B.A.M.F Weld on Rock Slider Install
Discussion in 'Bay Area Metal Fabrication' started by JLee, May 2, 2012.
  1. Aug 12, 2012 at 6:54 PM
    Madjik_Man
    Colorado Front Range
  2. Aug 12, 2012 at 8:49 PM
    JLee
    JLee [OP] The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
  3. Aug 13, 2012 at 6:21 AM
    Madjik_Man
    So is that wire brush thing I have good enough or should I try to borrow an angle grinder and buy one of those pads Supra listed?
  4. Aug 13, 2012 at 7:29 AM
    JLee
    Jerry
    Grass valley CA
    The cup brush is fine hell all i did with my sliders is rub them down with denatured alcohol and hit them with a Scotch-Brite pad self etching primer and rusto bet liner and they are still holding up after two years.
  5. Aug 13, 2012 at 8:07 AM
    Madjik_Man
    I was just going by your write up :(
    :p
    I'll just do the scotch brite pad.
    Last idiotic question: what's the purpose of the wire brush/scuff pad step in this procedure? To get rid of any rust or surface crud before priming/painting?
  6. Aug 13, 2012 at 8:30 AM
    JLee
    Jerry
    Grass valley CA
    it preps the sliders for paint you want tiny little scratches in the steel so the paint has something to adhere to.
  7. Aug 22, 2012 at 5:24 PM
    Bennett707
    Bennett707 Station707
    Oregon
    No more taco life for me
    I can't weld the gussets if I paint...
    Son of a...
    Ruined my weeks plan.
  8. Aug 22, 2012 at 5:58 PM
    JLee
    Jerry
    Grass valley CA
    Just leave the tops of the legs bare and just touch up the tops after welding.
  9. Aug 22, 2012 at 6:06 PM
    Bennett707
    Oregon
    Good idea jerry. Been a chaotic day. Thank you :)
    I really need toget a welder and learn so i don't have to rely on others.
  10. Aug 26, 2012 at 11:22 AM
    Madjik_Man
    Fack...
    1. I painted the entire leg(s) except the last 1.5". I forgot about the top of the legs where the gussets will go. What to do now?
    2. The gussets and plates are still wrapped in saran wrap. Do those have oil on them to prevent rusting? Do I need to clean the gussets and plates with the acetone and then scuff them up with the scotch brite pads?
    Sorry I'm such a knob.
  11. Aug 26, 2012 at 11:22 AM
    Bennett707
    Oregon
    funny. i taped the gusset spots but forgot about the last 1.5"!
  12. Aug 26, 2012 at 11:33 AM
    Madjik_Man
    Tweedle dumb and tweedle dumber!
    I guess I just have to strip the paint off the top
  13. Aug 31, 2012 at 10:33 PM
    Bennett707
    Oregon
    soo.. i have some rub noise i believe it is due to me not gapping from the pinch weld.. any possible fix or just get use to it?
  14. Sep 1, 2012 at 12:42 PM
    Drunknsloth
    Drunknsloth Indffrnce will be the fall of manknd but who cares
    Retribution
    South West
    08 SR5 Access V6 6-Speed
    Blacked-Out Badges; Retribution Decals (Sockmonkey); Tailgate Mod; Red LED Rear Blinkers; Yellow Foglights; Yellow Front Blinkers; Superwhite Xenon Corner Bulb; Leer Bedcap; Bedrug Bedmat; Black Cupholders; Black Plastic Piece Around Window Controls; Plasti-Dip Front Bumper Valence; Plasti-Dip Grill Surround; Blackout Chrome Back Bumper; Metal Miller Skid-Plate; Aero Turbine 2525 Muffler; TSB Rear Leaf Springs and Shocks; Satoshi Grill Pending; Off-Roading Torn off Mirror (Replaced); Blue-Sea Fuse Box; Tinted Tail Lights; URD Short Shifter; Interior Mood Lighting; Hood Lights; BedLights Pending
    Some guys on here cut off the pinch weld :notsure:
    Not sure if it's a good idea or not...
  15. Sep 2, 2012 at 8:38 AM
    #35
    Madjik_Man
    Did you not gap at all from the pinch weld or just minimally?
  16. Dec 10, 2012 at 11:19 PM
    #36
    andrew8404
    andrew8404 Well-Known Member
    ANDREW
    Albuquerque, NM
    17 DCSB TRD OR 4x4 (Sold) 19 Ford Ranger Sport XLT 4x4
  17. Dec 18, 2012 at 1:00 PM
    #37
    magnetic11
    magnetic11 Well-Known Member
    "some nuke plant"
    11 trd sport
    Fab fours front and rear bumpers, B.A.M.F. weld on rock sliders, softopper, removed mud flaps and D-Badged everything. Icon 2.5 Extended Travel coil-overs, Total Chaos upppers, 2.0 Icon extended travel shocks with the resi's and Dekar Leaf packs.
  18. Jan 17, 2013 at 11:32 PM
    #38
    99nmtaco
    99nmtaco Well-Known Member
    Patrick
    NM / VA
    2001 4 Runner
    ADS racing shocks ext travel front, ADS FJC piggyback shocks rear, Addicted Offroad front plate bumper, 4xinnovations rock sliders and rear plate bumper, SCS Stealth 6s
    Hey Jerry nice write up! I have a question about welding to the driver side frame on my 99 taco. Should I be worried about the fuel tank when welding the back leg to the frame? Do I just use a welding blanket and put it between the frame and tank?
  19. Jan 18, 2013 at 6:33 AM
    #39
    JLee
    Jerry
    Grass valley CA
    Take every precaution you can a welding blanket would be nice. If you smell any fuel at all do not even start welding.
  20. Jan 18, 2013 at 6:42 AM
    #40
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
