket:
    I am guessing it is not supposed to be bent in against the axle as in the pictures.
  7. Oct 25, 2011 at 9:07 PM
    #47
    pyroskier
    pyroskier Well-Known Member
    Jacob
    Laramie, WY
    2004 Ext Cab TRD 3.4
    No it shouldn't be. I'm guessing it's not hurting a lot, but rubbing/irregularities when it comes to your Brake system is never a good thing.
  8. Oct 25, 2011 at 9:09 PM
    #48
    pyroskier
    Jacob
    Laramie, WY
    I'm good w/ the ones you send me, you don't need to spend more on shipping/bolts for grade 8. I'd have to be in some serious shit to NEED grade 8 for the BPV. I doubt most/any car companies make them with grade 8
  9. Oct 25, 2011 at 9:28 PM
    #49
    JLee
    Jerry
    Benicia, CA
    I know that's why I did :devil:
  10. Oct 25, 2011 at 9:29 PM
    #50
    JLee
    Jerry
    Benicia, CA
    Yeah it's just tweaked a little your could still run the bracket no problem.
  11. Oct 25, 2011 at 10:29 PM
    #51
    brs127s
    O'Fallon, MO
    Once I am ready to install the BPV relocation bracket, I will take it off and tweak it back. It looks as if it is bent right on the very end.
  12. Oct 26, 2011 at 7:35 AM
    #52
    JLee
    Jerry
    Benicia, CA
    Yeah it shouldn't be too bad to bend it back into place. The reason im cutting these brackets in 1/4" plate is so the bracket wont get bent when wheeling. The first one I made for my truck as been bent quite a few times but it was thin sheet.
  13. Oct 26, 2011 at 7:41 AM
    #53
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    I might get one of these on a rainy day. I've had some issues with my one from beefed taco and I'd rather just replace it than keep hacking at it.
  14. Oct 26, 2011 at 7:59 AM
    #54
    JLee
    Jerry
    Benicia, CA
    Okay man let me know I've got 3 more on me right now ready to ship and I'll be cutting 50 more next week.
  15. Oct 26, 2011 at 11:33 AM
    #55
    JLee
    Jerry
    Benicia, CA
    I've got 3 more of these sitting on my desk ready to ship right now!
  16. Oct 26, 2011 at 4:14 PM
    #56
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Did you try the for sale section?
  17. Oct 26, 2011 at 4:38 PM
    #57
    JLee
    Jerry
    Benicia, CA
    This thread is good enough just letting prople know I have more ready to ship.
  18. Oct 26, 2011 at 4:40 PM
    #58
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    what kind of cnc are you using? im currently in machining to get a 2 yr degree
  19. Oct 26, 2011 at 4:42 PM
    #59
    JLee
    Jerry
    Benicia, CA
    TorchMate CNC table with a Hyperthurm powermax 45 air plasma.
  20. Oct 26, 2011 at 5:35 PM
    #60
    2000GTacoma
    Snow Hill NC
    cool we use all haas equipment at school cnc lathes mills and a huge cnc router
